Question about Samsung Televison & Video
I have a new 4h SUHD TV and ATT Uverse which is only broadcast at 1080i. What service do I go with to get 4k channels? My tv is 4k+ but not getting any of the benefit using Uverse
TV is Samsung SUHD 8000 Series TV which is one step down for their most top of the line. I feel I overspent for a TV that cant get a signal to how off its quality. I must not be the only person with this issue
    Top Expert:
  • Samsung Master
  • 79,865 Answers
4k will be picked up automatically when it is present, there is little 4K broadcast material available as of this date.
Posted on Dec 22, 2016
Samsung curve 65 inch has no sound, has picture.. Using Bluetooth curved sound bar, no sound on tv speakers either
Hi!
Check your power amp circuit. Or, check if it is feed by the power supply circuit. Good luck,
Serge.
Oct 09, 2016 | Samsung UN65HU8700 65"" Curved 4K Ultra HD...
How do I change the resolution on my Phillips 4k tv from 720 to a higher resolution tools
The TV will select the correct/appropriate resolution based on the source. To achieve the highest resolution you will have to connect a unit (video source) capable of providing 4K using HDMI 2.0 compliant cables. To achieve any HD resolution, the video source will have to be connected to a HDMI port. The ATSC terrestrial digital broadcast signal (over the air TV) is generally 720p, but many stations transmit in 1080i/1080p.
Jun 23, 2016 | Televison & Video
I just bought the samsung 65" 4K and cant program samsung remote with att uverse boc
2509,2556,2541,2593. Check these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 05, 2015 | Samsung 65" Class 64-1/2" Diag. - LED - 4K...
Uverse receiver signal is not 1080i
Hi Drkdani45,
I have this useful link for you where in you can see how to set screen tv settings to 720p to 1080i. Hope it helps.
http://www.att.com/support_media/images/pdf/uverse/Quick_Fix_Guide.pdf ( if you can't go to this manual directly please click on the new link below and click Configure your AT&T U-verse Receiver for High-Definition)
verse TV Support
Jun 21, 2012 | AT&T UVerse
Panasonic TC P50S2 tv loses sound fairly often. use at&t uverse hd receiver and after rebooting the dvr/receiver, the muting problem is gone for between 1 day and and 2weeks. at&t says the tv...
Use the component connection not the HDMI. Some of the ATT boxes have issues with the HDMI ports. Uverse is only broadcast in 1080i not p so you will not lose any video quality.
Apr 27, 2011 | Panasonic Viera TH-50PZ80U Plasma TV
Only showing on 480i even with hdmi cables on my element 55"
Not the problems with a HDMI cable.U getting only 480i because the tv station u are watching are broadcasting tv signal are in 480i only.Tries difference channels like 2 CBS or 4 NBC alway broadcasting in 1080i.See,u will getting 1080i.Ur tv good,it doesn't have any problems.
Mar 14, 2011 | Element Electronics ELDTW401 TV
Just brought a new Sharp Aquos LC-40LE810UN. Every time I turn on the TV, using either HDMI or component cables, the input screen ALWAYS cycles between 480p and 1080i trying to find a "signal"...
This tv the tv Tuner signal board have intermittent interlacing scanning freqencies problem.Tv is new,u just bought this tv wright,return it get another one for the replacement.
Dec 11, 2010 | Sharp Televison & Video
Not able to program vizio remote towork with att uverse Cisco box
Maybe too late for you but ATT just gave me a code that works with my Vizio plasma. Code is 1343. Even the mute works correctly. They gave me some others to try but I didn't need them. Other codes were 1018, 0030 and 0056.
Mar 19, 2009 | Vizio VO47L 47 in. LCD TV
Programing Remote
1343 or 1005 are the codes - press the TV mode button and the OK button together - the release at the same time - the top row of mode buttons needs to blink twice - then enter the code - the TV button should blink 2 times - try the power and volume buttons - if it worked then be sure to press the ATT mode button again after so you can change the channels
Jan 02, 2009 | LG 32LG30 32 in. LCD HDTV
Samsung DLP 56' TV turns itself off when I initially turn it own. (I turn it on, then it shuts off for approximately 5-10 seconds and turns back on. Sometimes it does it a couple of times before it stays...
The problem is with the ATT UVERSE HDTV BOX and not the Samsung DLP TV. There is an inherent problem with the ATT UVERSE HDTV Box when using a HDMI cable. This was verified by the ATT UVERSE Technician.
Thanks,
Dec 13, 2008 | Televison & Video
Televison & Video Logo
98 people viewed this question
Jerry Greenberg
Jerry Greenberg
