Question about Winter Sports
How do i fix my 2010 bearcat 570 xt 2- stroke. bearcat runs fine for awhile than starts bogging down when i use throttle ?
  • 3 Answers
SOURCE: poor idle and bogs down when more throttle is given
coil pack
Posted on Mar 23, 2009
joecool1888
SOURCE: car bogs with full throttle
Its the Fuel Filter...mine did the same thing :)
Posted on Apr 26, 2009
ollie reece
  • 1167 Answers
SOURCE: Carburetor issue
make sure the oil level is correct also on carb is a screw fiddle with this mixture screw and get back to me if it made no difference i will send a pic in a while
Posted on Oct 06, 2009
Jim1969pa3
  • 152 Answers
SOURCE: Not running at full throttle
close to the carb you will find two tiny screws. They are labeled H and L. L sets the idle speed. H sets the max RPM. Hold the throttle wide open and turn the H screw. When you find the very top end, back it down some or it will be running too lean. That would make it run hot, and provides less lubrication. Could result in engine failure if you run it too lean.
Posted on Dec 23, 2009
kel1guy2002
  • 3740 Answers
SOURCE: polaris 2 stroke jetski bogs down if more than 1/4
This is typical fuel starvation.
Possible causes:
1. Clogged Fuel filter
2. Dirty fuel tank fuel pick up screen or tank outlet hole
3. Cracked fuel line
4. Fuel mainfold screen clogged on the side of the carb. Plastic screen is inside of the manifold where the mounting bolt is
5. Pinched fuel line
One other thing it can be is a severely clogged clogged air filter. Usually if the air filter is clogged the plugs will foul often and fuel consumption will be high with low engine power.
Thanks for using FixYa.
Kelly
Posted on May 04, 2010
My 2 stroke weed eater starts, runs full throttle for 20 seconds then bogs down. Im no mechanic. Please help!
Stuck throttle. See if you can check that the speed control is moving the thing on the end of it called a carburettor. Could also be an air leak in the thing that join the carburettor to the motor. called the inlet manifold.
If all else fails, just take it to a garden machine repair shop.
May 23, 2016 | Garden
Starts and idles fine runs half throttle when fuel is applied
Harry, dirty carb or injectors.
Check the attached links,Manuals and guides, Good luck with your Bike
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
ATV TROUBLESHOOTING AND MAINTENANCE
ATV Service and Repair Manuals
http://www.carlsalter.com/motorcycle-manuals.asp
Jan 06, 2016 | ATVs
97 Nissan Sentra runs fine for about 2 miles then starts losing power and dies wont start back up for about an hour
Check Engine Light/Loss of Power Due to Throttle Body Unit ...
repairpal.com > Problems > Nissan > Sentra
The electronic throttle actuator (throttle body) can fail causing a loss of power ... start it studders like it is running on 2 cyl. then switches to 3 cyl. then to 4. but ... Throttle body replaced on my 2006 Nissan Sentra 1.8 engine. ... I Was going up a hill and I tried to speed up, all of a sudden my car bogs down and completely dies.
Nov 17, 2015 | Nissan Cars & Trucks
Chain Saws
Turn adjusting screws in all the way "gently" until they seat. Not too hard or you will damage them. Turn out 1 1/4 turns on both will get you in the ballpark to start it up. If it starts, let it warm up without going to wide open throttle for an extended period. As it is idling, turn low speed screw in until it starts to want to die down, then turn back out a little at a time until it starts to bog down, then turn it back in to the center of the two bogs (at the highest point of RPM). Throttle it from idle to WOT and it should be a steady rise in acceleration without bogging down. If it does bog on acceleration, turn the Low speed screw counterclockwise 1/8 turn at a time until bog goes away. For the high speed it is critical that you don't lean it out too far. Hold the throttle at wide open and turn the screw counterclockwise until it appears to run really rich. (Blurbs like a four stroke). Then turn the screw back in while holding WOT (wide open throttle) until you get a smooth sound with a bit of blurb every couple of seconds. Hard to explain in type rather than showing it in person, but it will get you in the right direction. I'm wondering why you are trying to adjust the carb in the first place...... If there is an issue that makes you think an adjustment will fix it, try the method above. If the adjustments don't work, or you have to adjust them A LOT, you may be in the realm of a carburetor rebuild. Be sure to check the fuel line, fuel filter, and depending on what model saw you have, the carburetor boot for splits or cracks.
Sep 21, 2012 | Homelite Garden
Having problems with my 1998 suzuki RM 125
The plug you need is an NGK R6918B-9. they aren't cheap. I would think this may be the problem. 2 strokes rely on the correct bits to keep them running smoothly. Spark plugs are more important on 2 strokes than 4 strokes due to the oil in the fuel/air mixture.
Jul 21, 2012 | Motorcycles
2003 yz 250 starts and idles but runs rich and bogs as soon as the throttle is applied
Hi, Anonymous and the usual suspects are:
1. Throttle cables misaligned or misrouted.
2. Damaged or restricted fuel tank venting system.
3. Intake system air leak.
4. Vacuum piston malfunction.
5. Accelerator pump leaking or no output.
6. Plugged bowl vent or overflow.
7. Fuel level in bowl too low.
8. Restricted fuel supply passages.
9. Plugged jets or passages.
10. Worn or damaged needle or needle jet.
11. The enrichner valve not seated or leaking.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
2002 yz250 idles fine but bogs and tries to die when twisting the throttle...
Bike dies when you give it throttle
YAMAHA YZ250 LC Owner Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Mar 19, 2012 | 2003 Yamaha YZ 250
My poulan wild thing 2375 bogs out when throttle
Make sure that the air cleaner and muffler are not plugged. Check the carburetor screws and nuts for tightness. After turning both needles CW to stops (lightly), back them out CCW 1-1/2 turns each. Start the engine and allow to warm up. Open the throttle and adjust the H needle CW somewhat until the engine speeds up, but is 4-stroking. Correct adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. Release the throttle and adjust L CW till the engine runs fairly smoothly, but allows the engine to 'follow the throttle'. Set the idle speed screw so that the chain doesn't turn, but the engine keeps running. Hope this helps!
Apr 15, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Starts fine, but will not accelerate: Homelite UT-10798R
Do you have the H and L adjuster screws on the carb? If so, then normally I'd back out a little bit on the L (low speed side of carb) The instructions for adjusting carbs, years ago, on 2-stroke, say to back out on the L when motor will not rapidly rev up. Most 2-stroke carbs have these 2-jets. The L is for gas to pass to motor with butterfly throttle plate closed. When opening throttle plate, there is a sudden rush of air, at first, and this L adjustment is allowing enough gas to pass for motor to begin to rev. up. Then the gas will also flow through another small port H, usually a small brass tube in the venture area (smallest diameter section of carb). You adjust the H with the throttle wide open, motor revved up. Turn either in or out slightly till highest RPMS reached, motor smooth and fast, then turn H out about 1/4 turn. The idea is to run motor slightly rich for highest HP when under load (cutting). Hope this helps
Nov 18, 2008 | Garden
Winter Sports Logo
140 people viewed this question
Top Winter Sports Experts
Arnie Burke
Arnie Burke
vtrktrmn
Are you a Winter Sport Expert? Answer questions, earn points and help others
