Question about Water Heaters
My boiler will fire up but will not stay lit any ideas?
    Top Expert:
  • Water Heaters Master
  • 80,339 Answers
Possible thermocouple issue.
Posted on Dec 22, 2016
Boiler ries to fire on heating or hot water but then shuts down after 10 seconds to F1 with the flashing red light, any ideas. clearly same principle as any boiler but I'm looking for someone who has...
that would indicate that the boiler is not firing up
If oil fired, been there done that
it is out of oil
the oil filter is clogged
the nozzle could be clogged/burned
the igniter wires need adj/replacement
if gas fired - similar issues but no experience
Dec 08, 2014 | Water Water Heaters
Wocester 37cdi condensing boiler when on low fire makes a reverberating noise that appears to come from fan/burner gas mixing assembaly whentemp arond 50 -55
Does the lit gas vary in amount of flame ? Are the gas jets clean?
Is the autovent screw opened at least 1/2 to 1 turn?
Possible resonance within the boiler casing - press and hold side & front panels to suppress the resonance frequency
Mar 14, 2010 | Water Heaters
I have a vokera unica 28 which pulses when firing
your fan may need attension fan runs after boiler shuts down is normal on some Vokera,s too clear fumes out the flue 2mins approx
Oct 04, 2009 | Water Heaters
Non i;n working boiler
Did you put automatic vent plugs on this boiler?This help stop from having air locks.I would try bleeding the high pipe to see if any air come out.The other thing I would check is the valve that out for the pump to pump water around.
Mar 17, 2009 | Water Heaters
Boiler makes twitching sound and doenst stay on
If the boiler uses oil (#2 fuel diesel); there are several factors that could cause this problem:
* Lack of oil due to clogged oil filter or restricted oil line.
* Cad resistance greater than 1500 ohms.
* Defective Primary control.
* Shoot accumulated on the retention head.
* En pinching flame in combustion chamber.
* Collapsed combustion chamber into firing range.
* There are other reason not listed here.
* Some problems require expensive testing equipment to make an accurate diagnosis.
* Get in touch with an oil burner technician with several years of experience. I have a license to practice in the state of Massachusetts. My number is 978-5443783
Mar 05, 2009 | Water Heaters
I have a gas hot water boiler that won't fire up altho the polit stays lit
check ot see if it has a safty eset on it. If it does then you can reset it and watch to see if it was just a intermittent problem or if it still locks out then you probly needd to ccall out a service company to check the uit out. Good Luck
Jan 06, 2009 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Water heater pilot light
it also sounds as though the pilot injector could be blocked so when the boiler comes on it extinguishes the pilot & then when the burner goes off boiler shuts down, or also the pilot rate maynot be set right, so when the main burner kicks in it robs the pilot of the gas it requires.
It could be that, or there is lack of ventilation for the boiler, so you get flame lift off when the boiler fires?
Dec 14, 2008 | Water Heaters
Fault light flashing 1 flash per second
Prior to writing the above fault I had asked the owner to turn the boiler temp controller , for the heating side, down just a fraction . I was phoned this morning to tell me that the boiler had stayed on allnight with no fault light . After consulting with the plumber who fitted the system it appears that there might not be a room stat ,
Nov 30, 2008 | Bosch Water Heaters
Water Heaters Logo
37 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
