Question about Singer Sewing Machines
I have a singer 401A. My needle is either hitting the presser foot or the plate underneath.
I have cleaned, oiled, adjusted the foot and the made sure the plate is in properly. I have broken 3 needles :/ Not sure what is going on with the machine.
  • Singer Master
  • 12,273 Answers
Most likely your machine is out of time or the needle bar is out of adjustment. May be best to take it for service.
Posted on Dec 22, 2016
  • 822 Answers
  • Confirm needle is not bent
  • Confirm needle installed correctly
  • Set needle position to "3" middle
  • confirm that the left right zig zag is not hung up.
  • remove pressure foot completely and check for clearance
  • remove presser foot plate and check for clearance
  • remove bobbin and check clearance
  • inspect needle hook interference.
If the needle correctly installed is interfering with the hook machine timing has slipped.
These machines are built like Sherman tanks and will last for ever. There are videos showing how to reset the timing. Suggest taking it to a qualified repair cent getting an estimate before proceeding.
Hope this helps?
I have a singer 401A.  My needle is either hitting - 26409592-eitmdnr1asegqr0yqm2a1adt-2-0.png Set needle position to "3" middle
    Top Expert:
  • Singer Master
  • 8,304 Answers
Singer 6235 - the fabric is not advancing regardless of stitch length or tension
Could be any of a multitude of reasons.
Check whether the feed dogs are actually rising 'above' the needle plate. If not, then they may be in a dropped position used for darning and free motion quilting.
Sometimes the feed dogs and the mechanism underneath is jammed with lint and debris. Make sure the dog teeth are well cleaned. Also check if the tips of the teeth are worn. Also verify that the needle plate is flush with the free arm--if it is raised, it will prevent the feed dogs from doing their job.
The other thing to check is whether the machine has a presser foot pressure adjustment. Some machines have it, others do not. On newer machines, it is usually a dial somewhere around the left side of the head or toward to top of the head. On older machines, unfortunately, some are simply a big screw head on the inside of the case directly above the presser foot bar. It basically applies more pressure to the presser foot, which in turn applies more pressure to the feed dogs. The problem will usually show up when sewing either very heavy or very fine fabric. Perhaps trying a different presser foot will make a difference.
I don't know what is the highest number the stitch length goes to on your machine, but a #2 stitch length is pretty short on mine. Try setting it higher.
Sewing Machine Presser Foot Stuck
Singer 6235 User Manual
Nov 19, 2017 | Singer Sewing Machines
Singer touch tronic 2000 feed dog will not advance fabric
Confirm the feed dogs are raised. Make sure the feed dog teeth, area under the needle plate and the bobbin area are clean of any debris, thread, or buildup. Some machines also have a presser foot pressure adjustment that increases the pressure the presser foot applies to the feed dogs. The feed dogs could be worn (never run the sewing machine without fabric between the presser foot & feed dogs).
https://www.manualslib.com/manual/508740/Singer-Athena-2000.html
Or, the machine has not had a thorough cleaning and oiling recently and the feed dogs are sticking from old oil.
Wheel on right side that controls the needle up and down is very tight...
Jul 30, 2017 | Singer Sewing Machines
Needle not lined up with hole in presser foot
Is it also hitting the needle plate? if so then you need to move the arm the adjustment is internal and you\'ll have to disassemble the clam shell case of the machine. May be best to have a pro fix it for you.
Jan 14, 2014 | Brother CS6000i Computerized Sewing...
Needle not aligned with hole in presser foot
Hi if the needle is hitting the needle plate you best get in touch with who you bought it from, The needle position is a critical adjustment and is done in conjunction with other adjustments.
Sep 22, 2017 | Brother CS6000i Computerized Sewing...
