Our dryer is not heat up. It spins, and will squeak, but does not heat up to dry. Model #417 93802200, serial #XE31600784. The washer works fine, love the unit and the space saving of the unit!
  • Washing Mach... Master
  • 822 Answers
These are reliable units and use much of the same components as their side by side big brothers!
Check all settings of the heat control and confirm under all settings that no heat is present in the drum.
Also try timed drying setting versus auto drying.
No heat in drum, first check is to confirm that 220 volt is at the appliance. The washer and dryer motor operates on 115 and if the one leg of the 220 volt supply is not present the heater will not work. Check breaker, dryer plug and removing plug from wall check the connections at the cable to the dryer.
Look for burnt wires/terminals.
Our dryer is not heat up. It spins, and will squea - 26409608-eitmdnr1asegqr0yqm2a1adt-2-0.jpg If connections are good than the following list of components are the most likely to have failed.
Heating element
Thermostat
Relay
Wire connections.
This unit is capable of running with just simple repairs for many years and if a qualified technician is available simple troubleshooting and repair is straight forward. All parts are available. Get an estimate before proceeding
Hope this helps?
Posted on Dec 22, 2016
Whirlpool model 110.88752792 dryer runs but does not heat
Concerning the Kenmore 11088752792 model where the dryer spins but does not heat. I had that problem a few years ago with the same model.
I replaced the fuse (part No. 3399849 about $10.00) and the thermostat (part no 3398128 about $25.00). Dryer worked fine the first try.
FYI. Today, I'm searching for what makes the dryer squeak when I came across your issue (though 6 months since you posted, but I figure there are other Kenmore stack-able owners out there searching for a fix). I haven't taken the dryer apart yet but have ordered the dryer belt, rollers, pulley (a package deal with RepairClinic) and the felt bearing/seal. May as well do a full replacement of the likely components that are causing the squeaks and not spend any more time going through trial and error repairs.
If you haven't already, the dogs on your agitator are probably due for replacement as well. RepairClinic has an agitator package deal with replacement dogs and seals.
Jul 14, 2011 | Kenmore 94802 Front Load Stacked Washer /...
Maytag washer squeaks when spin cycle stops
We have a Maytag Performa G3300 that we bought on 8/13/2001. It still works great, but on 2/25/10 it stopped heating. We found that by removing the front panel and vacuuming the accumulated lint on the inside of the dryer and the door, the problem was resolved. There were no parts to replace, just vacuuming.
Jan 18, 2010 | Maytag Performa PAV2200
GE Washer Model WJRR4170E4WW squeaks while agitating
There are four suspension rods that the tub hangs on. When the washer is agitating the tub will rock back and forth and the rods will move back and froth as well. To fix this noise, lift up in each rod and put some lubricant in the cup that the rods fit into at the top of the washer.
Note that it is best if you use a lithium-based lubricant rather than silicone based lubricant.
For more on do-it-yourself appliance repair help visit http://www.appliance-repair-it.com/index.html
Sep 11, 2009 | GE WBSR3140DW Top Load Washer
LG dryer (model DLE3733W) takes forever to dry the clothes.
check your vent hose for a clog. If dryer dont vent clothes wont dry.
Aug 25, 2009 | LG DLE3733 Electric Dryer
Dryer does not release any heat
Is yours the gas model? If so I need you to look for some things. Open back door panel and see if while trying to light the igniter is glowing orange. Sea Breeze
May 22, 2009 | Whirlpool LGB6300 Gas Dryer
Squeaks really loud while agitating. Drains great, and works well other wise. Could the belt be going bad?
Could either be the drivebelt slipping or, if an older machine could be the main bearing getting dry.
May 20, 2009 | Washing Machines
Dryer won't heat
If it is an electric heater that means that either the heating element,or the thermistor , or the cirrcuit breaker connecting the element mustbe replaced.
You find diagrams and replacement parts here, just enter the model number.
See also following suggestions from repairclinic :
There's no heat.
How Dryers work
Find a part for your Dryer
Oct 14, 2008 | Malber WD1000 Front Load Washer/Dryer
Kenmore Dryer Model 110.888029 Serial MH1102412 Type 180.00
MOST LIKELY PROBLEM IS A RESTRICTION IN THE EXHAUST. DISCONNECT THE VENT FROM THE BACK OF THE DRYER AND TRY DRYING ONE LOAD. IF IT DRIES O.K.,
THERE IS A RESTRICTION IN THE EXHAUST. CLEAN THE LINT OUT FROM THE ENTIRE LENGTH OF DUCT WORK.
Apr 08, 2008 | Kenmore 63942 Dryer
Condenser dryer
doubt if squeak is related to not drying. if you are getting heat (you say heating element is ok) take out condensor and hose it down till thoroughly free of lint. check appliance has adequate ventilation as well
Apr 09, 2007 | Zanussi TC180W Electric Portable Dryer
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
