Question about Kubota Garden
What is the correct nitrogene chrage in a kubota breaker FXK460?
    Sergeant:
  • 237 Answers
Nitrogen charge is half of the operating pressure. That is enough to cushion the blow and protect the hydraulics.
Posted on Jan 08, 2017
What do all the instrument lights stand for on my kubota rx 302 mini excavator
kubota owners manual for rx 302 mini excavator pdf - P(1 ...
www.search-document.com/.../kubota-owners-manual-for-rx-302-mini-e...
Looking for: kubota owners manual for rx 302 mini excavator ... 3.4 Flow testing, regulating & setting the excavator OEM relief valve. ... of the parts, even those ...
Manual KUBOTA RX 302 - User's Guide KUBOTA RX 302 ...
www.manuals.club/results_alpha.php?search=KUBOTA+RX+302
KUBOTA > KUBOTA > RX 302 > 10 results for : KUBOTA RX 302 ... KUBOTA - KX 008 (KX008) Mini Excavator (User's Guide in French) · KUBOTA - K008-3 Mini
Oct 27, 2015 | Garden
ONLINE PARTS DIAGRAM FOR KUBOTA ZD331
Go to Kubota Kpad Site. You must be running Windows Internet Explorer or the correct add-ons to access to site. Also you need to know which size deck you have.
Here the front part link.
Kubota Tractor Corporation Parts
Apr 05, 2015 | Kubota Garden
Where could I find a cylinder head for Kubota L3010HST?
Your Kubota should have it. You will need your serial number as there is three heads for this tractor.
Another option is your tractor savage yard. There you would your old head to match up the correct one.
Apr 01, 2015 | Kubota Garden
How do I replace a outside central air conditioner
First you need to determine if it is a heat pump or straight cool condenser. The reason is the low voltage wiring is different. This is the correct way to install an outside unit.
1.Pad must be level and unit should be secured to withstand 140 mile uplift wind with tie down straps.
2. Make sure breaker size does not exceed max per data sticker on unit. The electrical whip should also be correct wiring size for breaker AMPS.
3. Remove the shard er core valve to prevent damage to it, protect king valve with wet cloth or thermal trap paste to avoid damage. Connect the liquid line small cooper pipe to unit by brazing. Then run through gauges Nitrogen at low psi to prevent shoot build up in line set, now start brazing the suction line large cooper pipe, once finished help cool with water cloth.Check visually for any missed spots and re braze. Once you are comfortable that braze is a good seal now it it pressure test time.
4. (The above procedure is assuming that the inside unit has already been installed correctly, including the line set to unit.)
Through gauges connect Nitrogen compressed gas tank and increase psi in the line set to 350 psi and let stand ten minutes. If pressure is still 350 on both gauges you have a good seal, release the nitrogen into the air and remove tank from hose. Once gauges read 0 psi on both sides high and low you can start the vacuum process. These pressures can differ per refrigerant ( R410A example).
5. Hook up the Vacuum pump to the middle hose from gauges making sure you have replaced the shard er core valve back into the ports.tighten all hoses to any connection on machine, gauges, and pump open gauges and turn on pump allow to run at lest 20 minutes or until you reach 100 microns in a vacuum.Shut, close gauges and shut off pump remove the hose from pump.connect this hose to refrigerant tank and purge to center hose at gauges ( minus) amount of purge.
6. Now you can open the king valve and let refrigerant flow out of the condenser into the line set and air handler otherwise you have to add the refrigerant, newer refrigerant has to be charged into unit in the liquid state not gas state. R410A older refrigerant can be charged in gas state R22.
7. Hook up electrical,breaker off check with volt meter, follow diagram on unit. Then hook up low voltage, for straight cool depends on t-stat and unit witch colors they use follow schematics. I have found that Goodman use blue as common and yellow for cool, make sure that the same colors are used in the air handler to provide the 24 volts to outside contact coil.
If this seams difficult, well it is unless you have the correct training incorrectly done can cause damage to unit and to personal health ..
8. Or call a professional HVAC tech.
Sep 20, 2014 | Goodman Heating & Cooling
Do you have free manuals of Kubota mowers?
Try requesting manuals directly from Kubota.
Jul 16, 2014 | Kubota Garden
I need a down loadable manual for my kubota GL11000 diesal generator
Kubota GL11000 and Kubota GL7000 Manual http://www.pacifictoolcompany.com/index.php?main_page=index&cPath=13_127
Sep 30, 2011 | Miller 907068 MILLER TRAILBLAZER PRO 350D...
When i turn the air on it will not get cold at all, someone mention i could have a leak where the freeon goes.. what kind of problem could this be and how much is the cost of fixing it?
Hello, it could very well be a leak, if the air filter, evap coil, and airflow all seem ok then i would suspect a leak. Depending on where it leaks will depend on how much it will cost, if it is just a leaky schreader valve core then the core is just replaced and freon is added to the proper level. This would be somwere in the 100-150 dollar range. However, if it is a leak somwhere in tne lineset or in the evap coil then the leak must be repiared, a vacuum pulled on tje unit, nitrogen added, and finnally freon chraged back in, this would be closer to 400 dollar range. I hope this helps
May 18, 2011 | Heating & Cooling
How do I replenish the Freon in my Sillouette model DWC283BLS?
you legally can't unless you are e.p.a. certified to purchase the type of freon in the unit and you have the equipment to do so,by law you need to evacuate the sealed system,then pressurize system with nitrogen and a small amount of r22freon,find the leak,recapture nitrogen/r22 and repair leak,then recharge unit with correct amount of correct refrigerant it needs,the equipment to do so is very expensive too
Nov 19, 2009 | Danby Silhouette DWC512BL Wine Cooler
Mispaced manual how do you change bit on kubota
Can it be there is a collar on the chuck that you slide down (back)(toward the motor) to release the catch?
Jul 10, 2009 | Hammering
Garden Logo
90 people viewed this question
Top Kubota Garden Experts
Vernon Taylor
Mike Henne
Level 1 Expert
Are you a Kubota Garden Expert? Answer questions, earn points and help others