Remove sewing maqchine case
Plate on bottom: Remove screws. Keep screws in safe place and oil moving parts with good quality sewing machine oil. Zoom with spout for sewing machines & servers is what I use purchased online...lubricate gears with Singer lubricant (in tube). Tip machine back onto a towel to remove screws. Just one drop oil on moving parts & dot of lube gear only if not showing signs of grease already. Please remove bobbin and presser foot before cleaning/oiling. One drop oil then generously SMEAR oil on oscillating hook, open right front door & one drop top of needle bar. Clean out race shuttle for lint, fuzz balls, broken threads with soft sewing machine brush & clean your feed dogs gently with bristles too. Hope this helps. Do not clean machine near children or curious pets! I run my machine with pedal on table top so I don't accidentally step on it. Control with right hand to see moving parts. At your own risk, of course. Safe and effective but only if you are extremely careful. Replace all screws securely. Put in new needle all the way UP into needle bar groove, presser foot UP turning handwheel towards you, flat end of needle to back, Thread Front to Back of needle.. Keeping presser foot raised @ highest position ensures thread locates the tension slots properly. Jimmy
Apr 07, 2012 | Singer Sewing Machines
Kenmore 385. 15343600
Remove bobbin, presser foot, needle. Tip machine back on towel gently. Unscrew plate--don't lose screws! Do not service in presence of children and curious pets. Put foot pedal next to you on tabletop. Use Zoom Sewing Machine oil. Any part MOVING that are NOT gears get one drop oil. Any DRY ONLY gears get dab of Singer sewing machine lubricant. Replace screws. Secure screws. Open left front compartment & one drop oil @ top of needle bar. Open race shuttle (where bobbin case fits in). One-half drop oil of on oscillating hook (bottom left - hand corner...smear that oil around! Insert NEW needle all way UP in needle bar groove, flat needle shank toward back. Turn handwheel towards you and raise. Raise presser foot so that threading locates all tension slots a's you pull thread TAUT from spool to each tension slot and left to right through silver, metal take-up lever, and down to tension bracket, pass needle, then pull 6" thread towards you and thread from FRONT to BACK of needle. Place bobbin into case and "thread" it. Set presser foot on DOWN position. Turn handwh towards you, dipping needle into needle plate. Make loop with bobbin thread, pull towards you. Place a good 7" underneath presser foot (both threads). Let machine RUN on 24" scrap to distrubute oil/lube. That's it! Jimmy
Apr 05, 2012 | Sewing Machines
The thread is bunching up under the needle and needle keeps hitting something metal down in the bobbin case which then stops the machine. I've rethreaded bobbin, adjusted tension, checked needle &...
Your problem stems from the faulty foot lever mechanism. It's coupled to the upper thread tension control which only provides tension when the presser foot is in the locked down position.
If the presser foot won't positively engage in the down position, there's no upper thread tension and the thread bunches up below. Everything else stems from there. If the needle has hit the bobbin case too frequently then the bobbin timing may also be slightly out and the needle itself will be damaged and won't pass straight through the fabric; it only takes a tiny deflection from the vertical as it passes through the workpiece for the needle to flex and hit the bobbin case.
In summary, your machine is in desperate need of repair and adjustment. You haven't stated which exact Singer model you have, but they are usually easy to get servicing manuals for or you can take the machine to a sewing machine servicing specialist. Most singer spare parts (even for 100 year old machines) are usually still available fairly cheaply from a variety of sources, just enter "Singer spares" into your search engine to find suppliers.
To prevent re-occurrence, clean the mechanism regularly and lubricate it as directed by the manufacturer using sewing machine oil. Depending on how often you use the machine, do (or have done) a more thorough service periodically to check the timing and also that all mechanism screws remain tightly fastened.
I hope that my reply has shed some light on your problem and enables you to decide what to do next. Please take a moment to rate my answer.
Sep 30, 2010 | Singer Sewing Machines
I hear a knocking sound on my machine when I sew, and sometimes the thread pulls and messes up the fabric... any ideas?
The bobbin case and shuttle need to be cleaned and the machine oiled.
When you thread the machine, always have the presser foot up.
When sewing and you need to reposition the fabric, make sure the needle is down into the fabric before raising the presser foot.
When the presser foot is up, the tension opens and does not control the flow of the thread and you get a messy stitch or a jam.
Refer to page 84 of the manual for your machine. If you do not have a manual, download one free at the Singer Co. website. It is important to
follow the instructions in the manual.
Feb 24, 2010 | Singer 3116 Simple
Needle hits the plate that is over the bobbin.
If possible hoop the item. I have found that any item that has any thickness causes the presser foot to be pushed forward and the needle hits it and breaks. If you can press the item to lessen the thickness this may help. I spoke to Singer (I am a Singer dealer) and they did not have any help for this other than to recommend that the owner cut out the back of the foot. I don't think that would be a solution as it would be difficult to cut out the back of the foot and still have smooth edges, also it would cause the foot to be weak and possible break or bend. Good Luck
Feb 25, 2009 | Singer CE-200 Quantum Futura Computerized...
Sewing Machines Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
