Question about Building Materials
I am trying to reprogram my clicker klik2u-up garage door remote. I am holding *and # keys down and remote light flashing fast and won't stop. When I stop and hold again it flashes slower then stops
  • 247 Answers
SOURCE: OLDER SEARS GARAGE DOOR OPENER WONT OPEN GREEN LIGHT FLASHING
do you have the sensors at the bottom of the door? if so they might be out of alignment. all you have to do line them up by getting the green light solid. let me know if this helps you.
Posted on Dec 18, 2008
rulds2008
  • 3866 Answers
SOURCE: Problem with Sears Garage Door Opener
The motors is cought on something check the motor if it moves inches it will move a yard the question is the motor is it getting power? if so is it stuck on its own drive chain? Check these things you be glad you did.
Posted on May 25, 2009
tlm931
  • 273 Answers
SOURCE: My garage door won't close unless I hold the main button down
your garage door has saftey sensors at the door
these are photo eyes
in the owners manuel that came with the opener
that has pictures in it which would help
the photo eyes need to be clear of debri and aimed at each other with no obstruction
there are leds on each sensor and when aimes properly they should be light if i remember correctly
if you can not get them to light then you may have to replace the sensors
Posted on Oct 27, 2009
  • 3197 Answers
SOURCE: garage door opens a few inches and stops
On the rear of the motor unit near where all those white wires go you will find the 'up force'. Increase this 1/4 turn and try.
Posted on Dec 07, 2009
swolfinor
  • 504 Answers
SOURCE: Craftsman Garage Door Opener Can't Use Multiple Remotes!
THE UNIT CAN WORK WITH EITHER ROLLING CODE OR NON ROLLING CODE, NOT BOTH.
I WOULD GUESS THE CLICKER IS NOT ROLLING CODE.
I HAVE NEVER HAD GOOD LUCK WITH THE CLICKER REMOTES - GO AND GET ANOTHER REAL REMOTE - THE SAME SERIES AS THE ORIGIONAL.
GET A REFUND ON THE CLICKER - OR HAVE IT BRONZED FOR THE MANTEL.
HOPE THIS HELPS
Posted on May 24, 2010
How do i pair a clicker model klik2u key pad to a overhead door model 455 opener
http://chamberlain.custhelp.com/app/answers/detail/a_id/2578/~/clicker-model-klik2u-wireless-keyless-entry-owners-manual
Jan 19, 2015 | Building Materials
How do I check a wireless garage door keypad, to see if it is transmitting?
These remotes don't loose the programming code when a battery goes dead, most likely the remote or the board on the opener went bad, do any other remotes work? You can take the remote to an auto parts store and test it there. (They have a tester for key fobs)
Sep 24, 2014 | Sears Craftsman LiftMaster Chamberlain...
Clicker klik2u stopped working
You may need to repeat the programming procedures in the manual to make the remote work again. Sometimes if the battery dies, they lose their programming. I've encountered this before. What brand of garage door opener do you have? There may be a better remote control for you than the universal remotes like your Clicker.
Sep 17, 2013 | Building Materials
Tried to reprogram security code for outdoor key pad on 1/2hp craftsman garage door opener according to instructions online, pressed learn button- put in new 4 digit code-held enter. Lights did not flash...
Seems you've done everything right. Press and immediately release the smart/learn button and then walk over and key in a 4 digit code and press enter. If you are sure the battery in the keypad is good then I think your keypad is on the fritz or the wrong one for that opener.
Apr 19, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a clicker model KLIK2U and forgot the code. How do I reprogram without the old code?
It's really easy to reprogram your unit:
Step 1. Hold down the (*) and the (#) keys until the keypad stops flashing.
Step 2. Determine your opener ID using the list below:
*1= linear garage door openers manufactured from 1997 to
present.
*2= Chamberlin, Sears, Craftsman, LiftMaster, Master
Mechanic and Do it garage door openers manufactured from
1997 to 2004 ( Orange learn Button)
*3= Same as *2 above, but manufactured from 2005 to present
with a (Purple learn Button)
*4= Same as *2 above, but manufactured from 1993 to 1996
with a (Green learn Button)
*5= Genie Intellicode and Overhead Door garage door openers
manufactured from 2005 to present (315 MHz).
*6= Same as *5 above but manufactured from 1995 to present
(390 MHz).
*7= Stanley garage door openers manufactured in 1998 to
present.
*9= Wayne Dalton garage door openers manufactured
in 1999 to present.
Openers with learn Buttons
Programming: Enter the PIN that you want to use, remember
(4) digits only. then press #
Enter ID # from list above, for example 2 then #
Press and release the Learn button on your
garage door opener.
Enter your (4) digit PIN and press (0),
for Genie and Overhead door units press
(0) twice. To test and use wait for light to go out
on keypad, Enter you PIN and press (0).
Note: If opener doesn't function repeat programming.
Instructions if required.
Sep 17, 2010 | Universal Garage Wireless Keyless Entry...
I need KLIK2 remote instructions
How do I connect KLIK2 to a linear with a learn button
Feb 17, 2010 | Universal Garage Wireless Keyless Entry...
Building Materials Logo
49 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
