Question about Dishwashers
Installed the dishwasher, press on/off and it all lights up but then can't select a cycle!!
ginko
  • 19396 Answers
SOURCE: Dishwasher not running
Check door lock, if sensor in there is stuck the machine won't operate
Check also the water level sensor, if it is stuck the cycle wont start.
If the machine is still stuck then it is probably a faulty timer control board.
Before replacing the control board , the inlet valve, impeller, wiring harness, and additional electronic controls must be tested.
Try also unplugging the appliance from main, or tripping circuit breaker to cut power for ten minutes. ~This may unlock a jammed control board.
Posted on May 21, 2009
MNTECH
  • 1543 Answers
SOURCE: WE JUST INSTALLED A NEW MAYTAG DISHWASHER. IT
Check to see if the water valve is turned on. If yes, and still have problem, call for warranty service.
Posted on Aug 16, 2009
mrbobfixit
  • 259 Answers
SOURCE: Dishwasher lights up but won't start
You most likely have a defective door switch or possibly a bad key panel. Frigidaire had a large quantity of door switch failures so I would start there first.
Posted on Jun 12, 2010
Macmarkus
  • 2605 Answers
SOURCE: Dishwasher is shutting off. I select the wash and
Hello Maureen Johnson, welcome to FixYa.
I'll start by acknowledging your post indicates the problem is with your dishwasher not starting/functioning, however if you could post the complete model & serial number I would be better equipped to help you further. If you could also verify it is a Viking (built by Asko) as the header suggests.
I'll look forward to your reply and try and help you move forward from there.
Thank you. Regards,
Macmarkus :)
Posted on Jul 21, 2011
  • 306 Answers
SOURCE: Maytag MDB4651AWS Dishwasher will not start.
Do you ever hear the fill solenoid click on to begin the filling. That is the first thing that has to occur. The water supply generally connects right to that solenoid. Ohm out the solenoid coil. ( breaker power off)
Posted on May 22, 2012
Brand new Kenmore dishwasher and it will not start. The "Locked" light keeps blinking when you try to select a cycle.
To unlock it press on the start button for 3 to 5 seconds, then select your cycle. It locks the same way.
Oct 30, 2015 | Kenmore Elite Stainless Steel 24" BuiltIn...
I have a SHU5305us/u12 and my front door lettering got erase. anyone have a picture or a manual that tells me what each button means.
Cycle Interruption
As a safety feature the dishwasher will automatically turn itself off whenever the door is opened. However, if the door is opened quickly while in a wash or rinse cycle some water may splash out of the dishwasher. For this reason it is recommended that the machine always be switched off before opening the door.
To Interrupt a Cycle
1. Press the on/off button to stop operation.
2. Wait at least 10 seconds (or until the water noises stop) before opening the door.
To Resume a Cycle
1. SHU/SHI models, close the door and press the on/off button.
2. SHV models, push the on/off button and close the door.
Changing a Cycle
For Bosch dishwasher models SHI 6800 and 4320, SHU 5300, 5310 and 6800 press the program button of the desired cycle TWICE. For all other Bosch dishwasher models, press the program button of the desired cycle ONCE. The chosen cycle button (or the light above it) becomes illuminated, showing that it has been selected.
* SHU 3030 and SHU 3130 models do not have program lights.
Cancelling a Cycle
Each control panel shows which buttons to simultaneously push to cancel a cycle. Refer to your dishwasher to find the cancel drain buttons on your particular model.
1. Press the indicated buttons at the same time and hold for approximately 3 seconds.
2. When the drain pump noises stop and the LED display or clean light indicate that the end of the cycle has been reached, the dish
washer is reset.
3. Press the on/off button to turn the dishwasher off.
4. The dishwasher is now ready to run a selected cycle. Add more detergent if necessary.
Dado
Oct 05, 2015 | Bosch Dishwashers
Model #DU1015XTXS2
With the dishwasher door closed and the unit in standby mode or with no cycle selected and all lights off, press - heated-dry, normal, heated-dry, normal buttons in that sequence. Then press cancel..... wait until 2 minute cycle is done. Open and close the door and make sure it is closed. Then run another cycle.
Apr 06, 2014 | Whirlpool Dishwashers
Does this dishwasher have a lock button?
Hello - Yes, it does have a child lock control. It is design to prevent children from accidently change the dishwasher cycle or starting the dishwasher. It locks the dishwasher controls by pressing and releasing the DELAY TIME icon for 3 seconds. Do you see an indication lock light on your dishwasher illuminate? It will usually appear when the controls are locked and no new selections can be made until the lock is released. To unlock the controls, press the DELAY TIME icon under the indicator light goes out.
Oct 13, 2012 | Electrolux EWDW6505GS Fully Integrated...
May 21, 2012 | Maytag Dishwashers
My kenmore dishwasher wont start at all now. It used to start if you pushed certain buttons a bunch of times but now the lights next to most of the buttons light up but it wont start a cycle. any ideas?
