Question about Philips E-Box FTR9965 DTV Receiver
Tv cloudy and faces are red
My tv picture is cloudy and it has a red tint adjusted color, picture, tint etc...nothing helps its a philips magnavox model number 9p5511c102 is around 9 years old please help what could it be???
  • 616 Answers
TV needs CRT coolant replaced, once this is done the focus and color level of each CRT needs to be adjusted for optimum picture. expect to pay around $300 good luck, Julio at Millenium TV , Las Vegas NV (702) 736-1091 milleniumtvsvc@gmail.com
Posted on Jul 21, 2009
I have way too much redness in my 60in philips magnavox television...I need to know how to adjust the color and brightness so that the picture shows better!!
Can you give me a model number, if this is a rear projection set you may have a crt/picture tube problem with the liquid. Is the picture cloudy looking and you can't adjust color or tint to make better or pull up menu and if see a glow or hallow around letters and people in picture?
Jul 08, 2011 | Televison & Video
MY PHILIPS DPTV 335 HAS A GOOD PICTURE BUT ITS GOT A HEAVY RED TINT NO MATTER HOW MUCH I ADJUST IT.
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
May 01, 2011 | Philips 55PW9363 55" Rear Projection...
My tv has a red tint to it constantly. Can you tell me why?
  • Screen looks 3D
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 18, 2011 | Philips Magnavox 51MP392H Rear Projection...
My 50 in Phillips rear projection has a bad green tint and switches to a bad red tint what can I do?
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 10, 2011 | Philips Magnavox 9P6034C 60" Rear...
Magnavox rear proj (model# 8p6044 c102) pic is cloudy/green tint
Yes the coolant gets crud buildup in it over time which will cause the color and clarity to get very poor with obects that will glow around certain bright ojects. You can get the Phillips CRT coolant replacement kit from www.tvrepairworld.com which has the CRT coolant for all 3 CRTs and also includes the Cd with instructions on how to do the replacement.
Mar 27, 2010 | Televison & Video
Red and fuzzy picture can you help on my 50 inch phillips magnavox projection TV
This is a very common failure on Projection TV sets.
Screen looks 3D
The other common problem is cloudy lens fluid. After many years the coolant in the blue and green lens will become cloudy and cause the screen to look dull, red/orange, bright white, etc. You may even see halos around video.
You can see some example photos and find a solution here on Fixya.
Nov 25, 2009 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 55P8288 Entire picture has green
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 09, 2009 | Philips Magnavox 51MP392H Rear Projection...
Bad color suddenly appeared on Maganavox 437S 52 " Flat Screen HD
it should have a year warranty get it in for warranty repair before the warranty runs out or someone tells you the wrong thing to go and the tv ends up as a big paperweight...
Dec 28, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Bad color
Your TV most likely has one of two possible problems.
  • Screen looks 3D
Oct 26, 2007 | Philips Magnavox 51MP392H Rear Projection...
Dim picture
If decide to do yourself, ya only have to do the green and blue ones, the red light spectrum won't allow fungal growth. Pull whole CRT assembly out to prevent spilled/leaking glycol from onto lower main boards
Sep 04, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips E-Box FTR9965 DTV Receiver Logo
237 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
