Question about Building Materials
I need to program a remote for a Genie Blue max garage door opener. It doesn't have a learn button.
SOURCE: i have a pmx300IC genie
palm treo 700w off no open
Posted on Jan 19, 2009
SOURCE: Reprogramming a Genie garage door receiver
I ned a akai audio timer DT-100
Posted on Aug 18, 2009
  • 3197 Answers
SOURCE: Trying to clear the codes from my Garage Door
In most cases, when a garage door opens or closes by itself, or when you find your door open, upon returning home, the problem is due to a short somewhere. This short is most likely to be in one of two places: either in one of your transmitters or in the wall button or its wiring.
When there is a short in your garage door transmitter, you will often find the garage door is up upon returning home, even though you know you closed the door when you left the house. A short in your transmitter causes a continues signal to be sent. As you are pulling out of the driveway the garage door closes fully and appears to stop, but as the carriage and arm run past the down limit and hits the header bracket it reverses, and the door begins to open, just as you start driving off down the road. You come home to find the garage door is up, as if someone else had opened your door. The best thing to do to troubleshoot the garage door problem is remove the batteries from your transmitters and try operating the door from the wall button. If the problem is intermittent, you may want to do this for a day or two to eliminate the transmitters as the culprit.
If the problem persists, try removing the wall button wire at the motor head to ensure it is not a short in the wire to the button, then try operating the garage door with the transmitters only. If it stops the problem, replace the wires and test the wall button. It is a process of elimination.
Posted on Mar 29, 2010
swolfinor
  • 504 Answers
SOURCE: How do I program my Genie garage door opener to my 2005 Kia
GOTO HOMELINK.COM
THEY MAKE THE SYSTEM AND HAVE INSTRUCTIONS YOU CAN DOWNLOAD.
PLEASE NOTE: NOT ALL BRANDS/MODELS OF OPENER WILL WORK WITH THIS SYSTEM.
HOPE THIS HELPS
Posted on May 26, 2010
blanchettohd
  • 143 Answers
SOURCE: Genie Compact 3-Button Remote control will only open 1 door/not 2
On some of the remotes you will find a toggle switch to change frequencies, this might help. Note all new openers are operating on a different frequency than slightly older ones due to military interference. Even though both might be intellicode they might not work together on the same remote. Sometimes some openers are harder to program than others. So lets try to program the harder one. You need to find and press the learn button on the motor head. Then press the button on the remote once. The led light by the learn button should not flash. If so try it over. The light should either stay lit or go out after the first press. If it does press it again and then a third time. If it ever flashes during the program process try again. The third or fourth time the motor should operate. If not you either have a bad remote or more than likely a bed logic board. Thanks BB
Posted on Jun 06, 2010
Learn button on genie pro max garage opener is not working . How can I programm new remote?
if the learn button is truly bad you have two options either replace the circuit board or buy an external receiver. It was me a would replace the opener with a Chamberlain/Craftsman or Liftmaster belt drive opener. The new genies aren't worth a damn. I've replaced about a dozen that were a year or less old because of defects this year.
Nov 07, 2016 | Genie Pro Building Materials
How to program a remote for a genie garage opener model 209
When programming a genie remote press the learn button
Then you will have to press the genie remote at least three times before it stores the code older genie models 5 times genie i
Apr 05, 2015 | Building Materials
How do i program my garage ope
Take your old remote and point it at the new remote while pressing 'learn' (or you might only press learn and then shoot the old signal into the new remote). Almost impossible without the old remote though. Hope this works.
Apr 22, 2013 | Building Materials
I have a genie pro max PMX 300 IC/A garage door opener and bought a Genie 3-button remote (model G3T-R) and I can't get it programmed. I push the button on the back of the opener, push the button
Take the opener apart and see if there are about 4 numbers that can be set. If you have an older remote take it apart and match the numbers, then program it.
Feb 07, 2012 | Home Security
GT3-R -can
This is a dual frequency transmitter. (315/390) You need to select one button to program the TYPE 1 frequency of 390 MHz. Here's how:
Backwards compatable programming instructions for GT3-R dual-band remote: This is a 3 button remote, which can be used to operate up to 3 garage doors using IntelliCode radio controls. This remote is defaulted to operate the new IntelliCode 2 Genie garage door openers, but you can also program individual buttons to operate other IntelliCode 1 (pre 2011) models of Genie garage door openers made from 1998 to present. To change a button to operate a pre 2011 IntelliCode opener, the default IntelliCode 2 setting must be changed to IntelliCode 1. An LED light on the remote displays which mode the remote button is in: Red = IntelliCode 1 / Green = IntelliCode 2 To set one of the 3 buttons to be IntelliCode 1 (red), follow the instructions below:
  1. Select a button on the remote that has not been programmed.
  2. Press and hold that button for 10 seconds. Both Red and Green LEDs come on and stay on.
  3. Press the same button twice to toggle IntelliCode selection from IntelliCode 2 to IntelliCode 1.
  4. Press the same button again to confirm toggle. the LED should be Red. The IntelliCode selection for this button is set to IntelliCode 1.
