Question about Kubota Garden
WHAT IS THE CORRECT NITROGENE CHARGE IN KUBOTA BREAKER FXB 460?
  • yadayada
    yadayada Dec 22, 2016
    What unit of measure are you after?
    Top Expert:
  • Kubota Master
  • 78,257 Answers
What is the correct nitrogene chrage in a kubota breaker FXK460?
Nitrogen charge is half of the operating pressure. That is enough to cushion the blow and protect the hydraulics.
Dec 22, 2016 | Kubota Garden
ONLINE PARTS DIAGRAM FOR KUBOTA ZD331
Go to Kubota Kpad Site. You must be running Windows Internet Explorer or the correct add-ons to access to site. Also you need to know which size deck you have.
Here the front part link.
Kubota Tractor Corporation Parts
Apr 05, 2015 | Kubota Garden
Where could I find a cylinder head for Kubota L3010HST?
Your Kubota should have it. You will need your serial number as there is three heads for this tractor.
Another option is your tractor savage yard. There you would your old head to match up the correct one.
Apr 01, 2015 | Kubota Garden
How do I replace a outside central air conditioner
First you need to determine if it is a heat pump or straight cool condenser. The reason is the low voltage wiring is different. This is the correct way to install an outside unit.
1.Pad must be level and unit should be secured to withstand 140 mile uplift wind with tie down straps.
2. Make sure breaker size does not exceed max per data sticker on unit. The electrical whip should also be correct wiring size for breaker AMPS.
3. Remove the shard er core valve to prevent damage to it, protect king valve with wet cloth or thermal trap paste to avoid damage. Connect the liquid line small cooper pipe to unit by brazing. Then run through gauges Nitrogen at low psi to prevent shoot build up in line set, now start brazing the suction line large cooper pipe, once finished help cool with water cloth.Check visually for any missed spots and re braze. Once you are comfortable that braze is a good seal now it it pressure test time.
4. (The above procedure is assuming that the inside unit has already been installed correctly, including the line set to unit.)
Through gauges connect Nitrogen compressed gas tank and increase psi in the line set to 350 psi and let stand ten minutes. If pressure is still 350 on both gauges you have a good seal, release the nitrogen into the air and remove tank from hose. Once gauges read 0 psi on both sides high and low you can start the vacuum process. These pressures can differ per refrigerant ( R410A example).
5. Hook up the Vacuum pump to the middle hose from gauges making sure you have replaced the shard er core valve back into the ports.tighten all hoses to any connection on machine, gauges, and pump open gauges and turn on pump allow to run at lest 20 minutes or until you reach 100 microns in a vacuum.Shut, close gauges and shut off pump remove the hose from pump.connect this hose to refrigerant tank and purge to center hose at gauges ( minus) amount of purge.
6. Now you can open the king valve and let refrigerant flow out of the condenser into the line set and air handler otherwise you have to add the refrigerant, newer refrigerant has to be charged into unit in the liquid state not gas state. R410A older refrigerant can be charged in gas state R22.
7. Hook up electrical,breaker off check with volt meter, follow diagram on unit. Then hook up low voltage, for straight cool depends on t-stat and unit witch colors they use follow schematics. I have found that Goodman use blue as common and yellow for cool, make sure that the same colors are used in the air handler to provide the 24 volts to outside contact coil.
If this seams difficult, well it is unless you have the correct training incorrectly done can cause damage to unit and to personal health ..
8. Or call a professional HVAC tech.
Sep 20, 2014 | Goodman Heating & Cooling
When did harley dsavidson switch . belt driven
The first Belt drive was in 1903. The modern Harley (oxymoron) introduced the Rear belt drive in the 1981 FXB Sturgis. The 82 FLH Classic was next. Then the 85 or 86 FXR. The last big twin to get the rear belt was the 86 Softail. I'm pretty sure anyways but if not someone will come along and correct me
May 04, 2014 | Computers & Internet
Need to recharge the rear shock on an 1985 XR200. need to know the nitrogen pressure
Sorry to tell you this but what your going to find is that you can not perform this yourself without the correct tools. Although the manual says you can, you can't unless you have the correct tools to charge the shock. I have just discovered this myself.
Sep 18, 2011 | 2002 Honda XR 200
I have a Pinguino PAC 190 floor model that blinks PF what does that mean?
PF- error code means shor of gas/gas leak. It's not advisable to charge gas without finding out the leak.
To find out leak, remove all gas and then charge Nitrogen pressure up-to 300 PSI and then with soap solution or leak detector element you can find the leak. Arrest the leak by brazing/welding, Again pressurize with nitrogen to confirm no more leak. And then vacumize and do gas charging.
Dec 14, 2010 | DeLonghi Heating & Cooling
Is it hard on diesel garden tractors run for short time? 45 mins-1hr? kubota gr2110 or 2100
Short runs are not hard on the unit. As long as there is oil pressure and the battery stays charged your not going to hurt it at all. Kubota diesels are very reliable.
Kelly
Feb 28, 2010 | Miller 907068 MILLER TRAILBLAZER PRO 350D...
Mispaced manual how do you change bit on kubota
Can it be there is a collar on the chuck that you slide down (back)(toward the motor) to release the catch?
Jul 10, 2009 | Hammering
How much oil do i put in the rear shok for a yz250
You can change it. Im looking for the correct amount to do it myself. I already pulled mine apart and bought a rebuild kit for it. Comes with a new nitrogen bladder, o rings for the seal, and a few other necessary items. Just remember to measure where the jam nuts holding your spring is so you can put it back in the correct location. As for the nitrogen i heard 150 psi. I'm fortunate to work at an offroad racing shop so i'm just gonna fill mine with nitrogen there, but i dont think you should get charged too much at a regular bike shop. Rockymountainatv.com has the rebuild kit. You will need the seals atleast. If i find anything else out i'll let you know. Hope this helps.
Mar 15, 2009 | 2003 Yamaha YZ 250
Garden Logo
26 people viewed this question
Top Kubota Garden Experts
Vernon Taylor
Mike Henne
Level 1 Expert
Are you a Kubota Garden Expert? Answer questions, earn points and help others
