Question about Dryers
Dryer turns on, runs for a minute then stops. All the light around the dail blink.
  • 1122 Answers
SOURCE: Whirpool Senseon stops mid-cycle
there is a thermostat called a thermister on the blower box that will do that(run for few minutes and shut off) get the model number off dryer door or on inside dryer door wall ,go to sears .com click on parts put in model number and it will show you exactly where everything goes,let me know how you do-mike
Posted on Oct 02, 2008
dragonsthatk
  • 547 Answers
SOURCE: FRIGIDAIRE AFFINITY ELECTRIC DRYER NOT STOPPED HEATING
eleiment
Posted on Feb 18, 2009
  • 10 Answers
SOURCE: the dryer will run for a few minutes then stops
Sounds like a bad heating element. Take a Voltohm meter to check the continuity of the element for a short.
Posted on Jul 07, 2009
  • 1738 Answers
SOURCE: dryer stops running
Sounds like control board issues. You can look up the code on the internet with your model number.
Posted on Oct 10, 2009
KevinWhite
  • 1902 Answers
SOURCE: I have a Fridgidaire Dryer
Hello & Welcome to FixYa
If you have already tried cleaning the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair. It is located on the blower wheel housing inside the rear panel to the exhaust duct. You can test it for continuity before replacing, if it has continuity then it means that the problem is with the control board that is bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on Jun 14, 2011
Leq2152ee1 dryer does dry but keeps stopping if put on any setting over 15 min. Dryer stops single beep and top four lights blink.
MAY BE BAD MOTOR WITH BAD WINDINGS USUALLY STOPS AFTER 20 MINUTES OF USE? OR HEATING ELEMENT IS OVERHEATING? DUE TO BAD VENTING? THERMAL CUT OFF KEEPS SHUTTING IT DOWN?
May 08, 2014 | Frigidaire GLEQ2152ES Electric Dryer
Blinkin light
Turn the main power to the unit off, leave off for about 20 seconds then turn back on. Unit should restart. The blinking light is a fault light that can be reset by turning main power off. Most times it will restart no problems but if the fault re occurs there is a problem with the unit itself. If the fan starts and runs for around 4 minutes on cooling mode then stops and blinks there is a problem with the outdoor unit.
Mar 31, 2014 | Daikin Mini Split Ceiling Suspended Units
Frigidaire dryer dries for a few seconds then stops and lights blink.
Hi laylabetes - Answering your question, there isn't a way to actually CLEAN the control panel. Depending on an actual diagnose from a professional, the part would need replacing or if possible repair. However, if your model is electric, turns and there is no heat, it could possibly be a blown fuse. There are two house fuses that supply voltage to your dryer circuit in your fuse box. If one of the two is blown, the dryer may turn but will not heat. Check and replace fuse in fuse box if necessary. Please feel free to reconnect if this does not resolve your issue - Best, Chris
Jul 01, 2013 | Frigidaire Dryers
Affinity Dryer has all LED lights blink and then it stops running
Hello everclavel - Try reprogramming the dryer by flipping the household circuit breaker off or unplugging it. Wait approximately ten minutes and restart unit. If it proves to be ineffective, the dryer could possibly be experiencing a communication error with the main control board, wiring failure, or faulty door lock assembly. Connect with a certified technician to move forward accurately to assist with the repairs.
Jan 29, 2013 | Frigidaire Electric Dryer
GLEQ21512ES1 overheating fast
Hello Anne Truhlar - Try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately 30 seconds and turn on the fuse for the dryer. Turn on the dryer and select a normal cycle. If the dryer continues to overheat then I suggest contacting a professional to accurately diagnose and repair the dryer. The unit could possibly have a defective control board, power supply (240V), heating element, sensor or high limit thermostat.
Sep 30, 2012 | Frigidaire GLEQ2152ES Electric Dryer
My Frigidaire dryer FEQB4000FSO stops running and the lights blink after just a few minutes. What could be the problem?
Your dryer inside of it. The drum turns on two wheels and the drun its self has a belt around it the wheels are on each side of the drum on the bottom and have bearings in them that fail letting the drum ride on metal to metal making a scrubbing or dragging metal sound. This is what your problem is it is not an expensive fix but just make sure this is all you are charged for. Please rate my solution and leave testimonial this is how i earn my achievements Thanks in advance
Apr 22, 2012 | Frigidaire Dryers
Oct 02, 2008 | Whirlpool LER4634J Electric Dryer
Dryer stops shortly after being started
Dust has gathered around the thermostar wtich tells the machine when the cloathes are dry Remove the dust The thermostst is located inside the door on the right hand side it looks like a small nail sticking out
Feb 11, 2008 | Dryers
Dryers Logo
24 people viewed this question
Top Dryers Experts
