Question about Kyocera Km-6030 With Feed, Finisher, Bank, Print, Scan - 270k Copies
Kyocera km-6030 printer
I want to print a PDF document, and I cannot get the Properties box to open. I printed several documents the other day, and the Properties box opened and was totally functional. My problem now is not with the printing, but with trying to open the Properties box. Do you know what the problems is, and how I can access the Properties box? Thank you.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Kyocera Expert
  • 161 Answers
Try turning off copier unplug from wall for a few secs or try to restart your computer
Posted on May 04, 2017
marsrover
  • 682 Answers
SOURCE: Troubleshoot/repair of Kyocera KM-1505
1-apply fesh paper it must be out of humidity and wet.
2-confirm smoth motion of optical system.
3-deformed press roller-replace it..
4-paper conveying section drive problem-check the gears and belts and if necessary grease them.
Posted on Mar 05, 2008
  • 40 Answers
SOURCE: Printer will only print page 1 of multiple page documents
1. Check that you are using the latest print driver - from kyocera website.
2. If the issue is when you print pdf files then make sure you set the printer in KPDL Auto mode - check the print driver settings about this and the printer menu.
3.You may check if you have the latest firmware installed within the printer - print a service status page (Menu->Others->Service).
Posted on Jan 12, 2009
  • 17 Answers
SOURCE: printer queue
I have seen things similar to what you describe. Most likely it is due to a PC setting that retains jobs in the queue. Conceivably, if you have a hard drive in the printer, it is a setting that may be corrected by logging in to the printer's IP address. I have not ever seen it caused by the printer, alone.
Posted on Apr 07, 2009
  • 66 Answers
SOURCE: copier km-c2525e will only print 1 page of document
Hi
it might be a long shot but have you got an add toner message on your copier screen.
When toner is required the copier will only print on page at a time.
Alternately you should ensure that you have not selected a partial print  eg
print current view or print current page.
if all this fails, reload the driver and or your Acrobat reader
hope this helps
Posted on Aug 16, 2009
Gort007
  • 1187 Answers
SOURCE: how to print 11 X 17 documents using a Kyocere CS 2550 printer
Use this method:
[File]
[Print]
Select the printer from the list and click on [Properties]
Change the "Original siae" to "11x17"
Change the Output size from "Same..." to "8.5x11" or "8.5x14"
[OK]
[OK]
Posted on Sep 29, 2009
When I print it prints a code description of the document rather then the document
You need the proper print drivers. Download the drivers and update or re-install your drivers
Mar 13, 2014 | Kyocera Mita KM-2550 All-In-One Laser...
Kyocera KM2550 printer prints test page but cannot print word documents and pdfs
Try loading paper in the bypass on the left hand side of the machine.It may be that you are trying to print a document that is a different size to the paper that you have loaded in the copier.
Jan 13, 2014 | Kyocera Mita KM-2550 All-In-One Laser...
Printer usb port back computer
http://la.kyoceradocumentsolutions.com/americas/jsp/upload/product/15477/0/KM-1635_WebSpec_Eng.pdf
According to this document, there is one option to purchase an Optional IB-110 External Print Server connected via USB,
However this model is discontinued... :(
You could look on ebay, or amazon or wherever to find the optional print server that you need...
Sorry.
Happy New Year!
Topbarhive
Jan 02, 2014 | Kyocera Office Equipment & Supplies
I've got an HP Photosmart C5380. How can I get smaller PDF scans? they are all so big, even one page, and if I reduce the PDF resolution they are unreadable. Is there any other way? I know there's a ...
  1. Open the document that you want to print. Click File , and then click Print . The Print window opens.
  2. Click the button that opens the Properties dialog box. Depending on the software program, the button might be Properties , Options , Printer setup , Printer , or Preferences .
  3. In the Properties dialog box, select the print properties for the current print job, and then click OK .
Oct 26, 2010 | HP Photosmart C5380 All-In-One Laser...
KYOCERA FS C5030N PRINTS ONLY THE FIRST PAGE OF A PDF DOCUMENT. IT SPOOLS THE # OF PAGES IN THE DOCUMENT BUT ONLY PRINTS THE FIRST PAGE.
make sure you are using the KX PRINTER DRIVER first
if so..
tray changing the pdl format
in the printers and faxes area right click on your printer
right click go to properties.
click on device settings tab (you have this if you are using the KX driver)llhopefully you are
you will see a button (pdl) click on pdl
changed pdl to pcl5e
good luck
Feb 10, 2010 | Kyocera FS-1030DN Printers
Can't print entire pdf documents only first page.
There may be a few possible things for your to try. Below is the list of things you can try.
1) Reinstall the PDF software that you use to open your pdf documents. (reader or acrobat) *restart machine after reinstall.
2) Remove the printer from your list of printers and faxes then add it back again
3) Restart the spooler service
click start -> run
type services.msc then ok
on new window, look for print spooler, right click and select restart service.
May 29, 2009 | Kyocera Mita FS-C5016N Printer
Kyocera Mita KM-2530 Laser Printer will only print the first page not the rest.
Try changing print driver and switch emulation to kpdl auto if not already there. If this doesn't work go to properties on driver under font and switch to bit map. Don't do this step unles yo have to it really slows down your printer.
May 29, 2009 | Kyocera Mita KM-2530 Laser Printer
Log into your pc as admin and under the driver properties change from kpdl to pcl5
Its a combo of a problem with adobe reader and the KPDL driver
Apr 23, 2009 | Kyocera Mita KM-2530 Laser Printer
Printing problems Kyocera KM 2050
try setting the driver to KPDL mode in the settings section of the driver
May 07, 2008 | Office Equipment & Supplies
MAC problem with km-3050
What MAC OS are you using? I don't remember for OS 9 and earlier but if you are using OS X I can help you out. First make sure you are using the latest version of the print driver. When you open a document to print and select the Kyocera printer you will see the print dialog box. You need to look under the printer specific options to find the job accounting. I believe it is under set 2.
Hope this helps.
Henry
Mar 25, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
Kyocera Km-6030 With Feed, Finisher, Bank, Print, Scan - 270k Copies Logo
65 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
