Question about Cell Phones
My cable you plug into wall nolonger works haven't had it but a month
Please help
CAn nolonger watch videos from the Nova Site via PBS.org
maybe you need to update Flash Player...or the drivers in your PC..
Apr 01, 2013 | HP Pavilion Computers & Internet
Soniq qsl322tv5 flat screen tv says
Hi, Unplug the TV for 1 hour and try again. The TV will reset to default. Good luck
Dec 26, 2011 | Televison & Video
Tv2 remote not working tv1 must be on
It sounds like the RCA cable is plugged into TV 2 ports on the back of the receiver.
Depending upon your receiver, towards the center on the back of the receiver, you have 3 rows of colored (2 - Red, White, and Yellow; 1 - Green, Blue, Red). The RCA for TV 1 should go in the middle row. Please let me know if you have further problems. Thanks.
Dec 16, 2011 | DISH Network IR Remote Control
Hai, I have purchase one hard disk320gb , online on month of july-2010. that time it worked only two or thre times....currently it couldnot work. when i plug it show the lite...but it couldnot...
Please check if all the cables are plugged in properly and also make sure that when you press the power button the cpu fan is running or not, if the cpu fan is running please check if you are getting any kind of display or logo of the manufacturer. If the fan is not running please check the power cable and the wall outlet, if the wall outlet is ok then the cpu fan has gone bad.
If the cpu fan is running then try reseating the memory( ram ) or changing the slots of the memory( ram ). If you need further assistance and you are technically savvy to some extent i can let you know how to troubleshoot the power supply damage and other related issues.
Hope it helps
Thanks and Regards
Anand Sachan
Oct 28, 2010 | Computers & Internet
Phones stopped working. They only read
I'm not familar with the Vtech but I would suspect that all 4 units work off of the answering machine base. It sounds like it is seeing a dial tone.
Take a working phones like the wall phone, if it is easily removed, and use a known good connecting cable between the good wall phone and the jack that the Vtech is plugged into.
If that works, take the connecting cable loose and replace it with the Vtech connecting cable. If that works check the jack on the Vtech for crossed wire. If non found, connect it to the jack the wall phone was plugged into. If this doesn't provide satisfaction, let me know exactly what you did and what happened and we will go from there.
May 28, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
One flashing light not the whole ring
Make sure that all the cables are plugged in nice and tight so that none of them are loose then turn your console back on and it should work
Jan 25, 2009 | Microsoft Xbox 360 Console
Unable to connect handset on brother mfc-885cw
Plug a regular phone into the wall jack and listen for a dial tone.
Oct 16, 2008 | Office Equipment & Supplies
Cell Phones Logo
18 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
