Question about Air Tools & Compressors
Paslode im360ci red light stays on and not making any noise?????
Paslode
Make sure that you dry the top of the motor housing and connections.Make sure that the piston is up as far as it can go.
When you depress the nose against the work the motor should run and if you look at the flashing light on the side it will stay constantly on and momentarily flash when you pull the trigger. If it goes red then check the battery is charged otherwise there coiuld be a fault with the motor.
Is the inlet Valve facing the correct way with the bottom of the "V" facing down into the machine.
Check the date of the gas, make sure it is not out of date.
Is the gas cold? warm the cylinder up by putting it in your trouser pocket for 10 min. Paslode make winter gas for these cold days.
Jan 10, 2013 | RTO PasLode 900420 Impulse Framing Nailer
When the trigger is pressed the light on the handle flashes green and red intermittently and nothing else happens. any ideas?
Hi,I believe that is a battery issue...either it is run down or not charging properly...
Here is a tip that I wrote about the Paslodenailers and the problems that can come up with them.
I also have a link to the Paslodemanuals which contain Paslodecleaning and troubleshooting guides.
If you need parts for your Paslode,there also is a link for a site that sells the Paslode nailer parts.
PaslodeCordless Nailer Problemsheatman101
Sep 18, 2011 | RTO Paslode 902000 IM250 Ii Cordless 16...
Paslode 350 nailer wont work , push to fire fan works for 2 seconds then light flashes from green to red
Sounds like a battery contact problem or a bad battery..
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Feb 17, 2011 | Dewalt D55141FNBN HeavyDuty 16Gauge Finish...
Red light stays on as if battery is flat.
Check battery contacts...
heatman101
Dec 12, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Flashing green and red light by the trigger ,what does it mean
heatman101
0-
Oct 29, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Red light comes on
heatman101
Oct 26, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Hi .my im350 nail gun isnt working gas and battery ok and gun is cleaned.light on green .but when depresssed makes strange noise and lights on fire from fan end?
heatman101
Oct 24, 2010 | RTO PasLode 900420 Impulse Framing Nailer
My IM65 light flashes green then red, fan seems to be working and the gun does fire
heatman101
Aug 30, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
My im65 palode has stopped working,the red and green light if flashing,What could be wrong?
heatman101
May 14, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
Air Tools & Compressors Logo
129 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
