No is tab on button works, it gets you as far as the go sybolm and stops there nit allowing me access the window that all the icons
  • Bob Buckley Dec 26, 2016
    Hi Alfonso , I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Can't understand. Please write in your native language.
    BobB
2 Suggested Answers
jonsnell4
  • 25276 Answers
SOURCE: Windows ce eznotebook cant get through the
You must type the correct password first.
Posted on Jun 10, 2014
How do I remove facebook from my phone
On many phones, you can do it one of two ways.
Method 1: Place your finger on the icon and hold it until it selects and allows you to move the icon around. From here, you should see an "uninstall" tab with a trashcan icon appear at the top of the phone. Drag the icon of the Facebook application onto this tab to uninstall it.
Method 2: In your phone's settings, go under applications and find the Facebook application in the alphabetical list. Once located, tap the application to access its details. On this screen, you should see an "uninstall" button. Tap this button to uninstall the Facebook application.
Nov 26, 2016 | Facebook Computers & Internet
Tip
How to convert thumbnail into ICONS in windows 8 interface
First time I installed windows 8 i faced that problem that in place of icon it was showing only thumbnail. So here goes the solution to convert thumbnail into icons in windows 8 interface-
Open up the folder with the pictures and click on the View tab
Next click on Options to the far right
Then Click on Change folder and search options
This opens up an options menu
Navigate to the view tab
uncheck the box that says Always show icons, never thumbnails
And Check the box that says Display file icon on thumbnails.
This should solve the problem. It worked for me.
on Apr 13, 2015 | Microsoft Windows 8.1 - Windows
Tip
How To share a ADSL Connexion with 2 computers
Introduction
It is about sharing the ADSL connection from PC1
(Server) with PC2 (Client).
Assume that the connection to the Internet
configured correctly in the PC1.
* ) Hardware Requirements
A PC running Windows XP and equipped with a network card
(Server).
Internet access.
A second PC with a network adapter (client PC).
RJ45 crossover cable
*)Configuring Server Side
1. Assign an IP address
Click on Start / Control Panel / Network Connections
and Internet
Double click the Network Connections icon
get a new window
Click on the icon Local Area Connection with the right button
your mouse and select Properties. A new window appears
Double click on Internet Protocol (TCP / IP) a new window
appears
2. Share the connection.
Back in the Control Panel and select
Connections.
Then in the window that opens right click
your Remote Access (for example ADSL) and select
Properties option.
A new window appears:
Select the Advanced tab under Connection Sharing
Internet check Allow other network users to
connect through this computer's Internet connection and the
Establish a connection box Dial whenever
computer attempts to connect to internet and confirm by clicking
OK. A new window will open:
To Continue Click Here : .....More
on Jul 15, 2010 | Computers & Internet
I can only get 2 of 3 tabs
Turn nit off of green rectangle and check again
Jan 18, 2013 | Canon Powershot A1000IS Digital Camera
I recently bought a Sylvania 7 inch netbook sold at CVS.\r\nIt states to activate WI Fi to click on wifi icon on bottom right of screen. If icon is not available to press FN + F9 When I press FN+F9...
Your OS should have an icon on the desk top that says WIFI Power, it is blue in color and this icon turns the WIFI on and off. When the button says off, the WiFi is on, the idea is that it is waiting for you to turn it off. If that is not on your desk top, turn the machine over and look for a small hole 1in diagonally right of the data plate. insert a tooth pick in that hole a depress gently to reset your machine.
It is looking for a password (WiFi Network Key) You have to double click on the little computer icon down in the right tool bar area, the one with the two side radiating arcs, and possibly has a small red X under it. The red X indicates that it is NOT connected. When you double click on that icon a window called RT28701 opens up, then you click on Wireless Information tab, then you cursor down to the name of your WiFi and high light it and click the connect box. Then another window opens up called Network Properties. Uncheck "The key is provided automatically" box. This will allow you to type in your "Network Key", the password that protects your network from outsiders. This "KEY" was set up when you installed the router on your server computer. If this does not work at first, turn the machine over on it's back and using a toothpick, insert it into the little hole about an inch diagonally from the right corner of the data plate, this will re-load a new copy of everything including the WiFi RT28701 driver.
sometimes this driver gets confused. See my TIP at: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing
Dec 28, 2010 | Sylvania G-Netbook
Tip
Shortcuts tricks for Windows Vista(Keyboard shortcuts)
Following are some of keyboard shortcut tricks for Windows Vista and also for Windows XP:
  • Window key+B: Sets focus to first icon in the notification area. You can use arrow keys to move among the icons in the notification area or press Tab to move around on the task bar.
