What is the TV code for 55 Curve
I need to pair up with Dish
What is the pairing code for Toshiba TV with dish remote
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. SEARCH WITH THE SEARCH TAB FOR "DISH SETUP CODE"
http://electro-medical.blogspot.com/
Nov 03, 2015 | Toshiba Televison & Video
I need to pair my dish remote to my Sharp tv
Procedure to pair is too much to type in here, and is not practical. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Feb 17, 2014 | Sony Nsgmr1 Remote Control
Remote code for Vizio E552VLE
This incompatibility issue is a frequent problem.
Jan 24, 2014 | Vizio VF550M 55 in. LCD HDTV
How do i find pairing code for samsung un55d7000 series?
Unless it has changed, the default pairing code is '0000'
Sep 28, 2013 | Samsung UN55D7000 55 in. 3D LCD TV
Bury car kit for 9320 pairing code
the pairing code is written in ur car guide. if there is no code there then when pairing u can put any number and write it on ur device to complete the pairing.
(some cars have their pairing codes in their guides so check it)
good luck
Feb 17, 2013 | Research In Motion BlackBerry Curve 9320 -...
How to pair my bb curve to uniden BT112 bkuetooth
tell the person with bt112 bluetooth to pair with you.. their will be a thing that pops up on your phone that says enter pair code just put 1234
Jun 26, 2012 | Blackberry Curve 8350i
How do I enter the dish network code to hook it up to my tv?
Try this link it will give you programming codes and instructions.
http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/Remote_Codes_Web_Page.pdf
Daniel Busa
DISH Network Customer Service
Nov 30, 2010 | Mitsubishi WS-55809 55" Rear Projection...
What are the codes for Vizio On Dish network?
Hello!!! I hope that this has been resolved for you, but for future use, and any other questions that you might have, here are some steps that you can go through to get that remote programmed to your tv. Just follow the link below, where you will have steps for a power scan, which will scan through each code on your tv until you find one that works with the remote. Hope this helps.
http://www.dishnetwork.com/SupportSection/power-scan-instructions
Becki Barned
Jul 06, 2010 | Vizio VF550M 55 in. LCD HDTV
I have a Blackberry Curve 8320. I purchased a Motorola Universal Bluetooth Headset H620 that is supposed to be Blackberry compatable. I am unable to get my phone and bluetooth paired. What do I need to...
It may be the pairing code that you are using. Usually it is 123, 0000, 1111, 1234, or some other variation.
Make sure, also, that you are in pairing mode with the headset. If you can scan via bluetooth and detect the device, then it should be ready to pair.
Nov 02, 2009 | AT&T Blackberry Curve 8300 Smartphone
Blackberry curve won't pair with my bluetooth headset
Try the following. Hope this helps.
Okay,
1. Go into "Media" on your BlackBerry and enable incoming files (Menu-->Receive using bluetooth).
2. Find the file on your friend's device that you wish to send, and beam the said file accordingly.
2a. If you have not "paired" (created a friendship between) the two devices before, you will need to do this first...
2b. One of the devices will ask for a PIN code first and on this device you need to create a four-digit, numeric password that can be anything you like.
2c. On the second device, enter the four-digit, numeric password you created and follow the simple, on-screen prompts on both devices to complete the pairing (you can also pair the devices in advance by going into Menu-->Set Up Bluetooth).
2d. Depending on the devices being used and the time taken to complete the pairing, you may need to re-send the file (go back to step 1), otherwise, continue below...
3. When your friend's device tries to send you the file, your BlackBerry should ask you to name the file and where to save it; if you have not set the device as "trusted" in the bluetooth settings (Options-->Bluetooth-->your friend's device), you may need to approve the file transfer first though.
4. The file should now be on your device.
Note: by default, all
* Pictures are saved into /Device Memory/home/user/pictures or /Media Card/BlackBerry/pictures if you have a memory card.
* Sounds (including songs) are saved into /Device Memory/home/user/ringtones/ or /Media Card/BlackBerry/ringtones/ if you have a memory card.
* Videos are saved /Device Memory/home/user/videos or /Media Card/BlackBerry/videos if you have a memory card.
In other words, unless you specify somewhere else in step 3, this is where you will find your file.
And remember, your incoming file transfer WILL NOT WORK UNLESS YOU FIRST "PAIR" (CREATE A FRIENDSHIP BETWEEN) THE DEVICES, go into Media and CLICK MENU-->RECEIVE USING BLUETOOTH!!!
Jan 28, 2009 | RIM BlackBerry Curve 8310 Smartphone
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Electro Med Services...
