Question about Garden
My pressure washer simpson is leaking large amount of gray oil
Simpson Honda 3,000 psi 2.4 GPM 190
  • 7 Answers
SOURCE: oil leak under the engine
If it is a vertical shaft engine then it is most likely the crankshaft seal. That requires removing the engine from the frame and removing the pump from the motor to replace the seal. If it is a horizontal shaft engine then it could be either the shaft seal or the side cover gasket. Both require removal of the pump.
Posted on May 02, 2009
blueextc3221
  • 15935 Answers
SOURCE: Craftsman 2000 psi, 1.9 gpm pressure washer Manual
The model number is required to get the correct manual.
The Model Number is on the motor tag.
It is in the format XXX . XXXXXX
Where X = a number.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Aug 31, 2009
  • 56 Answers
SOURCE: I need to buy a pressure washer for residential/commercial work
Were I to pick from one of those three, I would pick the Landa. The most reliable pumps are Hotsy and since Karcher bought Landa and Hotsy, those three brands now have Hotsy pumps, though it doesn't say it on the machines.
Posted on Jan 02, 2010
mkh5094
  • 145 Answers
SOURCE: What type of oil is needed for a Honda GC160 Power
The type of oil recommended for that engine is SAE 10W-30 and the capacity is 0.61 quarts. This and more can be referenced at the website at the end of this solution. I was able to find the owners manual of your particular engine.
http://www.northerntool.com/downloads/manuals/60594.pdf?cm_re=Product%20Page-_-Manual-_-Side
Posted on May 28, 2010
kel1guy2002
  • 3740 Answers
SOURCE: We have a brand new Simpson- Honda 3,000 psi,
Hi and welcome toFixYa, I am Kelly.
When you say it stalls is this fuel starvation or does it act like you shut off the ignition switch?
This should have the Honda GXC160 5.5 Hp engine on it. With the fuel selector off, have someone one remove the float bowl and check for debris in the very bottom of the float bowl. Also use come carb cleaner and spray into the main fuel jet located in the threaded are where the bowl nut screws into. The main fuel jet has a pin hole in it that must be free of obstructions.
Since this is a new unit you may just have some dried fuel in the fuel passages. With the float bowl off use a spray paint can lid and turn on the fuel selector. It should fill the lid in 8 - 10 seconds to the point you will shut off the fuel before it overflows. If you do not have this kind of fuel flow start looking at the main fuel line from the tank to the fuel selector. Check for a fuel filter and a debris bowl. I think the debris bowl is located directly under the fuel selector. It unscrews CCW for cleaning. Just clean it out and re-install same.
The last thing to check is to remove the main fuel line from the carb and check fuel flow. You should have good fuel flow with the fuel ine disconnected. If you do have good fuel flow here and you stilhave the stalling problem the float will have to be removed and the float needle will also have to be removed with the float. Once the float and float needle are removed spray carb cleaner into the float needle hole to force any debris back out the main fuel line connection.
Re-assemble everything... turn on the fuel... check for leaks and then start the unit. This should solve the stalling problem. If it presists... the pilot jet will need adjusted. This is absolutely the last resort repair because if you do anything to this screw you must replace the pilot valve screw and cover. It also mandates the use of loctite 638 on the tear drop shaped screw cap. (the old cap breaks off for pilot scre removal.) See check sheet below.
Here is the carb check sheet:
http://www.honda-engines-eu.com/en/images/59139.pdf
This file will download before you can open it.
Thanks for choosing FixYa,
Kelly
Posted on Jun 24, 2011
Leaking water
Can you tell me where it's leaking from.
see link for parts.
http://www.ppe-pressure-washer-parts.com/simpson-ps2600-pressuew-washer-parts
Mar 21, 2014 | Simpson Professional 2600 PSI Pressure...
Im not getting the simpson 3200 psi to shot out water
Give us a all when you. An be at the washer.
http://www.ppe-pressure-washer-parts.com/page/419383926-32577450
Nov 03, 2013 | Simpson PS3200 Powershot 3200 Psi Direct...
My 13.0 honda gx390 motor has no spark and will not start
try disconnecting the black wire which runs across under the fuel tank you should have spark.
Nov 15, 2011 | Simpson Taskmaster Industrial Gas Powered...
How many ounces or quarts of oil do you put in the engine and what kind when changing the oil?
Power washer needs oil 2 places.
The pump head has a plastic window on side of pump. Oil should fill to middle of that window. Pump should have 20 or 30 weight NON detergent oil. SAE20 SAE 30 I believe. Auto parts store will know which is NON detergent.
The engine oil is ordinary 10W30. We used to change oil after each painting season by tilting engine to the side. Do not turn engine on it's side or upside down or oil will run into carburetor.
I don't remember exactly how many quarts we put back. Maybe 2? Fill up reservoir until oil is about half-way up dip stick.
Oct 07, 2010 | Simpson PowerShot Commercial-Duty Gas...
190 honda engine only runs on choke?
pour a large amount of carburator cleaner into the gas tank
run the engine for five minutes then shut it off and let it sit for a couple of days.
then start it and see if it runs any better
the longer you let it sit with the carb cleaner in it, the better it should run
Aug 08, 2010 | Honda 50 W Ar Pump 2500 Psi 25 Gpm...
Garden Logo
107 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
