On USB RECORINGS IT SAYS MY AUDIO DATA IS NOT SUPPORTED THEREFORE I HAVE NO SOUND TO GO WITH THE PICTURE WHICH HAS RECORDED OK ??
Basti
  • 1447 Answers
SOURCE: Samson G-Track recording volume issue
ok thats good, when you go to device manager do you see the USB Microphone listed with no conflicts such as ?, X, !..?
Posted on Jun 04, 2008
vincent721
  • 240 Answers
SOURCE: usb audio driver won't install from original cd
Installing USB sound card (any windows)
  1. Do not connect or plug the USB sound card
  2. install the software and driver
  3. restart the computer
  4. connect the USB Sound Card
  5. windows found new hardware
  6. select find hardware automatically.
  7. if windows cant find the driver select browse CD (contain driver)
i have 3 soundcard installed in my computer (XP Pro SP2,Vista Enterprise,Ubuntu Linux) 1 built in and 2 USB.
built in I use for speaker, 1 USB I used for monitor to my DJ mixing software, 1 USB I used for telephone(VOIP)
Posted on Apr 02, 2009
  • 253 Answers
SOURCE: when i recored a video, it's faster then the audio.
you may have to many "things" going on in the backgound, Look down by the clock in the lower left of your screen, and right click and close any running programs you don't need right then. You don't need any of them for windows to run, so dont worry about closing them down, then try recording and see if thats better. then you need to disable some of those unnedded apps from starting with windows, which is a seperate solution.
Please give a good rating if this helps
Posted on Apr 11, 2009
SOURCE: I'm trying to use my
http://dl.owneriq.net/b/b15dd636-9b8d-4d78-8fd0-4bb2d82774f3.pdf
Above is your user manual, perhaps this can help?
If you are getting feedback, that's because there is too much "Coupling" between the Mic & Amp, You may need to use a Mic, with LESS drive.
Are there any Firmware upgrades?
You also need to ensure the Recording CODEC is the same as the playback CODEC, that's a must do.
Posted on Nov 30, 2010
  • 5190 Answers
SOURCE: No audio after recording from sat. Reciever
Double-check your input cables from the receiver to the LG 389. Do you have the sat. receiver AV out connected to the front AV In on the LG DRT389? Make sure that you haven't mixed up the L and R audio connections on either side. (I've done something similar with RCA cables myself.) Next, try a different set of cables.
If that doesn't work, there may be a problem with the audio jacks on either your receiver or the 389. To check, plug the AV cables from the Sat. Receiver directly into the TV. If you have sound and video, then the input jacks on the recorder may be damaged.
Try using another input. (It looks like some models have the SCART input; you may need to set the input source in the menu under AV2 Decoder.)
The fact that you have audio output on USB and DVD's means that cables/connections between the LG289 and the TV are fine.
I hope this helps. Please add a comment with the details of which AV port you are using on the LG389 for additional assistance.
Posted on Aug 31, 2012
I cannot see anything on the LCD screen or in the viewfinder. It doesnt record video but it recoreds audio
It sounds like the CCD or its circuitry has gone down. (CCD is the cell that receives the light through the lens and turns it into a picture). Only solution is a repair or buy a new camera. If it is still under warranty or very near it, take it back to the dealer, promise him you didn't drop it, and ask nicely for it to be repaired under warranty. If you are in UK, argue your consumer rights if the warranty has just expired - the consumer may reasonably expect an expensive device like a camcorder to last more than a year.
Aug 28, 2014 | Hitachi DZ-MV750MA DVD Camcorder
When i recored my vocals they are delayed so it goes over the beat instead of being on top of it and right on point
This is a common problem with recording multi-track sounds on a computer. It is caused by something that is known as 'latency' - basically it is down to the fact that the signal from your microphone takes a different route through the system to that taken by the audio playback. The AT2020 is a USB microphone and the signal therefore has to pass through the USB bus circuit of your computer. Despite claims of multi-tasking your computer cannot do everything at once so it naturally creates delays to make itself work properly. This will be more of a problem with a computer which has a 'cut-down' processor such as a Celeron (Intel) or Duron/Sempron (AMD). These processors are really only intended for basic computing (office type) use and are not really up to the high demands of video or audio recordings.
You may get some improvement by tweaking some of the audio settings for your sound-card to change the hardware acceleration.
This article may help you http://www.pcmus.com/latency.htm
If you are using a dedicated midi /music recording program such as Cubase then you may be able to correct the time lag using the 'quantise' function after recording your vocals. However the best solution is likely to be a hardware one Either buy a proper multi-track mixer/recorder designed for the purpose or get a second USB microphone - play your backing track on an external device - using one microphone to capture your voice and one to re-record the backing track (the only downside for this second option will be a gradual degrading of the sound quality each time it is re-cycled)
Jan 28, 2011 | Audio Technica Audio-Technica AT2020 -...
When i put a balank cdr the recorer says wrong
Listen to it. Go out and buy "CD-R for AUDIO" or "CD-Music" blank CD's and it will cooperate. Home CD recorders are designed to reject data CD-R media for recording.
Jan 22, 2010 | Philips CDR775 2-Disc CD Recorder
Usb audio driver won't install from original cd
Apr 02, 2009 | Crosley Traveler Turntable
I have microphone connected and I am record and there is no sound being recored.
start-control panel-sounds and audio devices-Audio tab- in sound recording click volume and check with one is check try them all tell it works
Dec 06, 2008 | Computers & Internet
Jun 04, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
Dish-vip622dvr
my reciver dont recored and dont pause and take like 12 minutes to turning on, and have a message that a have to add a usb to help organize the programing a recored, o and is to slow that a have to keep presure the channel buton for like 5 seconts to make change
May 18, 2008 | DISH Network ViP622 DVR DTV Receiver /...
