Question about Whirlpool Washing Machines
Whirlpool washer letting both cold and hot water in when I only ask for cold water...
I have a Whirlpool washer LSB6300PW2. When I set the washer to use only Cold water, the washer begins to fill with only cold water, but then suddenly the water pressure increases and it starts filling with BOTH hot and cold water, and then suddently it switches back to allowing only cold water. It does this a few times before finally reaching the set water level, then the washer goes on operating as normal by beginning to agitate. What is causing the washer to allow BOTH hot and cold water in when I am asking for only cold water? Is this caused by a faulty Water Inlet Valve? Or could it be the Timer ?
  • Stella Ab Dec 23, 2016
    I found info below. Is this true?
    Water enters the unit from two valves on the rear of the appliance. One valve regulates the hot water and the other valve regulates the cold water. The water flows into the tub from the upper rear section of the unit. If the unit has a dispenser water flows through the dispenser. Only one valve will cycle on at a time. The unit will first dispense cold water at the beginning of every wash cycle regardless of the water temperature selection. The washer senses the temperature at the bottom in the tub and not at the incoming valve where the water enters the appliance.
    You must also take into consideration where you are located. Based on the ground temperature customers who select a cold wash can invariably see the unit bring in warm water in order to take the water to the required temperature. For example, a customer who lives in a colder region may see the unit alternate between cold and warm water even though they may have selected a cold wash. This is because the tap water temperature may be too cold for a cold wash and the unit will compensate to bring the water temperature to an acceptable level to provide best cleaning.
    The same is true for a customer living in a hot region. The tap water may be warmer than normal and so if the customer request a warm wash the unit may never make a request for hot water since the water entering the appliance will be at the proper wash temperature coming out of the water line.
    Uploaded 5 video answers.
  • 47 Answers
The water valve is working. It only does as told. Faulty water temp switch or yank out the small board and clean the terminals then re insert it and see if maybe corrosion was all that it was. That is what I would try if it was mine.
Posted on Dec 22, 2016
Whirlpool Washer water inlet valve
Go to the enclosed link with the exact model number of your appliance and you will get the appropriate part number. You can buy from them or check it out on ebay where , very often, the part will be available for less money.
Dec 15, 2016 | Whirlpool Washing Machines
Washer temp setting changes by itself
I also have a Whirlpool washer/dryer for my condo, although I don't know the model number of mine. I had the same problem -- after it was precisely a year old, suddenly one day the hot and cold started coming out reversed. I was able to fix mine by more or less temporarily fiddling with the water pressure. What I did was one time, when the rinse cycle was running and the washer was filling up with hot water (grrrr...), I completely shut off the valve supplying hot water. So at that point the water stopped filling into the washer, and then I started tinkering with the cold water, twisting the valve off and on a few times. Then BINGO, suddenly the cold water "kicked in" and for the remainder of the rinse cycle, it filled the washer with cold water. I then turned the hot water valve back on, and since then it has been running correctly.
Jun 05, 2010 | Whirlpool Washing Machines
The code f 20 flashes on my duet front load washer what does this mean
The F20 code for insufficient water going into the machine. Checked the hoses and water valves at the wall to make sure high pressure water is going to the washer.
You can try a different Cycle water temp setting. Like Cold/Cold or Hot/Hot to see which valve is not letting in the water.
There has been some know failures of the cold water inlet valves. That Whirlpool part number 8540751.
I hope this information has been helpful.
Good Luck.
May 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The washer is set on cold/cold. The hot water faucet is turned off. The washer should not be asking for hot water because it is set to cold/cold. It asks for and received cold water. At some point...
Newer machines know the water temperature. It will mix hot water even on a cold setting if the incoming water is too cold. Detergents need a temperature of at least 60 to activate.This will only happen in the winter usually.
Feb 24, 2010 | Washing Machines
I bought this washer used with out a manuel. I
Hello-I came across this several years ago. Some whirlpools have a preprogram where the water temp. is already defaulted to the type of load and color. As you assume the white should be hot or warm. The rest of the selections are probably cold. The manufactures can be driven to apply energy saving features into their products so most cycles are probably cold. If all else fails, when you make a selection let water fill into the tub about 5 minutes and carefully check to see if the water is warmer or colder. You also might be able to pull up owners info on the net if you have the model#.
Feb 08, 2010 | Whirlpool LHW0050PQ Front Load Washer
I have a Whirlpool lsb6300pw2 top-loader. Spinning is not always complete if at all. The tub usually drains fine it is just the spin cycle that for some reason is not happening. If the washer is reset...
Hello. I also have a Whirlpool LSB6300PW2. Do you happen to know what the Part # is for the WATER INLET VALVE? I googled my washer model and all that comes up is: LSB6300PW1, or LSB6300PW3, or LSB6300PW4 . But I can't find LSB6300PW2.). I am certain my model is LSB6300PW2 because that is what is imprinted under the top lid of the washer. I am looking for the Genuine OEM Whirlpool Water Inlet Valve, not a generic. THANKS !
Jan 04, 2010 | Whirlpool Washing Machines
My whirlpool front load washing machine accept hot water and no cold water entering on the machine.
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Apr 01, 2009 | Whirlpool GHW9400 Front Load Washer
Whirlpool ghw9100lw2 front load washer doesn't use both hot and cold
first make sure the hoses aren't reversed hot on cold or cold on hot next turn off cold water remove the hose from the washer and check to see if the screen on the washer is clogged if not get a bucket turn on cold water and see how strong the water is then let me know what you find dont rate me till we are done
Jan 10, 2008 | Whirlpool GHW9100L Front Load Washer
No cold water on cold settings
Try switching you hot cold inlets to the washer on the back....If that doesn’t work let me know...
Jan 04, 2008 | Whirlpool Duet 3.8 cu. ft. Front Load...
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
