New fan motor gets hot and stops after an hour have new computer
Hi have a bonair Evap cooler new computer new fan motor runs great 4 hour stops fan motor hot runs all day on boost
  • Heating & Co... Master
  • 1,923 Answers
Sounds wired wrong, possibly wrong wires on capacitor.(if there is one of course) need to have wuring schematics and make sure its wired right. Hopefully its the right motor!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Posted on Dec 24, 2016
My Bonaire evap cooler keeps tripping the fuse when I turn it on
there is an electrical short in the unit that is causing the fuse / breaker to trip
could be insulation, moisture in a junction connection or failing motor
Call in an accredited electrician to find / fix the fault
Mar 12, 2016 | Dryers
Bonair Evap Wont turn on after power failure
Hi bud do youself a favour before anything else take the main motor out and send it in to a reputable electrical repair co such as dynamic electrical in Benoni or look up a similar co near you and make sure that your system has not been hit bye lightning or a power surge from the supplier first I do own a Co that specialises in evap coolers and from previous knowledge a lot of the new systems have 12V inverters and if there has been a storm and you havnt diconnected your unit the PCs and motors are more than likely fried
Feb 17, 2014 | Mastercool 67471 Evaporative Cooler Air...
I have a problem with computer frozen, it get frozen almost every 3 hours, and make a sound like a motor, and I cannot move anything even the keyboar´s lights don{t move. I have ASUS M4A785TD-V EVO...
Sounds like its running hot, check that all fans are working and fan slotes / CPU cooler isnt clogged, You do not mention 3DFX card, ??getting hot also.
Feb 17, 2010 | ASUS M4A785TD-V EVO Motherboard
Our Bonaire Evap Cooler stopped after power failure
Turn the power of to both the heater and the cooler. Turn the power back on to the heater and the cooler at the same time then reset codes on controller.
Feb 07, 2010 | Mastercool 67471 Evaporative Cooler Air...
Fan is slow
I dont have a solution, but I have a similar problem with a Bonaire evap rooftop cooler which only started after a tech came to look at the unit when it stopped operating properly last summer. He said it uses less water now, but the issue is that it doesnt cool any where near as effectively with the fan speed so low. I am located in Melb Australia, and wonder if you are in the same area. I am going to call service AGAIN & get the minimum fan speed returned to what it was previously. I wonder if my original unit is too small for the house - but nevertheless, it used to work beautifully and now is a very poor example of evap cooling. The service guy said the base fan speed could be altered from the controller, but we dont know how to get into the setup menu.
Jan 30, 2009 | Dometic Rooftop RV Air Conditioner
Vulcan-Bonaire : summer breeze
This unit is a cooling unit only. I don't know what switch you are looking at but I don't think it's for the evap. cooler(swamp cooler). I am in the Phoenix, Arizona area and it's very common to have a evap. cooler and a seperate heat/cool system as on the hottest days the evap. cooler doesn't cool enough. I hope this helps. Please give me a positive rating. Thank you.
Jan 27, 2009 | Mastercool 67471 Evaporative Cooler Air...
Evap Cooler motor not cutting in
Look for a reset switch on the unit, press it and try again.
If there is no reset switch, unplug the unit entirely if possible, wait a minute and plug it back in.
Sometimes electronics get confused and need to start over. Let us know if that works.
Jan 12, 2009 | Mastercool 67471 Evaporative Cooler Air...
Brand new out of box and will not cool - after 12 hours - compressor is very hot ?
First question is, are there any fans that are built in that are not running? next is there may be no freon in the unit. Ive seen new stuff from the factory have no freon inside. feel the suction line (the bigger one) from the compressor. It should be cool. The discharge line (smal one) should be hot.
Dec 23, 2007 | GE PWR04FANBB Wine Cooler
Problems with my bonaire evap
air con keeps shuting down takes about an hour before its cranks back up.
Nov 11, 2007 | Heating & Cooling
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