  • Window key+D: Show Desktop (without the Sidebar).
  • Window key+E: Windows Explorer (opens to Computer).
  • Window key+F: Find Files or Folders (aka Search).
  • Window key+M Minimize All windows (Sidebar not included).
  • Window key+Shift+M: Undo Minimize All Windows.
  • Window key+R: Open the Run dialog box.
  • Window key+Tab: 3-D Flip (flips you through your applications but with a cool graphic instead of the standard Alt+Tab). Requires the use of the Aero user interface.
  • Window key+Pause/Break: System Properties.
  • Window key+F1: Windows Help.
  • Window key+L: Locks workstation. If the user account has a password, it must be reentered to unlock the system again.
  • Window key+U: Ease of Access Settings.
  • Window key+ Spacebar: This shows the Sidebar (the Sidebar must be open, but minimized).
  • Ctrl+Window key+Tab: Brings up Flip-3D, but it will stay on the desktop so you can scroll up, down, left and right.
  • Window key+T: Allows you to tab between application buttons on the task bar.
  • Ctrl+Shift+Esc: Opens Task Manager more faster than alt+ctrl+del.
  • Alt+Tab: Windows Flip. Allows you to choose an open application to switch to by repeatedly pressing the Tab key.
  • Window key+5: opens the snipping tool.
Some User Logging Shortcuts:
  • Window key (and then) three right arrows and Enter To Shut down
  • Window key (and then) three right arrows and U To Shut down
  • Window key (and then) three right arrows and R To Restart
  • Window key (and then) three right arrows and W To Switch Users
  • Window key (and then) one right arrow and Enter To Sleep
on Jan 16, 2010 | Microsoft Windows Vista Ultimate Edition
Icon changing to generic windows
Steps for Changing a System Icon:
BEFORE YOU BEGIN!
Right-Click your desktop and choose "Properties". Then follow the steps below.
1. Click on the "desktop" tab at the top of the Display Properties window.
2. Then click the "Customize Desktop" button.
3. A Desktop Items window will open. Choose the "General" tab.
4. From the dsplay of system icons, click on the icon you want to change making sure it's highlighted.
5. Click on the "Change Icons" button. This will allow you to browse your computer for the icon you want to use as a replacement for your System Icon. (remember to click "OK" and "Apply Changes" once you have chosen a new icon).
Jan 30, 2010 | Microsoft Windows Vista Ultimate Edition
I use my nokia N70 for connecting my pc to internet.I connect my phone through both bluetooth and usb.I connect to internet using one touch access.I had no problems at all in the past.But recently i have...
We want to change the properties for our connection to the internet. This is the adapter we want to share "from". Just right-click in the corresponding icon and select Properties.
The Bluetooth Network adapter was automatically created during the Bluetooth installation.
There's a bug in Windows 2000 before SP3 where changing the sharing option may change IP configurations in this adapter. To make sure you're safe, we will note the current configuration.
In the General tab select the Internet Protocol components and click Properties.
Write down all the information from the next dialog, and click Cancel.
Back in the Adapter properties, select the "Sharing" tab and tick "Enable Internet Connection Sharing for this connection".
Now, to configure the Bluetooth USB, right- click the Bluetooth icon in the system tray and select Advanced Configuration.
Change to the Local Services tab and double click "Network Access".
Change the type of service to "Allow other devices to acces the Internet/LAN via this computer".
The alternative to this option will allow your device to connect to your computer as part of a LAN, but will not have internet access.
Note the Configure Connection Sharing button: it'll open the configuration screens we've visited before. But some Bluetooth software will not have this button, hence I guided you through the other route .
Now, on your Pocket PC... Tap the Bluetooth icon the the status bar and select Bluetooth Manager.
You'll see your notebook or desktop here, and if it's out of range a question mark (like in the mobile icon in the picture).
Tap the icon corresponding to your computer or notebook.
If the computer does not show here, the devices are not paired! Go back and pair then.
Tap the Actions menu option.
Tap the "Connect to Network Access" option.
If all is ok, you'll see the message "Connected for Network Access" here !
Just start using your favorite programs... ICQ, Pocket Outlook, MSN Messenge, Pocket Internet Explorer .
