Question about Food Mixers
Beater not turning - Food Mixers
Beater on Kitchen Aid stand mixer doesn't touch bottom of bowl
Why would you raise the beater if you want it to reach the bottom of the bowl? You need to lower the beater. Turn the screw in until it just touches with empty bowl on high speed then turn it counter clockwise a 1/4 turn so it will just clear.
Mar 16, 2014 | KitchenAid KSM150PS Artisan Series Stand...
The mixing section has a gap in between
Do you mean the beater is not touching the bottom of the bowl? AS in there is a gap between the beater and the bottom of the bowl so it is not mixing all the ingriedients?
If you have a Tilt-head style mixer, you can adjust the beater/bowl clearance by turning out the adjusting screw. Place your bowl on the bowl screw cap, Place the flat beater on the agitator shaft and lower the head of the mixer so the beater is at the bottom of the bowl. There should be a 1/16" clearance between the bowl and the beater, if the beater is too close to the bowl turn in the adjusting screw, and if the beater is too far away turn out the adjusting screw. The adjusting screw can be located by tilting the head of the mixer back, and in the neck of the mixer you will see a flat head adjusting screw.
However if you have a bowl lift mixer and the bowl is too far from the mixer there are a few different way to fix that problem. If the bowl and beater are too far apart start by adjusting the adjustment screw. On this mixer the adjustment screw is under the head. Remove the bowl, and beater and lay the mixer on its back. You should be able to see under the head a screw sticking out, it does not have a head, but a little slot in the screw, use a flat head screw and adjust the beat 1/4 turn. Put the beater and bowl back on and test mixer to see if it the beater has a 1/16" clearance. If it doesn't adjust the screw and 1/4 turn. If after adjusting the screw the beater and bowl still have too much clearance use a mallet and tap both sides of the yoke arm up evenly until 1/16" beater to bowl clearance is met.
You can use the same dime test in the bowl to make sure you have the correct 1/16" measurement for the beater/bowl distance.
Thank you,
Colleen
MendingShed.com
800-339-9297
Apr 30, 2013 | KitchenAid Food Mixers
One of my blades is stuck and I can't engage the release
Make sure your Beater can slip in and out of the Beater Shaft
easily. Do not force the beater onto the Shaft if the shaft is bent.
If it cannot be removed easily by hand, use a soft rubber mallet
(not a steel hammer) to slightly tap the beater so it can be moved
up and down the shaft or from side to side. Then you can easily
turn the beater left and remove it from the shaft.
From Kitchenaid Manual:
To Attach Flat Beater, Wire Whip, or Dough Hook
1. Turn speed control to OFF.
2. Unplug stand mixer or disconnect power.
3. Tilt motor head back.
4. Slip beater onto beater shaft and press upward
as far as possible.
5. Turn beater to right, hooking beater over pin on shaft.
6. Plug into a grounded 3 prong outlet.
To Remove Flat Beater, Wire Whip or Dough Hook
4. Press beater upward as far as possible and turn left.
5. Pull beater from beater shaft
Jul 19, 2011 | KitchenAid KSM150PS Artisan Series Stand...
First time using bread dough beater It was hard to put on and am unable to remove
as far as possible.
5. Pull beater from beater shaft.
Jul 17, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Bread dough beater will not come off
as far as possible.
Can you lengthen the beater by loosing a screw?
Hi, KLOEHR, your beater will not lengthen by losing a screw. However, if you lost your Beater to Bowl Clearance adjustment screw, then it might appear that your beater had ‘grown’ because now the beater may be touching the bottom of your mixing bowl, where previously it had not. Simply said, the beater didn’t grow the mixer head drooped.
You don’t say if you have a ‘tilt-head’ or a ‘bowl-lift' mixer, but you can easily download a PDF version of your Owners Manual from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number (in your case, use KSM5PS)and select the last file listed that appear under Owners Manuals: KSM5PSWW0.pdf (2930.74 KB) and save that file to your PC. You’ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the mixer head height. I have extracted the instructions below:
Your mixer is adjusted at the factory so that the flat beater just clears the bottom of the bowl. If for any reason, the flat beater hits the bottom of the bowl or is too far away from the bowl, clearance.
Tilt-Head models
• Unplug mixer.
• Lift motor head.
• Turn screw (A) SLIGHTLY counter clockwise (left) to raise flat beater or clockwise (right) to lower flat beater.
• Make adjustment with flat beater, so it just clears surface of bowl.
If you over adjust the screw, the bowl lock lever may not lock into place.
Bowl-Lift models
• Unplug mixer.
• Place bowl lift handle in down position.
• Turn screw (B) SLIGHTLY counter clockwise (left) to raise flat beater and clockwise (right) to lower flat beater.
•Make adjustments with flat beater, so it just clears surface of bowl.
If you find the adjustment screw missing, you’ll need to replace it. But now you’ll need
I hope this helps! –Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Dec 10, 2009 | KitchenAid KSM5PS Heavy Duty Stand Mixer
I cannot get the beater to lock in place. The
Hi VBPROSANDY, When you say beater, I assume you mean your flat beater. Are you having the same problem with your Wire Whip beater and dough hook? If you are not, then the first thing I’d do is look inside the flat beater’s attachment well, to see that there is nothing; i.e. hardened food, dough or batter, in the bottom of it that would prevent the agitator shaft and groove pin from seating properly. The flat beater has two drain holes at the bottom for drainage, but if these get plugged it may prevent accumulated ‘gunk’ at the bottom from escaping, and over time the buildup may prevent the beater from seating properly.
If you find the beater attachment well is clean, then from the KA Instruction manual, to attach the flat beater...
1. Slide speed control to OFF and unplug.
2. Slip flat beater on beater shaft.
3. Turn beater to left, hooking beater over the pin on shaft.
Finally, check the groove pin on the agitator shaft to make sure it hasn’t become bent so that it doesn’t fit the beater properly. Pins shouldn’t bend, but sometimes they do.
The beater attachment process should not require any effort as the agitator shaft should easily fit into the beater’s attachment well and easily turn to the left. Your planetary should not move during this process and if it does move it will take some effort on your part to turn it. The fact that you’re turning the planetary means you’ve turned the beater as far to the left as it should go to ‘lock’ it. When you get this far, let go and the beater should fall into place on the groove pin.
Good luck. I hope this helps. Howard, Burke, VA
If this solution has been helpful, please rate it, thanks! - hslincoln
Dec 06, 2009 | KitchenAid KP2671 Professional 6 Series...
New Kenwood chef km 001 - I can't get the beaters out!
Try turning the beater in the reverse direction to the direction it normally turns - clockwise looking at the beater (I think), this should make the shaft pins ride up on some cams which should release the beater.
Sep 23, 2008 | Kenwood KM800 Major Classic Stand Mixer
Beaters don't turn
You should try to replace the beater turners or try to fix the problem that causes the beater turners not to work.
May 01, 2008 | Sunbeam Heritage 2346 Stand Mixer
Sunbeam hand mixer. One beater not working
That spring does not turn the beaters. It is part of the beater release assembly. Probably one of the gears is worn.
Nov 12, 2006 | Sunbeam 2485 MixMaster Series Hand Mixer
Food Mixers Logo
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
