Question about Microwave Ovens
How do you use the power level? - Microwave Ovens
How do I change the power level?
Usually, power level is selectable using the keypad.
Jan 03, 2016 | Samsung 1.8 Cu. Ft. Over-the-Range...
How do I set the power level
Enter the cooking time. Press the Power Level button until the desired level is displayed - Level 1 = 100%, Level 2 = 90%, ... Level 10 = 10%.). Press Start button.
Dec 10, 2015 | Sharp Carousel R530EST Microwave Oven
How do you set the power level
If you have a power level button---press it and then enter 1-0 for 10. Most microwaves automatically come on at power level 10 or Hi power unless you pick a different option like the defrost button which is usually power level 3.
Mar 31, 2015 | Westbend 0.9-cu. Ft. 900-watt Microwave -...
How do I set the power at 50%?
After first setting the cook time---then hit the power level button and hit the number 5 (for 50%) and then start. Power level can also be changed while running by hitting power level button and selecting 1 through 10. For example level 3 is 30% for defrosting.
Mar 20, 2015 | GE Profile Spacemaker XL 1800 36"...
Hamilton beach microwave change power level hp-p100n30al-s3 how do I do that? I pushed the power level button and only beeps does nothing to it
Hit power level button then number 1 through 10. Most have 10 power levels. 1 is extremely low. 3 is usually defrost, 5 would be half power and so on.
Feb 27, 2015 | Hamilton Beach Microwave Ovens
How do i adjust power level
There are no heat levels on a microwave oven, only power levels. I am not aware of any method of checking the power level except to boil water. Boil water at each level and time how long it takes to boil. The lower the power, the longer it should take. If there are no differences in the time, the oven is not functioning as expexted.
Sep 13, 2014 | Haier Microwave Ovens
Unable to adjust power level, the power level button on the control panel does not respond.
Try pressing and adjusting the power level before setting the cook time, or maybe before pressing start. Worked on my Panasonic
Dec 12, 2013 | Microwave Ovens
How do you change the power level?
On most brands, you enter the cook time, then press the "Power Level" key, followed by the using a single digit key for the desired power percentage, then hitting "Start".
EXAMPLE: Too cook for one minute at 30% power:
Time Cook > 1 > 0 > 0 > Power Level > 3 > Start
A possible alternative key combination may be:
Time Cook > 1 > 0 > 0 > Power Level > Power Level >Power Level > Start
Here is a guide to power levels:
May 21, 2013 | Rival Microwave Ovens
How do change the power level?
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
