Can I use grind wireless headphones with a desktop? If so how do I hook it up?
How to hook up wireless headphones
Haley, I have never done it, but it does not sound too hard. Read through the following links below to find out how to hook up wireless head phones.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.jabra.ca/q/how-wireless-headphones-work-how-to-connect
How to set up Wireless Headphones with the TV How Tos
How To Connect Wireless Headphones
Logitech Support
Apr 21, 2016 | Audio Players & Recorders
Can beats s450 be connected to any soundbar?
If the soundbar is Bluetooth-enabled, yes. But I have not read or heard about a Bluetooth-enabled soundbar yet. And why would you want to connect the headphones to the soundbar ? The only situation where this would make any sense is if the soundbar were hooked up to a TV. If this is the case, your only solution is to use regular (not Bluetooth) wireless headphones, which consists of two pieces: the headphones and a transmitter that you hook up to the audio output of your TV. The transmitter piece transmits any sound coming out from your TV wirelessly to the headphones.
Sep 27, 2014 | Beats By Dr Dre - Wireless Bluetooth...
How do I connect wireless headphones to a Dynex 42"TV model DX-42E250A12?
Check this link for a user manual
http://www.dynexproducts.com/cms/documents/Manuals/DX-42E250A12_11-0618_MAN_V1_EN_Final%20lr.pdf
Sep 07, 2014 | Dynex Televison & Video
Sylvania wireless headphones
Instructions
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more : http://www.ehow.com/how_4883556_use-wireless-headphones-tv.html
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
5
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
good luck
Nov 14, 2013 | Sylvania SYL-WH930GB Wireless Headphones
I bought wireless headphones, how do i connect them to the TV wirelessly
Normally the wireless headphones have a transmitter that send audio via wireless to the wireless headphones.
The transmitter needs to be plugged into the headphone outlet on the TV. This will switch off the speakers on the TV and sends the audio to the wireless headphones.
Sep 23, 2012 | LG 32LG30 32 in. LCD HDTV
Model No. TH-42PD50U can you hook ext speaker or wireless headphones?
Yes,if want to hook up ext.speakers.Buy the BOSE system,the best system out there so far.Wireless headphones.Buy the wireless headphone system.Plug in the remote stick to the HDMI hub and u have a wireless headphone.
Apr 28, 2010 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Wireless headphone hook up
Hello depends on how you hook it up as thee are several ways.
many receivers will output sound through the headphone jacks even when the speakers are left on.(my receivers require that you manually turn speaker A off when using headphones)
it may be possible for you to connect the headphones to a tape output but this will require headphones that have a volume control on them or an external.volume control knob.. You may encounter a problem as I am not sure if a tape output will provide enough signal to drive a pair of headphones. this would not be a problem if you use a pair of WIRELESS headphones as they have their own power source onboard..
A set of wireless headphones could also easily be connected to the output on the back of the TV but assuming you have your receiver plugged in to the TV audio out you may need a couple of Y adapter cables.
Also if your receiver has a pair of PRE OUT jacks those would work to power a set of wireless headphones may also power a wired set but once again not sure on power as I have never needed to try it.
Hope that helps a bit
Jan 09, 2010 | Audio Players & Recorders
 Grubhead
Grubhead
