Question about Samsung Televison & Video
I have no audio sound on my USB recordings when I play back on my Samsung TV in one room , When I put it in another TV again a Samsung it plays back as it should ,, picture & sound
  • 298 Answers
SOURCE: Playback problem EP
Do you have a tracking control on the
vcr if you do it should be centered during
record It can be adjusted during playback
to clear up the picture adjust it for the best
If you dont have a tracking control on the
vcr then it may require a mechanical adjustment
of the backtension or guidepost which requires
special tools to perform
Posted on Nov 18, 2007
Benimur
  • 6966 Answers
SOURCE: Picture rolls on playback
I beg to differ that the head is dirty. This is based on your post "...pre recorded tape is played the picture is fine..."
I am more inclined to suspect:
  • servo calibration. This would be the capstan motor controller. The recording speed slightly differs with the playback speed. You could try manually adjusting the tracking control and see if it corrects the problem;
  • recording speed selection, LP, SP, EP/SLP. try recording at the lowest speed LP;
  • video source, possibly of a different color system, PAL, SECAM, NTSC.
Hope this be of initial help/idea. Pls post back what is your video source, how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 24, 2008
  • 34 Answers
SOURCE: direct tv hdbox & Plasma TV & DVD SSound system & DVD recorder
Need to make sure you have the red,white,and yellow rca connection cables ran from the samsung dvd player to the red,white,yellow input on the back of the dvd recorder. Once you do that make sure you put your dvd recorder on line 1 input. If you look closely on the back of your recorder it should say line 1 input. If your recorder isn't on that input you can put the recorder on line 1 input by using dvd recorder remote and pushing the input button. Make sure you don't push the tv input button the dvd recorder remote there should be a seperate input button or a way to toggle the inputs on the recorder. Once you verify all that turn on your tv and go to the input on your tv that you watch the dvd recorder on and you should see what your recording on the tv.
Posted on Nov 21, 2008
Jma11
  • 140 Answers
SOURCE: LP audio recording seems to be at the wrong speed
1- The turntable is set to 45 rpm and the album is recorded at 33 rpm. Press the 33 rpm button the red light should come on turn the and be fine.
or
2- This turn table has a fast record mode where you can record a 33 rpm LP faster by spinning it at 45 rpm. If you are trying to use this mode you will have to make a software setting to tell the TTUSB10 digital converter program what mode you want to run.
Posted on Nov 29, 2008
SOURCE: Samsung DVD-SH853M HDD/DVD Recorder/Digital Receiver
Make sure you are not using DVD+R dics - the player won't play these. It is OK with DVD-R.
Posted on Jul 02, 2009
No audio after recording from sat. Reciever
Double-check your input cables from the receiver to the LG 389. Do you have the sat. receiver AV out connected to the front AV In on the LG DRT389? Make sure that you haven't mixed up the L and R audio connections on either side. (I've done something similar with RCA cables myself.) Next, try a different set of cables.
If that doesn't work, there may be a problem with the audio jacks on either your receiver or the 389. To check, plug the AV cables from the Sat. Receiver directly into the TV. If you have sound and video, then the input jacks on the recorder may be damaged.
Try using another input. (It looks like some models have the SCART input; you may need to set the input source in the menu under AV2 Decoder.)
The fact that you have audio output on USB and DVD's means that cables/connections between the LG289 and the TV are fine.
I hope this helps. Please add a comment with the details of which AV port you are using on the LG389 for additional assistance.
Aug 31, 2012 | LG DR389 MULTISYSTEM DVD RECORDER FOR...
I want to use my TV's speakers with Samsung ht320z not surround sound.How?
You have to hook up the audio cables to the TV from the DVD stand alone player. Red and White is audio and Yellow is Video. The player will play movies and the sound should go to your TV speakers. If not you will need to set it on the TV in the audio source to play from your speakers on the TV. John
Apr 15, 2012 | Samsung HT-Z310T Theater System
I have a Samsung SL620 digital camera with a Lexar 4GB SD card. It plays great videos and I am able to view them on my computer. However, when I put the SD into the USB of my Samsung LN46C630 LCD...
Probably because the tv doesn't have the correct circuitry to play videos. If you have a VHS recorder connected to the tv, you could download the video to a tape and play it that way. I have a Dish Network HD DVR. It has a usb connector allowing me to download to the DVR and play slide shows and videos.
Sep 15, 2010 | Samsung SL620 Digital Camera
The video and audio dont match when I play the dvd back
Hi and Welcome to Fixyah,
Audio and Video is out of sync when play the DVD, Suggest for that is go ahead and disconnect your dazzle and reconnect to another usb port and then Click on Start>Control panel>system>hardware>device manager>sound and video games controller> right click on video capture device and uninstall it. Restart your computer. Go ahead and then re-record again.
May 20, 2010 | Pinnacle Dazzle DVD Recorder
There is a 1 second delay from the time i play to
adjust your audio buffers, if your recording software allows it. however, there will always be some latency in usb recording devices. i recommend firewire or pci internal cards for recording.
Nov 30, 2009 | M-Audio Fast Track USB (FASTTRACK) Audio...
Direct tv hdbox & Plasma TV & DVD SSound system & DVD recorder
Nov 20, 2008 | RCA RTD155 System
Feed realtime audio and vdeo from webcam back to laptop.
to avoid short time agravation just put a inexpensive baby monitor i the room for the sound and use computer for video ... or get xn10 equipment ...
Sep 08, 2008 | Logitech Webcam
Can't transfer dubbed audio (secondary sound) using firewire.
Audio Dubbing on DV: Here's how you do this: Play your tape on the TRV-9 and feed the signal into the TRV-900, using the Firewire connector. Set the TRV-900's audio option to record in the 12-bit mode. When this is done, you will have the video re-recorded on the TRV-900 and the audio laid down on the primary 12-bit audio channel. Then, you can run the tape back through for a 2nd pass in the TRV-900, with the recorder set to the audio-dubbing mode. The audio you put into the TRV-900 this time, will be recorded on the secondary 12-bit channel. You can select either 12-bit channel when you play the edited tape back or you can mix both stereo channels into the output. Once you record on the 16-bit channel, you can't dub audio back onto that recording, without erasing the original channel, as the recording space for both 12-bit channels is occupied. You can't selectively re-record just audio onto the 16-bit channel either, without the video being re-recorded along with it. Both video and audio are sent over the same Firewire connector, so you can't input them from mixed sources, as you can with analog recordings. Only the secondary 12-bit audio channel can be used in the audio-dubbing mode. You can't dub onto the 16-bit channel or onto the primary 12-bit channel. The primary 12-bit channel can be used only when you're recording video along with it.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Televison & Video Logo
22 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
