Question about The Watches
The gears of my watch stopped, the dial stopped working but the digital clock still works what do I do
    Top Expert:
  • The Master
  • 48,555 Answers
Perhaps wind it .or take to jeweler for repairs
Posted on Dec 22, 2016
Large clock and second not working
probably needs a new battery these watches have two batteries
May 01, 2013 | Kenneth Cole Mens Gunmetal-Tone Watch...
How to use the subdials on a wrist watch
One of them is the seconds hand of your watch, this sub dial will keep on moving even if the watch is not used as a stop watch. the other 2 sub dials are for the stop watch function. one is for tracking the minutes and the other is for hours. the big seconds hand will only work if you use the stop watch function. you can reset your stop watch to zero by pressing the pusher located at the 4 o,clock location of your watch.
Oct 20, 2012 | Rolex SS/18kt Daytona
How it works invicta clock mechanism ?
Your watch is battery powered or a 'quartz' watch. It is commonly refered to as a 'chronograph'. That is another word for stop watch.As well as telling time and the date, your watch can time how long an event lasts. For example, a horse race. You start the chronograph or stop watch when the horse starts and stop it when it crosses the finish line. When the next horse starts you need set it back to zero to time the next race.Operation is simple. The upper push button starts and stops the chronograph. Try it. Now with the chronograph stopped, push the bottom button. The hand return to the 12 o'clock position or the 'zero' position. Also notice the small dials on the dial or face of the watch. They record minutes and other increments of time. The large hand going around when you push the upper button is recording seconds. Hope this helps, Michael
Oct 09, 2012 | Invicta Lupah Collection Chronograph #9813...
I have model fs-2919 would like to know what the other dials are for i dont have the booklet thanks for your help
The three small dials on this watch are all part of a "stopwatch" system. The small dial at the 12 o'clock is for tenths of a second( each half circle completed is one second or 1 whole rotation equals 2 seconds.) the small dial at the 6 o'clock counts a full 60 seconds for each revolution, and the dial at the 9 o'clock counts minutes(one full circle equaling an hour.) when the stop watch is started the 12 o'clock and 6 o'clock dials will start at the same time. you will notice that every half turn on the top dial equals one "tick" on the bottom dial. After the first minute of timing the top dial will stop ticking as it is for more precise timing of things that take less than 1 minute. each full rotation of the bottom dial will then equate to one "tick" of the 9 o'clock dial. hence the three dials counting tenths of a second, seconds and minutes. the setting of these dials is fairly easy once you understand the purpose. on the side of the watch there are two buttons(one top and one bottom) with a setting wheel in the center. When in use the top button starts and stops the stopwatch and the bottom button resets the counters. To set the watch simply pull the center wheel away from the watch all the way(2 clicks) set your minute hand and hour hand and then tap the bottom button repeatedly until the small dials all line up straight up. once that is done push the center wheel button halfway into the watch or one click to set the date. then simply push the wheel the rest of the way in and voila!!! hope this answers some questions
Apr 05, 2011 | Fossil FS2919 Wrist Watch
What are the 3 inner dials for? How do I set them?
one of them is the seconds hand of your watch, this sub dial will keep on moving even if the watch is not used as a stop watch. the other 2 sub dials are for the stop watch function. one is for tracking the minutes and the other is for hours. the big seconds hand will only work if you use the stop watch function. you can reset your stop watch to zero by pressing the pusher located at the 4 o,clock location of your watch.
Nov 09, 2009 | Rolex Daytona 116520 Wrist Watch
ADJUSTING ANALOGUE CLOCK
Keep pressing 'select mode' button until you get to H-SET. Than hold 'adjust' button until screen starts to blink. Now you can adjust analog clock by pressing 'start/stop (search)' button. When you are finished, just press 'adjust' button once. That's all.
Feb 18, 2009 | Casio AQ163WG 1BV Casual Sports Watch with...
Timex expedition problem
You probibly need to have the anologe serviced. It isn't like the old days when watches had a mainspring which, when you wound it the gears would push by anything that got in the gears way because of the pressure form the mainspring. Now with quartz watche ANY little thing ( dust sooo small) will stop the gears from running. I would take the watch to a reputable watchrepair and have them check the battery. DO NOT ask them to sell you a new battery just CHECK it. If you get a new battery, it the watch probibly will run good again for about 3 weeks , and then start acting up again, because a new battery might have enough power (at first) to get by the watches problem untill it uses some energy up. But if your battery is bad that to could cause this , but that is highly doubtful that is the problem.
If you still have a problems please let me know I will be glad to assist you!
Aug 18, 2008 | Timex Expedition 84601 Wristwatch
The watch stops instead of the chrono
On this type of watch the second should not be working unless you are in the chrono mode. The lower dial should be the only indication of the seconds when not in chrono mode. You probably need to have the chrono reset and shown how the functions work. Try a Fossil location they will be able to tell you how to work this watch. It does not sound like this is a major problem.
Dec 03, 2006 | Fossil FS3105 Wrist Watch
Watches Logo
18 people viewed this question
Top The Watches Experts
D. E. Hev
John mullen
Are you a The Watch Expert? Answer questions, earn points and help others
