Question about Cell Phones
How do i reprogram a new number for a shortcut
  • kakima Dec 22, 2016
    Hi Susan , I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and midel phone?
I have a 2008 Dodge Avenger how do you reprogram the computer had to replace it got one from junk yard the vin. Numbers are the same except the last 3 numbers it will not start
Unfortunately, new generation cars and trucks are very specific about everything. From how the engine burns gas to air on your tires... Your ECU has to be reprogrammed to your vehicle specifics to include vin number, air bags, abs, mileage, etc... Good luck!
Nov 30, 2015 | Dodge Cars & Trucks
When i select my programmed check voicemail button i get an error of "not in service". how do i fix this and re-establish it as the check voicemail shortcut?
Try Feature *3 - press the button you had programmed of check voice mail - the press Feature 981. This should reprogram your button.
Aug 20, 2013 | NorStar T7316E Corded Phone
How to do the relearn/reset after replacing ecm in 2001 monte carlo
DEALERSHIP HAS TO REPROGRAM THE NEW PCM.YOU NEED A GM SCANNER TO REPROGRAM NEW PCMS IN GM VECHICLES THE GM VECHICLES FROM 1996 UP TO 2011 HAS TO BE REPROGRAM AT DEALERSHIP, HOME MECHANIC CANT REPROGRAM IT.YOU NEED GM TECH 2 SCANNER.
Aug 01, 2011 | Chevrolet Monte Carlo Cars & Trucks
If I replaced the PCM on the 2005 dodge ram truck would I have to reprogram the keys to make the truck run?
If you key has a chip in it, you will probably have to get your ECM reprogrammed with the proper VIN, since it no longer matches the original VIN on your Vehicle. I don't think the dealer would program your keys to a mismatched VIN number, so more than likely you will need your ECM reprogrammed with the proper VIN. This will need to be taken to the Dodge Dealership to be fixed.
Mar 14, 2011 | 2005 Dodge Ram 1500
How to program this unit
do you mean reformat or reprogram???
Go into Menu, Settings, Phone Settings, Shortcuts and you can reset things from there...
Feb 10, 2011 | Samsung SGH-D900 Cellular Phone
What is the number if i will reprogram my cellphone through their keypad only?
*#7780# (*#rst0*) - This will soft reset your phone. It is different from *#7370# because all data, like contacts, calendar and notes, are not removed.
It will only reset the phone settings, such as profiles, themes and shortcuts.
The default lock code is 12345.
Dec 14, 2010 | Nokia 6600
Dear Sir or Madam I have renault scenic expressions 2005. manual gearbox 1.6 the problem i have is that one of the keys for the car works fine, but the spare key i have for the car only opens the cars...
You have been informed correctly. All you can do is to shop around and also to try independent automotive locksmiths as £150 for programming is a bit steep. If the price is for a new card AND reprogramming then it's a fair price as the cost is often over £200.
Sorry, but there are no shortcuts or quick fixes for this: if there were it wouldn't be a good security system.
Jul 28, 2010 | 2000 Renault 181
New Computer Won't Switch Back
can you reprogram the KVM switch to use different keys?
Dec 03, 2007 | Belkin F1DL102P 2-port KVM Switch
Sharp 32L-S400 Parental Programing
There are two ways to solve this problem 1 enter menu and remove old code and replace with new one, 2 reprogram eprom
Aug 01, 2007 | Sharp 32L-S400 32" TV
Cell Phones Logo
22 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
