Question about Refrigerators
I replaced my cooling unit. Now the display lights don't come on. I have 120v & 12v. Could the control unit go bad because of the ammonia . What would I check next. Domestic 2852
  • 3422 Answers
SOURCE: Dometic rm7732 not cooling
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
  • Is the refrigerator completely dead? If so, see “It's stopped completely.”
  • Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Posted on Jun 17, 2008
  • 423 Answers
SOURCE: Dometic 2852 freezer gets cold but refridge does not
If your freezer is getting down close to zero degrees (F) then I doubt that your refrigerant is low. The most common cause of the refrigerator section not getting cool (approximately 40 degrees (f)) is a fan that pulls the coils in the freezer into the refrigerator has failed. A very common failure of a cheep little fan motor. Normally that fan is behind a panel in the freezer section at the bottom. Determine where the cold air in the refrigerator section normally enters and the fan will be above there.
Posted on Aug 11, 2009
HIRAM517
  • 59 Answers
SOURCE: Dometic rv refer rm2310 .. no cooling on gas /electric
THE COST OF REPAIR EXCEEDS THE VALUE OF THE UNIT
Posted on Aug 19, 2009
Testimonial: " What do you think is wrong??? Cost of repair exceeds....? I understand that the ammonia leaks are very visible... nothing can be seen????"
  • 98 Answers
SOURCE: Unit cools fine on 120V, selecting GAS CHECK light on.
Do you hear a clicking sound If not. there is a black box inside the out side door. Check the fuses in it.
Ken
Posted on Sep 25, 2009
Testimonial: "Worked!!!"
  • 327 Answers
SOURCE: no cooling on 12v or gas
Hello,Depending on the age of the unit, it could have a compressor going bad on it, as the compressor gets hot the valves may not be seating correctly or may be burning out.
You may have also lost some refrigerant, but I am going to lean more to a bad compressor.
Thanks
Posted on May 30, 2010
Norcold n510ul. Why doesn't it refrigerate in any mode?
it possibly needs recharged with freon and sad to say that can only be done by a certified serviceman
Aug 25, 2015 | Refrigerators
Freezer gets cold frig is hot. I replaced theromister.did no good
If your Dometic refrigerator is a tri-power model (12V, 120V, lp gas), check all modes. It is not uncommon for these units to fail to cool adequately in 12V mode, as that mode is only for KEEPING things cold while on the road.
If the failure exists only in 120V mode, replace the 120V heating element. If the failure exists only in lp gas mode, replace the burner and make sure that the jet is clean.
If the refrigerator does not get cold in ANY mode, verify that the door seal is making good contact all the way around and, if it is, you'll need to replace the coil assembly. (They are available on eBay and Amazon at a fairly reasonable price.)
May 20, 2015 | Dometic RM2652 Refrigerator
Dometic RM2652 was working fine then stopped - no lights at the control panel above the doors.
Usually there is a short in the system when fuse is blown. Check the cord as sometimes mouse can damage the cord. It is a posibility.
Check power to the electronic board.
Jan 28, 2015 | Dometic RM2652 Refrigerator
Smell ammonia and refrigerator got warm,no sign of leaks
bad cooling unit if you cannot replace bring to a dealer or replace unit
Jun 19, 2014 | Dometic RM2852 Refrigerator
Lhave a rm 2601 rv refrigerator and when I cut it on the freezer coil gets warm instead of cold.Also it is making a gurdling noise. when I open the door to refrigerator the it has a ammonia bad...
Shut it off and get it checked. Ammonia is dangerous as I am sure you are aware. Ammonia smell is an indication of a leaking cooling unit. Time for a new fridge. Sorry.
Oct 14, 2011 | Dometic Rooftop RV Air Conditioner
Dometic 2652 does not cool that well. Food spoils. Placed 12V fans on fins and another on the lower portion. 46-58 degrees. No help. Replaced with circuit board #3308741.002 and no-go. I have no 12V power...
Hi
There could be leak which causes the no cooling state in your unit.To check the cooling ammonia system, the 110v heater or the 12 Volt heaters can be hotwired direct to a power source, this will check the cooling system, The 110 V is best to check. But you need a repair person to get it diagnosed.
Please get back to us if you have further query else please accept this particular suggestion.
Thanks for contacting fixya.com
Aug 24, 2011 | Dometic RM2652 Refrigerator
No cooling on 12v or gas
Thanks
May 30, 2010 | Dometic RM2620 Refrigerator
Aug 19, 2009 | Refrigerators
Refrigerators Logo
23 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
