Question about Garmin nuvi 52LM Essential Series 5" GPS with Lifetime Map Updates
Iam using an SD Card with Snowmobile Trail maps in it on my Garmin Nuvi 52 LM. Can I disable the auto zoom feature in the GPS.
SOURCE: Garmin nuvi 260
Re: Not sayinstreet names.
After you turn on your unit touch the wrench icon in the bottom right of the screen, this will take you to a menu which features "Settings" in the upper left of the screen. Touch "settings" and scroll down to "language" by using the up and down buttons in the lower right of the screen (down 1 should do it). Touch "Language" and in the voice category find and select "American English - Jill (TTS)". This is the voice that will give you Text To Speech (TTS) speaking the street names in English. If you prefer Spanish or French, find the appropriate catergories with "(TTS)" beside them - "Espanol Americas - Paulina (TTS)" and "Francais Canadien - Julie (TTS)" respectively. Any other selection will only give directional instructions such as "turn left in XXX".
After you have selected your voice press "OK" and back out to your main menu showing "Where to?" and View Map".
Now, when you navigate, you should hear an American female voice giving you directions by street name - assuming your volume is high enough to hear it.
RE: The computer icon displaying when you try to use your unit in the car with the 12 VDC cord.
You probably have a problem with the cord. The pin length in the USB style connector is critical and if it doesn't match up just right the GPS thinks it is hooked up to a computer. If you know someone who has a Garmin NUVI try using their cord and see if you have the same problem. Either way, call Garmin and see if they will send you a replacement cord or otherwise help fix the problem.
Posted on Nov 03, 2008
SOURCE: Nuvi 200w map download and sd card
Guys and or ladies... I know that you have to create a folder named "GARMIN" in the sd card so the maps can be recognize. Maybe this solves your problem. Let me know if it works.
BR from Spain,
Carla
Posted on Apr 01, 2009
  • 48 Answers
SOURCE: Garmin Nuvi 200 Maps Disappeared
Hope this helps!
I wanted to add maps to my 250W. I found the maps I wanted on a Torrent. However, many searches around various forums never revealed how to install these. Found the following through reading and experimentation.
1. Downoaded map image file GMAPSUPP.IMG. Download also gave me "Use code XXX when generating unlock code for maps"
2. Downloaded Garmin Unlock Generator 1.3 by JetMouse
3. Looked on my GPS to find the UnitID
4. Entered the UnitID into Garmin Unlock Generator. Ignore the GM XT device unlock code and the top Generate button.
5. Selected Map Product as Custom and entered the code given for the downloaded image file.
6. Hit the bottom create button to generate a 25 digit code.
7. Download Img2Gps and run
8. Click Load Folder to load the image file. Select the tick next to it.
9. Check the Use Unlock Key option and paste the 25 digit code in.
10. Load a blank SD card into your Garmin
11. Connect the Garmin to your PC using a USB cable. You should see two dirves in windows: one is the Garmin and the other is the "Removable Disk" SD card.
12. Create a folder called "Garmin" on the SD card
13. Select Folder/Card in Img2GPS
14. Click "Copy Maps". Select the folder /Garmin on the SD card. You may need to click copy again.
15. Upload will take a while.
16. You should now see a file GMAPSUPP.IMG on the SD card in the /Garmin directory.
17. Create a new text file called GMAPSUPP.UNL in the same directory (make sure it does not have a hidden .txt extension).
18 copy the 25 digit unlock key into this file.
19. Close the file.
20. Disconnect the Garmin.
21. On Startup it should load your original maps and the new ones.
Posted on Jun 02, 2009
SOURCE: Can't unlock maps on the SD card
I am still waiting for the promised free solution suggestions
Posted on Jun 13, 2009
  • 4090 Answers
SOURCE: Is there any free map updates for the garmin nuvi?
Asmany as there are FREE dinners Updates are not free, unless you paid full price for it when you bought it. Free upgrades are a deceptive myth. If you get a free uograde its usually minor and was included in the price of the pack.
Posted on Sep 20, 2009
DELETING MAPS ON NUVI 40 LM
Plug your GPS into your PC, it will mount as a hard drive. You can then open the folders and delete content. As easier solution is to put a 8gb micro SD card in the SD card slot. Garmin Express will allow you to put additional maps on the SD card.
Mar 22, 2017 | Garmin Nuvi 40Lm - Gps Receiver
No space to download maps
Install an 8gb microSD card in the SD slot. Garmin Express will then allow you to download maps to the SD card.
May 08, 2016 | Garmin Nuvi 52 Gps
When i use garmin express to update the maps for my nuvi 52, i hit the install for maps and it doesn't complete the software update before it errors.
Do a hard reset on the device. Download Garmin Express and install it to your PC. Connect your device to your PC. Garmin Express will identify it and allow you to install all the maps and software that the device has a subscription to. You either have a corrupt file or a space issue. If it is a space issue, insert an SD card 8gb or less and have Garmin Express install the maps and updates to it.
Apr 02, 2016 | Garmin Nuvi 52 Gps
Well u see i want to update my nuvi an middle east map i think i have a 2010 verstion now the problem is i want it for free.
Unless you have the LM model (lifetime maps) the map update will not be free. But the system software and other updates will always be free. I will attach a link to the Garmin site.
Thanks for using FixYa
https://my.garmin.com/mygarmin/registrationGettingStarted.htm?productType=auto&categoryType=AUTO
Sep 05, 2011 | Garmin nuvi 1310 Car GPS Receiver
Unocking Garmin SD maps
it is in the box it came with, on the back of the instruction book.
If you did not buy it 'new in the box', you will have to refer to the 'activation' code sent to you email.
The Garmin Nuvi 760 does not require SD card maps if you are using it in the US, btw...
-d
Feb 15, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin Nuvi 760 memory card
Does the Garmin Nuvi 760 require an additional memory card for normal use?
The simple answer is : no it does not need and SD card to work
Jan 26, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin Nuvi 300 - SD problem
I believe your current location is somewhere in UK/Ireland, which means the Nuvi's last/current satellite fix is not anywhere within Spain/Portugal. If you need to use the maps features of that country where you're not physically there with the Nuvi, the Nuvi must be in Simulation mode first. Fold down the antenna to switch off GPS (not device) and enter Simulation mode.
Then, scroll the map screen (combinations of zooming out, browsing, and zooming in to the spot) until you find the location you want to simulate (it must be within the maps coverage). Then, tap 'Set Loc' at the bottom of the screen. At this point, as far as the Nuvi is concerned, this is the GPS location where you are at. Then you may proceed with Address Search, etc. using the other map's database.
Jul 26, 2008 | Garmin Nuvi 660 GPS Receiver
Map
The Nuvi 350 does have an SD cart slot in the side, which will allow you to purchase maps of other countries on an SD card, and use them in your unit. Garmin has a list of available maps for purchase on their web site.
Feb 11, 2008 | Garmin nuvi 350 GPS Receiver
USA MAPS
You need to buy a preloaded SD card, purchase maps from Garmin and download them to a blank SD card.
Dec 10, 2007 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 52LM Essential Series 5" GPS with Lifetime Map Updates Logo
32 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
