Question about The Music
What year was the Lowrey GX Series Model GX 325 G-700 built?
Where can i get owner's manual for lowrey rhapsody organ for free
direct by request, top left.
Product Literature Lowrey
full system reset details in case you ever need it
lowrey rhapsody problems
Jul 24, 2017 | Music
Need to download an owners manual for a Model TP-44 Lowrey Organ
Try Googling (lowrey)(TP-44)(manual) without parens.
Jul 19, 2017 | Music
Where can I buy a tube or bulb part number 1591AEH for a Lowrey organ model number MSO227082
Run that on Google and see what you get...Always run this stuff on Google before posting, as it usually returns useful stuff. Here is didn't... I ran a few, but only got a hit on "lowrey organ" as the manufacturer site. You could send them an e-mail, via the 'contact us' link. I didn't hit on any parts for that device...
Jack
Jun 02, 2015 | Music
I have a lowrey m-375 organ. The lower keyboard works sometimes and other times it just doesn't make any noise at all. Very rarely the upper keyboard cuts out but never for long, any ideas? thanks
These older units like this usually inherit intermittent problems like this from sitting up and gathering dust. There are many switches and relays inside this model, and other electrical connections that would get dirty or corroded over the years. I think a good professional servicing would fix this.
Mar 28, 2014 | Music
Lowrey L65 restoration
Try going to the
organforum.com
Feb 17, 2010 | Music
Lowrey organ C# and D# on both keyboards don't work. Fixable?
We can only guess what model you might have and whether it is tube or solid state.
If it is a vacuum tube type, probably one tube is burned out... likely either a 12AX7 or maybe a 12AT7 as a guess.
If it is solid state and the unit has not been moved to cause a loose connector, better to call a tech. If it has been moved, you could look for a loose connector.
Feb 01, 2010 | Music
Lowrey catillion organ with loud static noise
Try posting on the organforum.com.
It sounds like the power amp has a problem. Probably filter capacitors have gone bad.
Oct 24, 2009 | Music
Need a fuse for a lowrey-genie organ-44
If the fuse blew, it is for a reason. Probably shorted filter capacitors.
Oct 13, 2009 | Boss Micro BR Digital Recorder
Need Lowrey Organ Manual
Here you go. this is the web site that will fix you up.
http://www.lowrey.com/contact.aspx good luck DFD
please rate me TK U
Apr 08, 2009 | Music
Music Logo
46 people viewed this question
Top The Music Experts
drivealot
Kyle Steven OHare
Kyle Steven OHare
gbob59
Are you a The Music Expert? Answer questions, earn points and help others
