I HAVE A MR HEATER 210'000 HEATER IT WILL ONLY RUN WITH THE TOP COVER REMOVED OR RAISED ABOUT AN INCH IF COVER LEFT ON IT WONT FIRE UP AT ALL OR IT WILL SPUTTER
    Problem Solver:
  • 7 Answers
This is typically due to Low Pump Pressure.
Check to make sure you input and output air filters are clean.
There is a filter under the black cover so make sure to check that one.
Turn the pressure up a 1/2 pound past manufactures setting and see if the unit starts after that with the hood having to be lifted.
Posted on Dec 27, 2016
My mr. Heater contractor series 75,000 kerosene heater won't get hot the blower isn't kicking on its getting fire and it's got kerosene in it but it won't get hot the blower won't kick on?
Kerosene Torpedo Heater Repair + Test - YouTube
? 12:08
https://www.youtube.com/watch?v=k1nRieTELnk
May 25, 2013 - Uploaded by InductiveExperiments
I repair my "Reddy Heater" torpedo heater by installing a new ... I replaced spark plug, filters,photo cell, new K, it has fuel spray,spark but it won't ignite now! .... I removed my motor andhot wired it to an outlet and it worked fine. but when hooked up ....Mr. Heater 36,250 views ... Get video URL at current time.
Torpedo Kerosene Heater repair & HOW they work - YouTube
? 9:30
https://www.youtube.com/watch?v=ve0nzByP6SU
Dec 6, 2013 - Uploaded by sixtyfiveford
Could not find my manual and the Mr. Heater (75k),web site let me down for a pdf. Opening the .... Thanks for the video -- helped me get mine working again ... Fan runs also just won't fire Any help would be great Thanks.
Mr Heater Kerosene heater cleaning and maintanence ...
? 9:06
https://www.youtube.com/watch?v=2EzoWdZLExg
Jan 11, 2016 | Mr. Heater Heating & Cooling
Reddi heater sprays and igniter gets hot but heater wont fire up??
If the heater will not ignite, this maybe caused by low pump pressure or perhaps a fuel blockage, or could be caused by too much air from the fan, the hot surface igniter heaters are very sensitive to this kind of problem. Will the heater start with the top cover removed?? If so try closing down the angle of the fan blades a little, but not too much, to reduce the air forced into the combustion chamber. If the heater will not start with the top cover removed, try adjusting the pump pressure, or replace the nozzle. This may not be very scientific, but the solution maybe by trial and error, and can be very frustrating! Hope this helps.
Feb 25, 2014 | Heating & Cooling
210,000 btu Mr. Heater Contractor heater won't start
That error is a cad cell error. That could mean that the combustion air is having issues. The electric eye is bad or dirty or there could be an issue with the pressure sensors. go to mrheater.com and look at the troubleshooting guide or call the free 800 number
Jan 05, 2014 | Mr. Heater Heating & Cooling
Ignition timing 1988 subaru 1.8l
the timing at the distributor is 20 degrees before top dead center. Also check your fire order 100 times It CAN start and run funny with the fire order off. She fires 1 3 2 4 (left head then right head) and your cylinders are clearly labed with raised numbers on the block at each cylinder.
Hope you get her running smooth soon!
Feb 21, 2011 | 1988 Subaru GL-10
I installed a Mr Heater 45,000btu heater in my garage, when I turn it on to fire, it fires for a moment, I get about a 3 inch flame for a moment and then it goes out. What do I need to do?
clean the flame sencor first check connections on flame sencor , check you have gas to heater check limits high and low jump then out one at a time see if it lights , or check pressure switch if fitted jump this out and check tubes to it
Jan 20, 2011 | Mr. Heater Natural Gas Garage Heater -...
Flame wont stay on, runs for about 5-10 secs and
usually the thermocouple wears out. Make sure the thermocouple is in the flame, if it is, and it still wont stay lit I would change that first.
Feb 28, 2010 | Mr. Heater MH175KT Open Flame Utility
I have a a problem with my mr. heater. When I turn it on it puffs
Not knowing what Mr Heater Model you are referring to, I would suggest you call Mr.Heater's customer service line at 800.251.0001.
They have techs that can help troubleshoot your problem.
Dec 30, 2009 | Mr. Heater Portable Buddy
Dayton kero heater wont fire
your photo cell is bad or dirty its a little lens that looks threw the hole into the cumbustion chamber with two wires coming out of it.
Jan 15, 2009 | Dayton Electric Heater
Heater core
NO, BUT THE COMPLETE HVAC MODULE NEEDS TO BE REMOVED. THIS IS BASICALLY THE LARGE BLACK AIR DISTRIBUTION BOX LOCATED UNDER THE RH SIDE OF DASH. THE RH BODY MOUNT BUSHINGS ARE ALSO GOING TO NEED REMOVAL & THE BODY SLIGHLTY RAISED TO GAIN ACCESS TO CORE UNDERHOOD.
Nov 06, 2008 | 1996 GMC Jimmy
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