You are now ready to program the remote to your garage door. Follow accompanying instructions for "Programming to IntelliCode 1 Genie garage door opener," or see below instructions: Programming Instructions: Gently press the Receiver Learn Code button on the power head receiver of your Genie garage door opener (motor head on ceiling in garage). This small, black, unmarked button is located behind the light lens at the motor head and is nearest the floppy 6 inch antenna wire that protrudes from the motor head. When pressed, a radio signal indicator light will start blinking red for 30 seconds. After pressing the Learn Code Button, press your transmitter button twice for your system to grab the frequency and code it in. (Keep the transmitter you're tuning at least 2 feet away from the power head while tuning.) Press the transmitter button once more to test the system and start your door moving.
Jan 06, 2012 | Video Game Consoles & Games
FOR GENIE GARAGE DOOR OPENER ICA SERIES WITH INTELLICODE REMOTE CONTROL SERIES II ELECTRONICS. PROGRAMED REMOTE FOR NEIGHBORS DOOR, WHRN NO LONGER NEEDED THE ACCESS I RE-PROGRAMED TO MY DOOR. NOW BOTH...
First you want to clear both Garage Door Openers. To clear the openers you need to locate the learn code button. This button is (usually) under the white lens cover just push it and hold it in until the red light stops flashing then do the same thing to your other opener. This clears out all remote controls that are programmed to these openers. Try the remote to make sure the units were properly cleared. Neither opener should activate if this was done correctly. After units are properly cleared push the learn code button on the opener that you want this remote to open. The learn code led will flash, then press the button on the remote once (learn code goes solid), press the remote a second time ( learn code goes out). Press the remote a 3rd time and opener should activate.
Nov 22, 2010 | Genie Company Genie Intellicode 1Button...
I want to program my Genie ecellerator isd 1000 so that I can use my Homelink system in my car and my wife can continue to use her Genie remote that came with the opener. How can i do this? Thanks
Inside the car press the 2 outer buttons on the homelink until the led light by it goes out or flashes rapidly. This erases all old/factory codes. Hold the remote 1" from the button you want to program and press the button on the remote and the homelink button until it flashes rapidly. Then press the learn button on the motor head and then press the button on the homelink you pressed before 4 times and this should code in. Thanks BB
Aug 21, 2010 | Sears Genie Garage Door Gpwk12 Wireless...
May 15, 2010 | Genie Company IntelliCode GICT390-1BL...
Programming the garage door opener
Homelink Garage Door Opener Programming Procedure:
The procedure described below was successfully applied to a 2005 Jaguar S-Type.
To begin with, several attempts were made using the programming instructions contained in my Jaguars owners manual. Though the procedure described in the owners manual was straight-forward and understandable, I was unsuccessful in getting the vehicles remote to make my garage door opener function. The particular garage door openers I have are both made by Genie. Both openers utilize the Rolling Code feature.
To begin with, be sure to clear previous codes on your Jaguars garage door opener by first turning (rotating) the ignition key to the I position (first notch). Next, simultaneously hold button 1 (left most button) and button 3 (right most button) down until the middle buttons red light changes from continuous on to a rapid flash. This process takes approximately 20-25 seconds. What follows is a two part process. In the first part, get your Genie portable remote and hold it near (approximately 3 inches away from) your Jaguars garage door opener console buttons. Choose which button on your Jaguars remote you wish to dedicate to your Genie door opener and simultaneously press and hold your Genie opener button and your Jaguars opener button. The red light on your Jaguars center button (button #2) will light up and within 1-2 seconds will begin to flash rapidly. You have just completed part 1 of the two part process.
Part two: Now it is time to utilize the Learn function on your Genie garage door opener. Press the Learn button on your Genie garage door opener. The red LED adjacent to the Learn button will begin to flash. You now have 30 seconds in which to program your Jaguars opener button. Using the same button you just used in the part 1 procedure, press and hold the same button for several seconds. As before, your Jaguars red light in the middle button will light up and within 1-2 seconds, it will flash rapidly. Release the button you are programming. Now, here is the key piece of information! Once again, press and hold that same button. Once again, the center buttons red light will flash rapidly. Release your newly programmed button. This procedure proved successful in my application. Here is what has just happened. The first time you pressed your Jaguars remote button tells the Genie opener that it exists and that it is a viable candidate for making your life easier (opening the damn door). The second time you press your Jaguars remote button confirms to the Genies rolling code that your Jaguars signal is legitimate and is to be trusted from then on.
Jun 06, 2008 | 2003 Jaguar XJ-Series
Building Materials Logo
66 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