Yes, visit the Geekzone mobile, or browse the internet from the sofa...
"Hmmm, what's on the movies tonight?"
If you tap the Bluetooth icon in the status bar again...
You'll see the computer or notebook is connected .
To disconnect, simply tap the connection icon in the status bar, and tap the Disconnect button.
And this is the result of disconnecting...
To check your connection from the desktop or notebook, double-click My Bluetooth Places, and open My Device.
The icon in green show which Bluetooth profile is in use right now. Right-click My Network Access, and select Properties to see its current status.
That's it!
Jun 22, 2009 | Nokia N70 Cellular Phone
Logitech mouse problem
I assume there is no second mouse on the system and you are using keyboard commands. Try the following in the device manager..
  1. Press Control-Esc or press the Windows key on your keyboard to bring up the Start menu.
  2. Using the up arrow key, highlight "Settings."
  3. Right arrow key to "Control Panel" and press the enter key.
  4. Use the arrow keys to highlight the System icon and press the Enter key.
  5. Use the right arrow key to select the Device Manager tab. (For Windows XP/2000 , use the right arrow key select the "Hardware" tab. Now use the tab key, select the "Device Manager" button and press the enter key.)
  6. Use the "Tab" key to select the "Computer Icon" at the top of the list of device icons.
  7. Use the down arrow key to highlight the Mouse icon.
  8. Use the right arrow key to open the mouse icon and verify there is a mouse icon that states, "HID-compliant mouse," and another entry that states the name of your USB device.
  9. If there are any errors reported on these icons by exclamation points or red X's, highlight these icons using the arrow keys and "Tab" to the "Remove" button and press the enter key. (For Windows XP/2000 , highlight these icons using the arrow keys and then press Alt-A keys. From the "Action" menu, highlight "Uninstall" and press the enter key.) When the "Confirm Device Removal" box appears, press the enter key.
  10. Once these icons have been removed, use the Tab key to get to the "Refresh" button and allow Windows to re-detect the pointing device. (If u r using Windows XP/2000 , press the Alt-A keys. From the "Action" menu, select "Scan for hardware changes" and press the Enter key.)
  11. Use the arrow keys to open the Mouse icon again and verify that there are no errors reported.
  12. Power down the computer system and restart Windows.
Apr 16, 2008 | Logitech diNovo LX300 Keyboard/Mouse
Can't print landscape?
Make sure the correct printer driver is installed.Check your user guide.Read the information below.
Printer Settings
You can use the printer properties window, which allows you to
access all of the printer options you need when using your
printer. When the printer properties are displayed, you can
review and change the settings needed for your print job.
Your printer properties window may differ, depending on your
operating system. This Software User’s Guide shows the
Properties window for Windows 98.
Your printer driver Properties window that appears in this User’s
Guide may differ depending on the printer in use.
If you access printer properties through the Printers folder, you
can view additional Windows-based tabs (refer to your
Windows User’s Guide) and the Printer tab (see “Printer Tab” on
page 10).
NOTES:
• Most Windows applications will override settings you specify
in the printer driver. Change all print settings available in the
software application first, and change any remaining settings
using the printer driver.
• The settings you change remain in effect only while you are
using the current program. To make your changes
permanent, make them in the Printers folder.
• The following procedure is for Windows XP. For other
Windows OS, refer to the corresponding Windows User's
Guide or online help.
1. Click the Windows Start button.
2. Select Printers and Faxes.
3. Select your printer driver icon.
4. Right-click on the printer driver icon and select
Printing Preferences.
5. Change the settings on each tab, click OK.
Layout Tab
The Layout tab provides options to adjust how the document
appears on the printed page. The Layout Options includes
Multiple Pages per Side and Poster. See “Printing a
Document” on page 6 for more information on accessing printer
properties.
Orientation
Orientation allows you to select the direction in which
information is printed on a page.
• Portrait prints across the width of the page, letter style.
• Landscape prints across the length of the page, spreadsheet
style.
• Rotate allows you to rotate the page the selected degrees.
Layout Options
Layout Options allows you to select advanced printing options.
You can choose Multiple Pages per Side and Poster.
• For details, see “Printing Multiple Pages on One Sheet of Paper
(N-Up Printing)” on page 12.
• For details, see “Printing Posters” on page 13
Jan 16, 2008 | Samsung ML 2010 Laser Printer
Computers & Internet Logo
David Payne
David Payne
