Question about Vacuums
Kenmore vacuum 116.36720600
My vacuum just cut off. i can't get it to come back on. HELP PLEASE????
  • patricklim Apr 10, 2008
    As I was vaccuming, it suddenly stopped working.
    Tried plugging it in different outlets, toggled the on/off swtich... still not working.
  • 1,673 Answers
Can be various reasons, the cord is bad, problem with the switch. Also there is a protector for the motor or the motor itself. The 1st thing I would check would be the cord.
Posted on Feb 12, 2008
  • 438 Answers
SOURCE: Belt broken a a Kenmore
Greetings from,
To properly fix a belt on a Kenmore vacuum, you will first need to indicate whether this is an upright or a canister vacuum. The model given, 116, is only the first part of the model number, and all Kenmore vacuums, upright and canister style, start with 116. There is a period first, then a whole string of numbers, 116.255553 etc.
Kenmore vacuums are mainly made by Panasonic for Sears, and most will use a Panasonic belt. If the belt is an upright, this makes it simple, and will be a Panasonic "UB" belt.
For a canister vacuum, most models use what's referred to as a cogged belt. This type of belt has little teeth on the inside of the belt, and is Panasonic CB-5 belt.
Instructions on How to Replace the Belt for an Upright;
There will usually be to plastic screws on the top of the agitator housing on the base of the vacuum, that will say belt access. Simply take a flat head screw driver, and turn the screws so that the screw is pointing up and down on both sides. Then pull the plastic agitator housing, or the top of the base of the vacuum off. Inside you will see a the roller brush, and the belt (or broken belt). Simply take the new belt and wrap it around the silver pulley located in the back of the machine, opposite the roller brush, and wrap the other end of the belt through the roller brush. Stretch the roller brush back into the housing of the machine, and replace the top of the base of the vacuum back on the machine. You should give the belt a tug, to ensure that the brush is spinning when the belt is being pulled.
Feel free to email me if you have any further questions, I'd be happy to walk you through it, or even shoot an instructional video to show you how you to replace it. My email is chris.jones at govacuum . com.
Chris Jones
Posted on Oct 01, 2008
SOURCE: Kenmore vacuum manuals
I tried what reddevil6 suggested and was not able to get Sears to produce a manual. I would prefer an online manual but at this point I'm desperate enough to try anything.
Posted on Oct 05, 2008
SOURCE: repair kenmore elegance vacuum model 116
My Kenmore Elegance 116 turns on the powerhead but the vaccuum motor does not go on . Is there a reset button?
Posted on Feb 09, 2010
SOURCE: Kenmore Model 116 upright beltless vacuum, agitator will not turn
I had the same issue. The holder for the micro switch is very weak and will open up and allow the switch to come loose, and in my case the was not enough slack in the wire. I unplugged the unit, pressed the pedal and laid it down. Open up the bagger door and remove the bag and filter. Remove 4 screws in the bagger compartment, remove 2 screws by InteliClean indicator lights, remove 4 screws on the outside close to the light. You will be removing the blue upper case. Remove the upper case and look on the right where the lower agitator section pivots. There you will see a micro switch. I ended up lifting and tilting the lower pivot section to the side, repositioning the switch in the holder, and then wedging a full glue stick (not melting but wedging) between the white plastic housing and the switch holder. This added the strength needed to the switch housing to hold it in place. Put it all back together, install the filter and bag. This fixed mine. Good Luck.
Posted on Feb 27, 2010
  • 438 Answers
SOURCE: Model 116 Kenmore vacuum cleaner. 20+ years old,
I believe that this is probably a Kenmore Canister vacuum cleaner, but I can't be positive. The model number 116 is just the first part, and all Sears vacuum cleaners start with model 116. There is a . after the 116 that will identify the vacuum. If you'd like me to be more model specific, or if this is an upright vacuum, please just request a clarification and I can take pictures even for you.
If this is a canister style vacuum, then you'll need to remove the foot pedal that rewinds the cord reel. There are 2 or 3 (depending on which model you have) hidden screws underneath of this pedal. You may simply pry off the pedal using a flat head screw driver. Also when you have the bag door open, you may just pull forward while it's open, and this will remove the bag door housing. There should be two screws in the front of the motor housing that need to be removed as well.
