The water doesn't come out cold - Washing Machines
How to move around brandt wm 550
see this causes and fix it. God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Sep 22, 2012 | Washing Machines
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
Aug 01, 2012 | Washing Machines
Cold water barely goes in washer but the hot goes in full speed
take off the cold water hose and put it in a bucket to see if the water flows into the machine
if it doesn't replace the hose
if it does replace the hose on the other end
Nov 06, 2011 | Washing Machines
I have two problems with the Kenmore Ultra side-by-side refrigerator I inherited with my new house. 1) Water and Ice Dispenser do not dispense. Ice is being made but doesn't come out and water...
check the switches inside the panel where water and ice come out. that front panel comes off. this happened to me those switches are mounted on plastic mine broke and I used zip ties to put them back in place. The switches were just dangling there.
Aug 04, 2011 | Kenmore 53642 / 53644 Side by Side...
I have recently installed a washer in my shop. Only the cold water hose is hooked up since I only have cold water in the shop. I ran the first load and as it filled water is spraying out of the hot water...
First check that you have selected a cold water only cycle. Otherwise the cold water will backfeed through the hot water inlet. If that doesn't help or isn't possible, I suggest you buy a blank cap to screw over the hot water inlet. You should be able to get one from any plumbing store. Hope that helps.
Jul 06, 2011 | Washing Machines
Hot water pours out, cold water trickles. This just started happening this week. Is there a pump that forces the water to move or is the problem more likely the hose is plugged? or is there another...
The dual water inlet valve cold side is just stopped up with sediment. There is a screen filter in the water hose where it connects to the water supply. Cut the water off and unscrew the hose and look in the end of it for the cone shaped filter and clean it out. If that doesn't fix the problem you may have to clean or replace the inlet valve which is at the other end of the hose. The hot water doesn't usually have a problem because any sediment has a chance to settle out in the hot water tank.
Jun 10, 2011 | Kenmore Washing Machines
Fills water & stop
I had the same situation but it is now fixed. Be sure your hot and cold water are both turned on, even if you use the COLD / COLD . My washer kept stopping in mid stream.Haven't had a problem in a month
Jan 29, 2009 | Frigidaire FTF530FS Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
