Question about Sharp Microwave Ovens
My sharp pro microwave drawer overheated and now it does not come on. Checked plug and ltibreaker
  • Sharp Master
  • 6,694 Answers
If you wish to get some details about microwave oven repair ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Posted on Dec 23, 2016
Will not turn on. Checked breaker and plug, microwave is getting power.
Rick,
Good possibility that you have a blown fuse. Follow the directions provided below to find the fuse.
Unplug your microwave and turn it around and remove the screws holding cover on and then remove the cover. Be very careful about touching electrical connections because there can still be some live current stored in the capacitor. Look for where the power cord goes into the back of the unit and follow the black wire from the cord to where it ends. It should stop an either a circuit board or a fuse holder. Make sure that you replace the fuse with the same amperage fuse as what you take out. You will find the amp rating stamped on one of the silver collars on each end of the fuse. Good luck!
Apr 26, 2015 | Sharp Insight Pro Black 30" Microwave...
I have a Sharp Insight Pro KB6025MS. the power is not on but it is plugged in...whatis wrong? -
have you checked your breaker to make sure it is on? If it is then check at the plug and see if you are getting power to the stove.
Jun 14, 2014 | Sharp KB6025MS Stainless Steel 1000 Watts...
Drawer tries to close and then opens
I would suspect that a foreign object may have gotten in the pathway of the drawer, the drawer actuator is out of adjustment, or one of the door sensor switch is damaged, defective, or off its mount.
The service manual is at our site here.
You can order Sharp parts from Encompass here.
Nov 02, 2012 | Sharp KB6024MW Insight Pro 24" Built-In...
MIcrowave emits an electrical smell while cooking. It still cooks, but has started emitting an odor recently when in use.
Is the smell ionized (the outside smell of a cold winter morning air) or more of an electronic component burning??? if it's more of an ionized smell it could be normal, (if the smell is strong) it could be a leaking high voltage cable (electric arching) bad insulator, if it's more of an electronic component burning smell, it could be a overheating component, in both cases you should have it checked by a professional technician...
Cheers!
Jun 25, 2011 | Sharp KB-6024MS Stainless Steel 1000 Watts...
Comes on but it wont heat up
Mine just started doing this... pushing on the left side of the drawer results in a "click", and then it will actually work. I suspect there is a switch/contact in there that is worn/malfunctioning, but am still researching it.
Dec 31, 2010 | Sharp Insight Pro Black 30" Microwave...
Sharp Insight Pro microwave drawer KB6024MS not working
The drawer often stops working when it is abruptly stopped while opening and forced closed or vice-versa. To fix, simply do the following:
1) Push the draw all the way closed
2) Push the "Setup" button repeatedly until the "Open/Close ...?" appears.
3) Hold the Start Button until the time reappears in the display.
4) Repeat steps 2 & 3 three more times
5) Unplug the Microwave for 30 minutes.
The drawer is now reset. The drawer will now open electronically (automatically) either by pushing the open button on the panel or by pulling the drawer handle slightly.
Feb 05, 2010 | Microwave Ovens
Sahrp microwave drawer doesn't automatically
It will have a one year warranty.
I would contact Sharp for their nearest authorized servicer.
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277) or visit them online.
Nov 27, 2009 | Sharp Microwave Ovens
Microwave Ovens Logo
53 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
