Question about Orbit Hardware & Accessories
I have an expandable 4 valve orbit timer. How do I CHECK the 2 settings I have made with out actually re setting them?
protek480
  • 1714 Answers
SOURCE: how to set timer on malibu box
Also, make sure to set the dial for the correct time of day.
Posted on Jul 25, 2009
SOURCE: When setting the timer (model 12-817) power is
What timer is this?
http://www.electricsupplyonline.com/prod/intermatic-springwound_timers.php
Sounds like a defective timer.
I have three Intermatic spring wound timers that are used every day, and never have that problem.
After all, how does the timer 'know' when it's set on the 'hour' since the dial does not have stop points at specific times?
Add a comment for more free help.
Also take advantage of fixyas phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Posted on Jan 04, 2011
aquaman987
  • 927 Answers
SOURCE: I have a 6 station
I am somewhat confused about your station numbers. How many stations do you have? What is Ihappening with stations 1, 3, 5, 6?
Regardless, this is probably what is happening.
No matter how many stations you have, YOU ONLY PUT IN ONE START TIME. That one start time begins the cycle that starts with station 1 and proceeds to the other stations based on your station RUN times.
If you have one start time of 6:00 am, and a run time of 60 minutes for each zone, then
At 6:00 am station 1 starts.
at 7:00, station 1 shuts off & station 2 starts.
at 8:00, station 2 shuts and station 3 starts, etc.
You are not programming the individual start times for each station.
If you put in more than one start time, the timer remembers and will run all stations then go back and begin again and if there is a third start time, it will begin a third time.
Gary
Posted on Sep 02, 2011
  • 5245 Answers
SOURCE: I have city reclaimed water source for my sprinkler system. My problem is I connected the waterlines to the solenoid (1) and then the zone index valve (4 zones ), then i wired the solenoid to my spr
What model number of timer? I have to see exactly which timer you have to answer question.
What wire goes where?
Are you using 120Volts?
What is output voltage of timer?
What voltage is solenoid? 24Volt or 120Volt?
Copy following links for Orbit manuals:
http://www.orbitonline.com/support/guides/Manualsearch3.cfm?Brand=02&Type=Timers
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Posted on Aug 11, 2012
  • 5245 Answers
SOURCE: need instruction manual for orbit sprinkler timer model 57196
Copy following link for Orbit Sprinkler timer manuals
http://www.orbitonline.com/support/guides/Manualsearch3.cfm?Brand=01&Type=Timers
Copy following link for various brand name sprinkler timer manuals, including Nelson, Melnor etc if you need new timer
Posted on Sep 11, 2012
I have an Orbit 9 Station Sprinkler System & the manual watering feature isn't working. I replaced the 2 AA batteries & the fuse in the control box but it still won't come on. Can you help me?
Based on my knowledge of Orbit branded products like yours your timer has failed and you need to replace the unit with another more reliable brand. Orbit has real issues with their designs.
Aug 03, 2016 | Orbit Hardware & Accessories
Getting sprinklers to come on
Is it a one way valve? If so you may need to turn it around, if it was just installed from new... make sure that the dust caps are not inside the valve and obstructing the line
Jun 02, 2016 | Orbit Hardware & Accessories
Where can I get a manual for 6 station irrigation timer?
Hi Colleen, The 1st link is a 2 page manual for a 4 & 6 station indoor controller and the 2nd link is a youtube video showing how to program an orbit timer, I hope this helps because you don't give a brand or model number.........CHEERS..
https://www.hunterindustries.com/sites/default/files/IC_EcoLogic_EM.pdf
How to Program an Orbit Easy Set Logic Timer
Apr 27, 2016 | Orbit Hardware & Accessories
How do I cancel old program and reprogram?
Did you check out the instructions that came with your Orbit? If lost download a set from their web site.
Oct 26, 2015 | Orbit 4 Station Sprinkler Timer With Easy...
Orbit Problems
Most likely timer is not plugged in or outlet has no power. Should display a plug with a circle around it with a line through it. If not. Check the wiring be sure the same color wire used for Common in the timer is used in the field. Should have 1 wire from each valve connected to it.
May 26, 2013 | Orbit 58872n Complete Yard Watering Kit
Mod 57880 am setting ok pm setting wont come on ?
Is this new timer?
Or timer that worked before and stopped working?
Check outlet with circuit analyzer for correct polarity and grounding.
Reset timer and re-program, being careful to avoid conflicts and/or overlaps. Each ON time must also have OFF time with consistent days for each. If selected time is 12:00, then use 11:59 instead to avoid possible problems with am and pm conflict.
product comes with 1 year limited warranty.
Orbit digital 57880 sprinkler timer manual is 19 pages long, which is good argument for using analog timers with 1 page manual.
Troubleshoot appears on page 18 of manual, and includes Tech service number.
http://waterheatertimer.org/pdf/Orbit-WaterMaster-57880-Controller-Owners-Manual.pdf
Oct 04, 2012 | Orbit Hardware & Accessories
Aug 09, 2012 | Orbit Hardware & Accessories
Model 57882 9 station timer I did set up station 1 where do I begin in order to set up station 3
Question is not clear.
Do you have programming problem with the timer?
Or problem locating sprinkler heads?
Or a sprinkler valve problem?
Add a comment with detailed information.
Sprinkler timer turns ON-and-OFF.
Timer does not advance the sprinkler to next station. The sprinkler valve advances to next station when timer turns OFF.
For example, when timer turns ON, then station 1 starts watering.
Timer turns off, and then sprinkler valve automatically advances to station 2.
Timer turns on again, and station 2 starts watering.
Orbit resources:
http://www.orbitonline.com/lib/media/InstallationGuide.pdf
http://www.irrigationdirect.com/media/manuals/owners-manuals/orbit/Orbit-WaterMaster-57880-Controller-Owners-Manual.pdf
Aug 02, 2011 | Orbit 57882 9 Station Super Dial...
Hardware & Accessories Logo
66 people viewed this question
Top Orbit Hardware & Accessories Experts
appman67
appman67
 Kenneth
Kenneth
Andrew Taylor
Andrew Taylor
Are you an Orbit Hardware and Accessory Expert? Answer questions, earn points and help others
