Question about Lands Phones
What does 1471R mean on land line?
My partner is cheating and I went to redial and 1471R came up so I pressed 3 to be connected and it didn't recognise number
When i call to my partner that time one ring after that automatically call disconnect
It sounds like your partner is "tripping the ring"
If this is a land line frequently this means a wet or corroded connection somewhere along the line. Try disconnecting everything at the side of the house and call it. If the problem persists call the phone company as it is on their side of the line. If not then you need to shoot the trouble in the house wiring.
Good Luck
Oct 19, 2015 | Lands Phones
How to fax?
This section describes dialing and sending faxes directly using the Numeric buttons.
note:
  • A PBX (Private Branch Exchange) is an on-site telephone switchboard. If your machine is connected through a PBX or other telephone switching systems, you have to dial the outside line access number first, and then the number of the party you are calling.
Sending a Fax with the Numeric Buttons .
Click here for other useful sending methods.
1. Preparing for sending a fax.(1) Make sure that the power is turned on.
(2) Load a document on the Platen Glass or in the ADF.
important:
  • When sending a double-sided document, set the document on the Platen Glass. You cannot scan double-sided documents from the ADF.
(3) Press the FAX button.
The fax standby screen will appear.
(4) Adjust the density (scan contrast) or image quality (fax resolution) as necessary.
See "Adjusting the Sending Quality"
2. Sending the fax.
  • When the document was loaded on the Platen Glass:
(1) Use the Numeric buttons to dial the recipient's number.
(2) Press the Color button for color sending, or the Black button for black & white sending.
important:
  • Color sending requires that the recipient's fax machine supports color faxing.
(3) Press the OK button.
The machine starts sending the fax.
note: When loading two or more documents
  • Load the next page, and press the same button as you pressed in (2) of step 2. Repeat the same procedure to scan all pages of the document, and press the OK button.
  • When you have sent the first page with the Black button, the following pages will be sent in black and white.
When the document was loaded in the ADF:
The machine scans the document automatically and starts sending the fax.
important:
note:
  • To cancel sending a fax, press the Stop button, and follow the instructions on the LCD.
  • If documents remain in the ADF after pressing the Stop button during scanning, "Close the feeder cover [OK]Eject the document" will appear on the LCD. Press the OK button so that the remaining document is automatically fed out.
Automatic redialing
  • When sending a fax and the recipient's line is busy, the machine will redial the number after a specified interval. Auto redial is enabled by default. Auto redial can be enabled or disabled by selecting ON or OFF. Select ON to specify the number of redialing in Redial times and redialing interval in Redial interval.
Redialing the Number Dialed with the Numeric Buttons
1.Prepare for sending a fax.
(4) Adjust the image density (scan contrast) or quality (fax resolution) as necessary.
2. Select the telephone number recently dialed.
(1) Press the Redial/Pause button.
Most recently dialed fax number using the Numeric buttons will appear.
(2) Use the g0016984.png (-) or g0008875.png (+) button to select the number to redial.
The selected number will appear in the fax standby screen.
3. Send the fax.
important:
Jun 03, 2011 | Canon PIXMA MX340 Wireless Office...
We have the Avaya Partner phone at work and no one can figure out how to silence the ringer. I can get the volume down but not off.
Changing ringing on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Central telephone Programming.
Enter in the extension number that you want to program.
Press the line that you want to ring.
A solid light on the line means immediate ringing
A slow flashing light means delayed ringing (meaning the phone will wait 3 rings before starting to ring.)
A fast flashing light means no ringing..
Press feature "00" to logout
Sep 22, 2010 | Avaya 700340193 Corded Phone
Code for programming recall button and redial buttom, please
Program feature 03 call waiting for recall.
Feature 05 for LNR. Redial.
Feature 00 press an unused button if it has something assigned to it press the mic button and press the button again to assign the code. Or just remember the code and use it. The feature button is just that when you use up buttons.
Apr 05, 2010 | Avaya Partner 18 Eurostyle 18D telephone
How do you use the Redial function?
Redial in ITR-8D-3 IP Phone
Press key to activate redial feature. Press redial and scroll back through
numbers that have been dialled. Until the desired number is displayed. Press the * key to activate dialing
Nov 05, 2009 | NEC ITR-8D-3 IP Phone
Ring options
Press the right hand intercom once. The display should say Centralized Programming.
When finished with that station press the right hand intercom and enter in the next extension to program and set ringing accordingly.
Sep 26, 2009 | Lucent PARTNER18 Corded Phone
Toshiba DKT2010-sd ringing in ear while on a call
1) To stop the ringing in your ear, press Redial and Vol Down at the same time
The following must be performed from station 10 or 200.
2) To change date : Press INTCM, #, 6, 5, 1, Enter date YY/MM/DD, press redial
3) To change time : Press INTCM, #, 6, 5, 2, Enter time HH/MM/SS in 24 Hr Format, press redial
4) To change day of week : Press INTCM, #, 6, 5, 3, Enter day (1=Sun, 2=Mon...), press redial
For more information regarding your Toshiba DKT 2010 Phone and the system that you're using, feel free to browse our extensive guides and manuals that you can find here
Or you can call me at 1-800-903-9190
May 05, 2009 | Toshiba DKT2010SD Phone
Line ringing on different phones
Im guessing by Lucent 308 you mean Lucent Partner ACS. Changing ringing on a Partner system is done on either ext 10 or 11.
Hope that helps
Jan 28, 2009 | Lands Phones
Redial
With the handset down, press Feature # 3, then press the key you wish to make a redial button, press CHG, press FEAT, press F8, press save. Now it's a redial button.
Jan 12, 2009 | Comdial 8324S-PT Corded Phone
Phone ringing.
On extension 10 or 11 press Feature 00
Left intercom, left intercom, right intercom
Enter your extension number
Press line buttons until its a fast blink and display say no ring
Feature 00
only transfered calls will ring
Nov 21, 2008 | AT&T Partner 18 Phone (315805B)
Lands Phones Logo
32 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
