Question about Viking Ovens
Viking oven control panel won't unlock - Viking Ovens
3 Suggested Answers
SOURCE: upper oven locked and control panel is not working
First off this oven sucks. Now to fix the problem replace the Fuse assembly with #4451042 an $11.00 part. SHUT OFF THE POWER AT THE BRAKER PANEL FIRST. Then open the lower oven door and remove the two small screws that hold the side trim pieces, slide them up a bit to remove. At the top of the track remove two more small screws that hold the display panel in-place and lift the cover up and away from the oven. The fuse is inside of a clear plastic tube with a female spade connector at each end of it. replace the failed part and put things back the way that they came off. Next time don't by a Whirlpool.
Posted on Jul 09, 2008
  • 1922 Answers
SOURCE: Are there fuses in an Eaton Viking wall oven
you have lost one leg of input power that gives you 240 volts check both legs for 120 volts each for a total of 240 volts
Posted on Oct 05, 2009
Model DED0530 wall oven. Tries to start but then why does it indicate 'cooling error lower one'?
[PDF]Viking Use & Care Manual
Viking Rangecontact our consumer support center at 1-888-VIKING1. We appreciate your choosing a... Error Handling .... *Note: Professional Series Premiere model control panel and features are shown. Oven ... upper or lower oven, and then set the desired temperature. .... cooled, remove any ash from oven surfaces with a damp.
Nov 06, 2015 | Ovens
Viking replacement decals / stickers: Has anyone found a reputable source of replacement decals for oven and cooktop - mine rubbed off after a few years' use, and from cleaning....)
Try Mark the owner will find accurate decals of your cooker confirm it with you and send you two sets plus degreaser. Follow the simple steps from the sites video instructions and voila. It is so easy and I highly recommend Mark and his product. Tell him Shaun sent you.
Jan 08, 2014 | Ovens
Viking double oven control panel labels rubbed off
The control panel face can be ordered from Viking Range unless the unit is very old, then I would suggest, You will need the model and serial number from the rating plate on the unit. These parts are usually not very expensive and are really easy to replace.
Hope this helps....GOD BLESS...Randy...
Feb 02, 2012 | Viking Designer DEDO130 Dual Double Oven
The stickers that indicate what temperature the oven is on have come off during cleaning. Is there anywhere to buy replacement stickers/decals? Thanks.
I true wish there was, Viking will sell you only the panel with the writing on it, because its part of the panel. I an sorry that happened but there is not fix to it other than replacement of the panel.
Good Luck
Viking Number to verify if you like 1-888-845-4641
I am a certified servicer
Aug 17, 2011 | Viking Professional Select VESO130SS...
Oven door won't open after self cleaning cycle
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Aug 13, 2011 | Viking 27" Professional Select Built-in...
On my viking oven i get a FO on the panel. The oven wont cut on.
f0 error is either an E.C.R. (electronic range control) or that it is the keypad and it would probly be about 300 buuucks to fix
Jan 09, 2011 | Viking VGS0166 Stainless Steel Gas Single...
The door to my viking oven is locked and stuck, does anyone know how to unlock it?
Must be taken out of wall far enough to remove top panel and manually disengage lock
Nov 20, 2010 | Viking 27" Professional Select Built-in...
Viking oven won't turn on
I had same problem (twice) with my Viking dual fuel range. In my case a relay that supplies power to the oven heating elements failed. The convection fan would run. The elements were warm to the touch. If you have a free standing range, it may be that relay (part number PM010026) which is located in the front of the stove. Remove a long narrow stainless steel panel (1 screw each side) located under where the door hinges. You can hear the relay click when you turn up the oven thermostat. That will help you locate the relay.
Note: Viking does not sell parts. You have to find their parts distributor for your part of the country.
Sep 20, 2007 | Viking DEDO205 Stainless Steel Electric...
Ovens Logo
59 people viewed this question
Top Viking Ovens Experts
Dan Webster
Dan Webster
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Viking Oven Expert? Answer questions, earn points and help others
