Question about Masonry Tools
Oops! i need a crank handle for a mastercraft 12.5 in. thickness planer. i was told to call the 1 800 number in the owners manual but i cannot find mine.does anyone out there have this number?
2 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: Need a user manual for mastercraft thickness planer
I'd suggest calling 1-800-689-9928 and speaking with one of the customer service representatives
Posted on Dec 15, 2008
How do I download dewalt 733 manual?
Try Googling (DeWalt)(733)(manual) without parens.
Apr 27, 2017 | Dewalt Drills
I am looking for parts for a mastercraft thickness planer and was directed to this site...can you help?
I would suggest searching on line for your make and model of tool, you might be able to find an operating manual that should give you information for where to go for replacements.
Jan 08, 2017 | Crafts & Hobbies
Owners manual for a dewalt planer
The Instruction Manual for the Dewalt DW734 Heavy-Duty 12-1/2" Thickness Planer can be downloaded from this link:
http://servicenet.deltaportercable.com/Products/Detail?productNumber=DW734#
Scroll down in the list of downloads to Instruction Manual and select the icon under PRINT DOCS.
May 15, 2011 | Dewalt DW734 Heavy Duty 12 12" thickness...
I am unable to raise or lower the cutting surface of my DW734 thickness planer. The turn handle is very hard to turn. Is there some kind of a locking mechanism ? If I had a manual I might be able to figure...
Follow this link: http://servicenet.dewalt.com/Products/Detail?productNumber=DW734
This will allow you to download the manual and exploded art for base, cutterhead and motor. You may also want to check the position of the turret stop. First of all, make sure the cutterhead lockdown lever is disengaged. Here is from the manual:
Your planer is equipped with a turret stop (M), shown in
Figure 11, for repetitive planing of pre-set depths. Stops are
set at 0", 1/4", 1/2" and 3/4". Use the 0" setting when planing
between 1/8" and 1/4".
TO SET A PLANING DEPTH
1. Be sure the carriage is set above 1-1/4" before trying to
set the turret stop.
2. Turn the turret stop until the desired measurement
shows (Fig. 11).
3. Unlock the head lock lever (Fig. 8). Turn the depth
adjustment crank, lowering the carriage by the desired
increments, until it contacts the turret stop.
NOTE: DO NOT USE FORCE TO CRANK THE CARRIAGE
BELOW THE LEVEL THAT THE TURRET STOP INDICATES.
PERMANENT DAMAGE TO THE HEIGHT
ADJUSTMENT SYSTEM ON YOUR PLANER WILL
RESULT.
NOTE: The 3/4" turret stop can be adjusted for other planing
thicknesses. Adjusting the 3/4" turret stop does not affect the
other turret stop settings.
TO ADJUST THE 3/4" STOP FOR OTHER
THICKNESSES
1. Unlock the head lock lever (Fig. 8) and turn the adjustment
handle counterclockwise to raise the cutter head.
2. From the back of the tool, locate the turret adjustment
bolt (N) shown in Figure 11. This bolt is set for a 3/4"
depth of cut at the factory. Use the crescent wrench provided
to loosen the jam nut. Adjust the bolt up or down to
reach the desired planing depth.
3. Turn the depth adjustment crank, lowering the carriage by
the desired increments, until it contacts the turret stop.
Hope this helps.
Dec 27, 2010 | Dewalt DW734 Heavy Duty 12 12" thickness...
I bought a mastercraft planer and do not have manual for it? I looked it all over it has no serial # and model # on the tag wear those # should be , there is only the date of manufacture and it is S9907....
I did some searching and it looks like if you call 1-800-689-9928 they will be able to help you out. Let them know the date code, and its size. I really doubt they made more that one 12" planer that year. If that date code is like DeWalt or Delta, that should mean the 7th week of 1999.
Nov 22, 2010 | Garden
Need owners manual for Delta DW734 thickness planer
look on the right side of the page you can download the parts list or the manual
http://www.dewalt.com/tools/machinery-portable-thickness-planers-dw734.aspx
Nov 18, 2010 | Dewalt Planer (DW734)
I do not have a manual for my mastercraft maximum 13 inch planer and would like to know how to remove the blades for sharpening
If it is anything like my 12 1/2 inch mastercraft planer you will need to remove the dust guide first, and then the drum with the blades will be visible. To remove the blades you need to loosen the bolts with the appropritate sized crecent wrench. Seems to be the only part of my planer that does not require an allen wrench actually.
Oct 20, 2009 | Tools & Hardware - Others
Delta 12 inch thickness planer blade change
Go to this link and at the bottom center of the page insert your model number. You will be able to download the manual for that machine.
Delta manual
If your question has been answered, or I fixed your problem, please take just a moment to rate this post...thanks!!
Mar 23, 2009 | Tools & Hardware - Others
Nov 18, 2008 | Tools & Hardware - Others
Masonry Tools Logo
1,638 people viewed this question
Top Masonry Tools Experts
Tom Chichester
ray gallant
Are you a Masonry Tool Expert? Answer questions, earn points and help others
