Unable to go beyond the go symbol, cannot access icon window
I have just purchased an Acer Iconia A501 tablet (3G + 32 GB) and I am having trouble reading my USB stick. I have tried to get help on the Acer site which stated you need a file manager. I have downloaded...
First locate the wireless network icon on your computer. On Windows laptops, the icon looks like 1 or 2 monitors and is in the bottom right on the taskbar. On Macs, it's a wireless symbol on the top right.
Then either right-click the icon and select "View Available Wireless Networks" (Windows XP) or just click on the icon and select to "Connect or disconnect..." (Windows Vista). On Mac OS X and Windows 7, all you have to do is click on the wi-fi icon to see the list of available networks.
Select the wireless network and -- on Windows -- click the "Connect" button.
Sep 06, 2011 | Android Apps
I hv nokia7210 phone after 1.5 years suddenly the charge not stand . i change the battery even though the charge not stand beyond 3 hours. some unknown icon "G","E" are appered in top of the screen near...
Symbol "G" and "E" are not related to this problem."G" means GPRS and "E" means Internet .The charging problem might comes due to bad charger or cgharging coil might fused or charging filter (IC) might sort.
Aug 15, 2010 | Nokia 7210
How do I show the Internet symbol at the bottom of the desktop screen?
Show the Internet Icon at Taskbar
Right click on Task Bar -> Properties -> Notification Area Tab -> Check Network System Icon Box -> Apply -> OK.
Bottom of the desktop screen=>Taskbar
Aug 06, 2010 | Microsoft Windows Vista Home Premium...
I am unable to open attachments from last month and beyond
Which version or yahoo are you using , If you using the All-New-Mail version switch it to Classic, now try...Hope it will help you...Thanks for using Fixya....Good Luck
Nov 09, 2009 | Yahoo Mail
Cant see desktop icons or access Windows anymore. Brand new Nc10.
If the Windows loading progress bar appears after turning ON the Computer and the Computer goes to the blank screen then perform the under given steps.
Press "CTRL+Shift+ESC" key combination to open the Task Manager window.
Next, click on the "Applications" tab and click on the "New Task...." tab located on the bottom of the window.
Then type "explorer.exe" and click "OK".
This would bring you back the Desktop icons and the taskbar.
Sep 15, 2009 | Samsung NC10-14GW Notebook
Unable to use desktop icon to access Vaio home entertainment
check that the software related to that is installed properly. if it cant solve ur problem then u can install a new window and then install all the softwares again ok. it will solve ur problem
May 21, 2009 | Sony VAIO VGC-RB34G PC Desktop
I have a hp compaq presario V2000 laptop, I am unable to get the ascii symbols using the alt+ key. need help
Try using charicture map. Also most versions of windows can access via charmap.exe under the run command
Feb 18, 2009 | Intel Dot Station (INTC300AIO) PC Desktop
Unable to access Windows Live OneCare options of actions needed
Right click on the icon at the bottom right, and then click "Get help at help center".
You can look for various solutions and if nothing works,
then at the bottom right of each help topic, there is a "contact support" link which will give you further instructions.
Jan 15, 2009 | Microsoft LIVE ONECARE 2.0 XP/Vista for PC
Unable to connect to internet
if you give the wep key in the router or modem or the access point then you give the wep key in that if not there direct connect it and you can check also where its give the password or not just go to the right click on the wireless icon in the taskbar then go to the view available the network in that your wireless ssid shows just click it in that you show the lock symbol then your network in the password its wirten that unsecure networks then you direct connect it
Jan 12, 2009 | Dell TrueMobile 1180 802.11b Wireless...
HP Solutions won't open - Windows XP
I can not access a driver for my hp scanjet 2400 online to install in my hp laptop pc- Window XP
Oct 25, 2008 | Office Equipment & Supplies
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