Hi8 to Computer for editing
Color: Black Part No.USBG-VX3 VISTA COMPATIBLE USB Video Adapter USB 2.0 Audio/Video Grabber S-video& Composite
AUDIO AND VIDEO GRABBER FOR WINDOWS VISTA GrabBee X+ USB 2.0 Audio/Video Grabber New Generation USB2.0 Audio/Video grabber is the best ideal companion for your portable audio/video application. Real-time MPEG 1/2/4 recording make you have powerful video application on hand. GrabBeeX+ USB 2.0 A/V Grabber is the bridge between your computer and analog camera, VCR, camcorder or other video source. GrabBeeX+ USB 2.0 Video Grabber is small enough to fit in the palm of your hand and is ideal for both notebook and desktop computers. Applications : Video recording & editing Take photo Video email Security monitoring system Features : Small Wonder--Dimensions are (L)81mm x (W)30mm x (H)15mm Audio and video go though USB 2.0 bus (WinXP) to make best performance High speed USB 2.0 data transfer rate for best video recording Encoding MPEG 1 or MPEG 2 format directly use InstantMPEG Technology, Ideal formats for creating VCD or DVD movies Up to 25 fps motion capture capability at 720x576(PAL) & 30 fps at 720x480(NTSC) SnapShot function support Composite, S-Video analog input, NTSC, PAL and SECAM multi system support Recording period setup Composite, S-Video analog input, NTSC, PAL and SECAM multi system support Support Brightness, Contrast, Hue, Saturation, Sharpness control Powerful video editing function include Motion Video Special Effects/ Title Effects/ Picture-in- Picture Effects/ Slow & ast Motion Video Effects/ background music/?color background/ Transitional Effects Plug & Play Low power consumption. Ideal for portable computer too No Battery---No need to install batteries or run off the wall adapter
  • Specifications : Video input : One RCA composite, One S-Video.
  • Video system : NTSC, PAL and SECAM multi system support Audio input : in WinXP, go through USB; in Win2000, go through sound card
  • Motion capture : AVI format from 160x120 to 720x576 resolution MPG format from 320x240 to 720x576 resolution Still image capture : BMP/JPG/TIF/PCX/TGA file format
  • Performance : Up to 25 fps at 720x576 for PAL, 30fps at 720x480 for NTSC Power Source : 5VDC,300mA(max) through USB port Minimum System
  • Requirements : USB 2.0 equipped computer Pentium 4 1G or above 128MB of RAM Windows 2000/XP Sound card
  • Package Contents :
  • GrabBeeX+ USB 2.0 Audio/Video Grabber
  • GrabBeeX+ drivers CD
  • Ulead VideoStudio editing software
  • User's manual
    I have heard this works, going to try one today, I have tried EVERYTHING else, downloading drivers, diffferent programs, firewire cords, so I think this will work, when I googled our specific camcorder, this matches, also, some people are selling the exact sony camcorder on ebay with this included, stating they have used it to connect to their pc. Hope this helps.
  • May 06, 2008 | Sony Handycam CCD-TRV608 Camcorder
    Mp3 disk no audio when playing
    First, make sure the CD is an AUDIO CD, and not a DATA CD
    If you have recorded a Picture CD or MP3 CD
    yourself, ensure that your disc contains at least 10
    pictures or 5 MP3 tracks.
    MP3(ISO 9660) 96, 112, 128, 256
    kbps & variable
    bit rate fs, 32, 44.1,
    48 kHz
    – MP3 discs, picture (JPEG) files
    on CD-R(W).
    – JPEG/ISO 9660 format
    – Maximum 9 characters display.
    – Supported sampling frequencies :
    32 kHz, 44.1 kHz, 48 kHz (MPEG-1)
    16 kHz, 22.05 kHz, 24 kHz (MPEG-2)
    – Supported Bit-rates : 32~256 kbps
    (MPEG-1), 8~160 kbps (MPEG-2)
    variable bitrates
    Oct 02, 2007 | Philips DVD 622 DVD Player
    I have no sound on my sony handycam
    Sony got back to me with the answer, so I will post it here for future reference.
    If there is no audio when USB streaming with PIXELA ImageMixer version 1.5 software on the Microsoft Windows XP operating system, change the USB capture device setting for sound to USB Audio Device. In the Image Mixer Tool settings, confirm the USB Capture Device settings are set for an available USB Audio Device. This setting is not defaulted to the USB streaming mode.
    This would be the icon of an open end wrench in the top right hand corner of the capture environment screen.
    Follow this procedure to change the USB capture device setting for sound in the Pixela ImageMixer 1.5 software.
    1. In the ImageMixer window, click the USB Device Capture icon.
    2. Click the Preferences icon.
    3. In the Capturing/Recording Preferences window, in the USB Capture Device Setting section, click the down arrow to select the desired sound device.
    4. Click the OK button.
    For any request for processing or editing assistance you may visit the PIXELA help file. You may also contact them at the following website:
    www.imagemixer.com
    Jul 04, 2007 | Sony Handycam DCR-TRV265E Digital...
    Computers & Internet Logo
    98 people viewed this question
    David Payne
    David Payne
