How to get rid of soap opra screen on sony xbr75x850d
How do i rid of fruit flies in my plants
I've had the same problem and was able to get rid of the fruit flies using the following method.
First, sprinkle diatomaceous earth on the dirt in the plant pots. Diatomaceous earth is all natural and non-toxic, but it will kill the fruit flies.
Here's a link for killing bugs naturally with diatomaceous earth:
How to Get Rid of Spiders Naturally with Diatomaceous Earth
Next, make a mild soap and water solution, pour it in a spray bottle and spray the plants. Make sure the solution is mild because if it's too strong it will affect the plants.
Here's a link for the homemade insecticide soap recipe:
How to Make Homemade Insecticidal Soap for Plants Today Homeowner
The combination of the diatomaceous earth and insecticide soap will take care of your fruit fly problem. It will probably take about a week or so for all of the fruit flies to die, but if you're vigilant you'll take care of the problem.
Sep 18, 2014 | Cooking
Tip
Laptop or Monitor Cleaning
LCD and plasma screens have a anti-glare coating or anti-reflective coating. This is so any bright light doesn't reflect and wash out the picture. It does help but it also makes cleaning the screen a bit of a problem.
As this is a coating on glass it is actually possible to clean t off by using the wrong cleaner. There are great glass cleaners out there but most are chemically based and too aggressive. In other words they attack the coating.
So what do you use? Paper towels, a drop of dish washing or liquid soap and water. And you need to use a bit of a technique or you will see smears or smudges on the screen.
You need to get two sheets of paper towels. One is your dry wipe. Wet one with water. Then add a drop of liquid soap or detergent. Give it a couple of gentle squeezes to distribute the soap. Then give it a bit harder one to get rid of excess water. Depending on the coating you may want a second piece that has only water and just damp not wet.
Now we clean the screen. First take the soapy towel and wipe down the screen getting it wet. You don't want running water just enough to wet the screen. If you have the soap right you will just see the odd bubble. Once you have the screen wet, wait about 30 seconds and now scrub it using the soapy towel with a circular motion. If there is anything on the screen it should come off. If something is stubborn just keep scrubbing it or use a fingernail to scratch it off and wipe with the soapy after.
Now we need to get the soap off. If the screen dries and has streaks you may need to use the wet un-soaped towel to wipe/rinse of the soap before drying. To dry the screen we want to use the dry towel and use large circular motions. Go over it once and turn it over so the dry side is being used. Keep using those big round motions and at the same time ease up of how hard you push the towel. The idea is to have little pressure on the towel as you finish. That's the trick to getting it streak free.
This takes a minute to do but lets you safely clean your display without damaging the coatings. It also works on any glass surface.
on Jul 07, 2010 | Computers & Internet
Tip
How to clean your screen (TV-Laptop-Monitor)
on Apr 16, 2010 | Televison & Video
Dishwasher soap is not dissolving.
Try emptying the dishwasher and putting a few tablespoons of vegatable oil in the bottom. Run the cycle without soap and no dishs. Often dish soap (palmolive) builds up and creates soap suds that won't go away during a normal cycle. The oil binds with the soap residue to get rid of it. It worked for my Kenmore. I know do it every few months. Good Luck!!!
Thanks
Jun 22, 2011 | Kenmore 13742 / 13744 / 13749 Built-in...
Can't get rid of the soap...
One buy dishwasher cleaner or run bleach in it. But the reason why is because of hard water the hard water makes the soap stick to everything. And you might be using tomuch soap only use the main side not both and make sure you us jet dry. But the beat thing you can do buy water sofiner and then you can us even less soap and it will clean better and save the life of your dishwasher. Look at the film you can see, now think about the film you can't it's pritty sick
Apr 29, 2010 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
How do you get rid of the red screen of death?
This is called the "PS3 Red Screen Of Death" it's the same as the 360's RROD. The best solution would be to contact Sony about it and they should resolve the issue. It's generally a hardware issue.
Jan 06, 2010 | Sony Playstation 3 (PS3) Console
Split screen question
Ah split screen just another way of getting two picture in one screen, or sport for he and Opra for her.
Fisrt you must understand what split screen is, it is taking two information from different source and sending the info to the micro to devide the info for two seperat image.
Well something like that but I know you were inpress,
Yes you can. Take the main source you or using I would say the TV box in cable connection or av1 and then your DVD or and VCR to source av2 or 3. When presing split screen or pip you will get one screen showing the main source your tv box and the second your dvd (or VCR) in the source input solector you should be able to change the second amage input with input solector and the tv box change the other.
Oh what a butiful life aint it.
Try this with 7 different source, Cable, satelite, fta, dvd, camera, gaming sytem, and computor,... well that another chapter.
What about Bob
Feb 29, 2008 | Panasonic PT-50DL54 50" Rear Projection...
Kenmore built in mf#15254
check the sump screen and make sure theres no obstructions.are the wash arm holes clogged?is the drain hose clogged?
Aug 13, 2007 | Kenmore 24 in. 16293 Built-in Dishwasher
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
