Question about Furniture
Edgestar CWB1760FD beverage/wine cooler combo. New scratch & dent. Left side is cooling but right side isn't. Internal fans work. Have replaced the control and the main circuit board. E6 error code.
  • 90 Answers
SOURCE: fan not working
Does it have a compressor and does it run? If so there is probably a relay on that board that is bad or only runs with the compressor.
Posted on Feb 16, 2008
jumptrout51
  • 3361 Answers
SOURCE: I have a GE Monogram Wine cooler model ZDB24AABB cooling fan
No switch. Fan motor going bad and must be replaced.
Posted on Feb 21, 2009
SOURCE: AVANTI WCR683DZD WINE CHILLER - E4 ERROR CODE
I have the same E4 problem. You can order the PCB from Avanti at Miami Florida or your regional Avanti service rep.
Posted on Dec 16, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Electricity works, unit doesn't cool.
Hi and welcome to FixYa. I am Kelly.
This is a 6 or 8 bottle free-standing wine cooler from what I can tell.
I am not having much luck determining if this is a manual defrost type unit or not. Given the inital sales price now of $79.95 I have to assume it is a manual defrost type.
There are a few things that can cause your problem.
1. PTC relay and KliXon thermal overload assy on the compressor.
2. Run capacitor
3. Temp control
You said the fan does not run so I cab not rule out the temp control.
I can not even find a parts break down of the unit.
With no fan running the very first suspect is the temp control but you can at least listen for a CLICK when you cycle it from off to any other position. If you hear a click I would start looking at compressor start / run parts.
If you have access to your units compressor note the manufacturer, hp if stated (1/8hp etc) and Model number.
Then call or visit your local appliance parts supply store with that information in hand. The will have a PTC relay / KilXon thermal overload AND run capacitor that will fit your unit. I am pretty sure that will get you going again UNLESS you have a broken wire somewhere.
The replacement parts are going to run about 50% of the cost to replace the whole thing.
Thanks for using FixYa!
Kelly
Posted on Feb 19, 2010
SOURCE: Both zones of the wine
Check the thermostat for temperature setting. Also check the condenser coils and clean them if found clogged with dust. Unplug the wine cooler and wait for a couple of hours before plugging it again. If you can hear it running or whining, perhaps the compressor is being overheated. Test various components such as temperature control knob, evaporator fan, defrost timer, compressor relay, overload protector and the compressor motor.
Take care.
Posted on Oct 22, 2010
My dual zone wine cooler stopped cooling. Power is good and fan is working.
Fan is wired separately from the cooling unit. you may have a wire corrosion issue. take put the shelves, disassemble the back of the unit from the inside and observe the wiring to see if there are broken or corroded wires/connections. R/R if necessary.
Dec 14, 2014 | Magic Chef Dual Zone Wine and Beverage...
Edgestar wine cooler blowing fuse on the left side circuit board
If you have replaced the circuit boards it's probably associated with a wiring short circuit or compressor failure. Suggest you get a professional technician to further investigate the fault. In the interim check for a short to the frame of the unit, an internal light or for moisture issues or a condensation issue from water.
Mar 25, 2014 | EdgeStar ES TWR325ESS-32 Bottle Dual Zone...
Wine cooler not cooling.
Your themostat inside the cooler may be broken.
Mar 19, 2014 | EdgeStar TWR282S Wine Cooler
Edgestar cwr300sz
This cooler's operating range is 40-65 F. If it is still in warranty contact the manufacturer. You could have a faulty thermostat. If so have it replaced.
Dec 30, 2013 | EdgeStar BWC120SS (36 cu ft) Wine Cooler...
Edge star not cooling and clicking sound
the clicking sound may be the condenser fan. if the compressor is running, check to see if there is dust or ice blocking the air flow on the condensor or if the fan is moving slow. this will prevent cooling. remove any obstructions and replace the fan if necessary
Nov 24, 2013 | EdgeStar BWC90SSLT - 84 Can Supreme Cold...
Take a look at: https://edgestar.zendesk.com/hc/en-us/articles/200604529-My-beverage-cooler-is-not-cooling-below-50-degrees-How-do-I-get-the-temperature-lower-
May 11, 2013 | EdgeStar TWR181ES
Wine Cooler not Cooling
I think the compressor of the cooling refrigerator is not working. Otherwise the refrigerant gas has escaped from any leakage. Please check two above mentioned things. Gautam Kr. mandal, Durgapur
Jan 19, 2010 | Kitchen Appliances - Others
Edgestar Dual Wine Cooler
Well... it is tough to get wine to spoil.
Keep it out of the sunlight and don't get it really warm
(after all... is just grapes that have already spoiled...
I'm just saying).
I bought the VERY EXPENSIVE Kitchen-Aid
48 bottle... took the 5 years & about another month
for the evaporator FAN to rub a hole in the evaporator aluminum return line (made in USA (opinion: junk)).
KITCHEN-AID never even returned a call or e-mail.
Handling circuit boards: You MUST WEAR anti-static
wrist straps when handling them... ELSE you could be popping those semi-conductors like POPCORN.
The only other REPUTABLE source of information I have ever found on EDGESTAR (very helpful) were the folks at
Compact Appliance.
https://www.compactappliance.com/edgestar-wine-coolers/
ESD wrist-strap
Amazon com Rosewill ESD Anti Static Wrist Strap Components RTK 002 Black...
Mar 13, 2017 | Refrigerators
Beverage/Wine cooler not cooling
call a local refrigeration repair service .
Jan 15, 2018 | Refrigerators
Furniture Logo
290 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