My guess from the age of the vacuum that's probably the motor that's gone. If this is the case, you probably can still get a motor if you'd like to just replace the motor inside, rather then buying a new vacuum. Typical Sears Kenmore canister motors sell for 79-120 dollars.
Again, I'd be happy to try and help you further, I will just need the entire model number after the 116. to know which vacuum you have.
If this was helpful, please click the 4 thumbs up icons in the top of the page. Thank you,
Chris J.
Posted on Mar 21, 2010
Just purchased a floor model Kenmore Progressive vacuum 2009 Model... no instruction manual was available at the store. Where Can I get one
Hi There,
Here's a link to the owners manual for the Kenmore upright which this question was listed under, the 116.35913. You can find the model number on the back or the bottom of the machine on a sticker that also contains the serial number. If you have a different model then this, and would like the correct owners manual for your vacuum, please just use the clarification request form here on fixya, and I'll be more then happy to try get that for you.
Here's the link:
If you found this repair helpful, please be so kind and leave feedback by rating the repair helpful from the link in your email. This is really what keeps Fixya repair professionals continue posting free repair help, by leaving feedback you are helping to continue having free answers to your questions rather then the premium questions. This is really appreciated.
Chris J.
Apr 17, 2010 | Kenmore 35912 / 35913 Progressive Upright...
Connectors on Kenmore Power Mate
to take the hose off, you just depress the clip at the end but there is no easy way to remove the connectors off of the ends, it just must get cut out and the new one pushed in and sealed
Let me know if you need any further help
Apr 07, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
How do I open a Kenmore 116 Vacuum?
You shouldn't need to remove the cord just to put a new plug on. Just cut the end off about 2 inches back, strip the outer insulation and the wire ends and install the new plug. Make sure there are no stray strands of wire hanging out from under the screws. I always solder the ends, so that I am dealing with a solid wire rather than twisted strands.
Sep 19, 2009 | Kenmore 25512/ 25513 Progressive Canister...
My vacuum just stopped working, so I don't know what the problem is. I used it in the kitchen to vacuum the hard wood floor. I turned it off, and a few minutes later, turned it back on to finish vaccuuming...
When I get most Vacuums that have dies on people most of them the wire has been worn and cut one or more wires on the plug cord. Sometimes the cut can be over looked. Please unplug and check the wire carefully.
Also please post the make model and year you bought it would help in getting you a answer.
Aug 04, 2009 | Kenmore 23913 Progressive PowerMate Bagged...
Vacuum will not shut-off
if it has a foot pedal flick it a few times and see if it goes off.if its a switch unplug the vacuum and move the switch from on to off real fast a few time.if you have any contact cleaner you can try to spray a little into the switch while unplugged and work the switch back and forth a few times .the switch might just be dirty.if you don't hear a click when you turn it ioff and on then the switch is probably bad.please leave feedback.i hope i was some help to you
Mar 30, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Motor on the powermate keeps cutting in and out.
If your talking the motor on the beater bar, then chances are either when the beater bar was attached to the hose near where you hold it, it did not lock, and the connection is intermittent, or the cord has an internal break.
Jan 22, 2009 | Kenmore 22313 Bagged Canister Vacuum
Kenmore/Sears Progressive 116 How to get housing off to replace cord
There are four screws, two at the front and two at the back under the step bar that rewinds the cord.  It lifts off from the bottom.  Be careful not to snap off the tabs.
Sep 20, 2008 | Kenmore 23913 Progressive PowerMate Bagged...
Hot cord
likely after all these years that the motor is starting to go bad and draw more amps thasn it should. a new motor at a vac dealer is your best bet. it was likely made by panasonic, so a new panasonic is your best bet, and less $$$than the kenmore for the same vacuum. sears parts are extremely expensive
Sep 06, 2008 | Kenmore 23313 Whispertone Bagged Canister...
How to take the brush out?
There should be screws on the bottom plate covering the brush roll, take those out and it should come off and then you can access the brush roll.
Feb 17, 2008 | Kenmore Progressive Bagless Upright with...
Vacuums Logo
245 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