Hello
Ensure that the dishwasher is connected to a working power supply. Check the local fuse or circuit breaker and restart as necessary.
Open and shut the door firmly until it latches into place. The dishwasher will not function if the door is not latched into position.
Select the desired cycle and press the cycle button firmly, as you must choose a cycle in order for the dishwasher to begin operation.
Look at the water valve that is connected to the dishwasher and ensure it is turned on.
Turn off the dishwasher and unplug it from the power supply to reset the unit. Plug it back in and select a new cycle. Select "Start." If the dishwasher still does not start, contact an authorized service technician.
Sep 11, 2011 | Kenmore Dishwashers
My Maytag QuietSeries 400 dishwasher won't start. Sometimes 88 flashes on the display and that's all. What does that mean? Model # MDB7601AWB
Dishwasher will not start Is the door open or unlatched?
Make sure the door is completely closed and latched. On models with a dual-digit display, the control displays "- -" during a cycle if it believes the door is not latched. Check for obstructions (spoons, etc), interfering with the door operation. A lower dish rack that is installed backward will also cause incomplete door closure.
Check your household electrical box to see if a fuse has blown or if the circuit breaker has tripped. If the unit has a plug-in power cord, make sure it is plugged in.
Does your dishwasher have a rotary timer knob? (Some Models)
The cycle selection must match the position of the timer knob. Turn the timer knob to the beginning of the preferred cycle. The timer knob should click when you reach the start of the cycle.
Is the control lock option activated?
Press and hold the Heated Dry option (button with lock icon) for three to five seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.
Is the delay start option activated?
To cancel the delay and cycle, press Cancel/Drain.
Has the motor stopped for less than 10 minutes?
The motor may have stopped due to an overload. If this is the case, the motor will automatically reset itself within 5-10 minutes.
Is the Start/Resume indicator flashing?
Opening the door or interrupting the power can stop the cycle. Close the door and press Start/Resume. If the Start/Resume indicator flashes three times when you press Start/Resume, the dishwasher is waiting for you to open the door after the last cycle. Open and close the door, and then press Start/Resume.
On models where the controls are on top of the door be sure to close the door within 3 seconds of pressing the Start/Resume to start or resume the dishwasher cycle.
Is the water shutoff valve (if installed) turned on?
Make sure that the water shutoff valve is turned on.
Jun 19, 2011 | Maytag Dishwasher
My model number is FDB1500LFSO, my dishwasher quit...
Is there power to the dishwasher? Electricaly ground dishwasher. Connect ground wire to green ground connector in terminal box. Do not use an extension cord. Failure to follow these instructions can result in death,fire or electric shock.
Press and hold the Heated Dry option (button with lock icon) for five seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.
If these tips did not work or your controls are not working correctly you may need to schedule service.
May 17, 2010 | Dishwashers
Water is not coming into my Maytag dishwasher.
Is the door open or unlatched?Make sure the door is completely closed and latched. On models with a dual-digit display, the control displays "- -" during a cycle if the door is not latched. Check for obstructions (spoons or utensils), that may be interfering with the door operation. A lower dish rack that is installed backward will also cause incomplete door closure. The lights for cycles selected will flash if the door is opened while running a cycle.
Is there power to the dishwasher?Check your household electrical box to see if a fuse has blown or if the circuit breaker has tripped. If the unit has a plug-in power cord, make sure it is plugged in.
Does your dishwasher have a rotary timer knob?The cycle selection must match the position of the timer knob. Turn the timer knob to the beginning of the preferred cycle. The timer knob should click when you reach the start of the cycle.
The indicator light next to the lock graphic will illuminate when the controls are locked. Press and hold the Heated Dry option (button with lock icon) for three seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.
Is the delay start option activated?To cancel the delay and cycle, press Start/Cancel twice.
Is the water shutoff valve turned on?Make sure that the water shutoff valve is turned on.
Mar 03, 2009 | Maytag 24 in. MDB6600A Jetclean II...
Whirlpool quiet partner III
Hello bckp,
Welcome to Fixya
If your dishwasher does not run or stops during a cycle
Is the Start/Resume indicator flashing? Opening the door or
interrupting the power stopped the cycle. Close the door and
press START/RESUME.
Does the Start/Resume indicator flash 3 times when you
press START/RESUME? The dishwasher is waiting for you to
then press START/RESUME.
Is the door closed tightly and latched?
(NOTE: On models with a dual-digit display, the control
displays “- -” during a cycle if it believes the door is not
latched.)
Is the right cycle selected? Refer to the “Cycle Selection
Charts.”
Is there power to the dishwasher? Has a household fuse
blown, or has a circuit breaker tripped?
Has the motor stopped due to an overload? The motor
automatically resets itself within a few minutes. If it does not
restart, call for service.
It is normal for certain cycles to repeatedly pause for several
seconds during the main wash.
If the dishwasher will not fill
Check the overfill protection float that is able to move up and down
freely? Press down to release.
Let me know if any of these procedures helped you?
Huuum
Please remember to leave a rating.
Oct 04, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
