SOURCE: hanns 17" LCD MONITOR
internal power supply failure,the AC power supply that powers the backlight fails every time you turn it on. Unfortunatly electronic repair is costly, A new monitor is cheaper.
SOURCE: LCD monitor turns off after 2 seconds from boot
Thanks for the suggestion, I have finally found out that the back light for the monitor is culprit. Also dell people and confirmed it . They aggred for a replacement. Thanks for the suggestion again.
SOURCE: the screen turns offf after 2 seconds
The problem can be caused by bad caps in the power supply, bad inverter circuits, bad lamps. You need to open it up and post back what you see inside so we can guide you further, see example of failde monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
SOURCE: hi... i have a problem with my acer x193w lcd
It could also be the inverter. If the monitor does not work after replacing the capacitors, you might have to replace the inverter.
