My Washer (Maytag Atlantis mav6300aww) will not start. It shut down in the middle of a cycle with the drum full of water. Now nothing turns on at all
Lumpy816
  • 246 Answers
SOURCE: Maytag Atlantis washer will not drain and spin unless you lift the lid
The cheaper thing to check first is is your lid bent? The lid switch is in the center of the lid. If it "droops" or has been bent, it shaft on the back of the lid cant hit the switch. Open the lid and apply pressure in the bottom, center of the lid. This usually corrects the problem without replacing the switch.
Posted on Jun 16, 2008
SOURCE: Maytag Atlantis shut down during rinse cycle.
Contacted a local repair shop. They told me that if I got it spinning again, the motor was most likely ok. It is protected by a thermal switch that turns it off when it begins to overheat. The smell was to be expected as it was overheating; the difficutly restarting was because it hadn't cooled off enough yet. We have now used it a few times for small loads. Still getting a smell, but the wash cycle is completing ok.
Posted on Jul 25, 2008
  • 27 Answers
SOURCE: Maytag Atlantis MAV7600AWQ Washer. Delayed fill
ALL WASHERS COME WITH SCREENS AT THE
WATER CONNECTIONS.DISCONNECT THE HOSES AFTER TURNING OFF THE WATER.THEN,CHECK THE SCREENS FOR MINERAL BUILDUP.CLEAN THE SCREENS IF
NEEDED AND GO FROM THERE.
Posted on Mar 07, 2009
milten1
  • 1304 Answers
SOURCE: Maytag Atlantis - dead and full of water
with the atlantis i would have to say yes
open the control panal,
pull out the lid switch and unplug it,
give it a shake if there is any rattle
thats your problem
you can order a new switch and plunger from
appliancepartspros.com
looking for part number
AP4008646 about 20.00
Posted on Oct 17, 2009
Testimonial: "Thanks Milten. Your diagnosis of the problem was 100% accurate. I was able to fix my washer with a $20 part. It works perfectly now. Paul from Chicago"
SOURCE: I have a maytag Atlantis washer - 7 years old, it
I have a Maytag Atlantis top load washer which leaks in the rear right hand corner under the discharge hose, how do I take the machine apart to get to the problem.
Posted on Feb 06, 2010
Maytag atlantis washer doesnt spin on spin cycle, also found plastic shavings in clothes, appear to be coming from the top outer edge of the tub, a white plastic trim piece. wash cycle seems to work fine...
There can be several causes, the drum off balance would cause the shavings during spin cycle , balance could be one of the the balancing mechanism failed and not running could be the balance sensor shutting down the spin cycle. You should start by checking the balance shocks .
May 14, 2011 | Maytag Atlantis MAV9750A Top Load Washer
Maytag atlantis washer mav6300aww drains water but does not spin
my maytag washer model #MAV6300AWW will not spin out during cycle but can turn it back to spin and will spin out
May 30, 2010 | Maytag Atlantis MAV6000 Top Load Washer
I have a Maytag Atlantis MAV6200AWW. The washer
hi
the solenoid on the cold water is gone down or it is not fed with electric
Jan 29, 2018 | Maytag Atlantis MAV6451 Top Load Washer
Sits Pretty Doing Nothing,ARG!
Any codes on the front?. Try here to see if it's any help: Type in MAV6000 only
http://servicematters.com/maytag_library/html/index.html
Danwan
Sep 12, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis screeches @ end of spin cycle,
may be something stuck in the drum or a segment raised on the motor. to test either remove the belt and spin the drum if no noise then the motor is faulty. if a noise then there may be a bra wire between the drum/tub.
Mar 16, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Mar 07, 2009 | Maytag MAV7600 Top Load Washer
Water fills but does not agitate or spin
THIS UNIT HAS A DOOR SAFETY SWITCH WICH ALLOWS WATER TO COME IN BUT NOTHING ELSE TO HAPPEN IF THE DOOR IS OPEN I WOULD START BY CHECKING THIS SWITCH.
Nov 29, 2007 | Maytag Atlantis MAV6260AWW Top Load Washer
Drum full of water after wash
Lubricate the motor plate the whole motor slides back and forth to switch from spin to wash. Not a good design very problematic.
Oct 01, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
