Question about Canon imageCLASS MF4150 All-In-One Laser Printer
Malfunction with printer when tried install the printer driver
I cann't make connection with my PC. the error massage is: the printer is malfuctional.
    Novelist:
  • 112 Answers
It sounds like there is something wrong with the printer, or perhaps you don't have the printer drivers installed, or just not the correct ones. Search for the drivers for your printer model on Google and download the latest version of them and install them. After that, reboot your PC and try again.
I hope this helps :)
Best Regards,
James
Posted on Jul 21, 2009
Dir.hp hp p1005 printer engine error massage what
Are you connected to a PC or a MAC? Is the error displayed on your PC or your printer? Is there a number associated with the error? Please provide the number at the exact error message.
Or, you can go to HP.com/support and drivers and research the error message.
Aug 18, 2013 | HP LASERJET P1005 Printer
Cann't acces winwows 7 ultimate os
Try below mentioned process:For USB connectivity> start>Device & printers>add a printer>select dot4 001>choose 3050 drivers from the list> install it> connect the usb cable after completion of the drivers..For LPT: same as above choose the 3030 drivers from the list
Dec 29, 2011 | HP LaserJet Office Equipment & Supplies
Printer error has occurred
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer ONLY WHEN PROMPTED, to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken. Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Nov 11, 2011 | Canon MP520 All-In-One InkJet Photo...
Cartridge error solution when printer is switched on the cartridge error massage comes
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or
May 07, 2011 | HP Officejet 4355 All-In-One InkJet...
Eror E677
roblem :
The machine displays an E674 code. This may be followed by an E677 code when the Fax pcb is removed. The imageRunner also has a Print Board installed.
Solution :
With the Fax Board and Print Board installed an E674 code occurred. When the Fax Board was removed an E677 code then occurred.
Try removing the PDL Interface pcb for the Print Board from the copier. Reinstall the Fax Board, if the E674 code does not occur and the copier is capable of sending and receiving faxes, then replace the PDL Interface pcb because it may be faulty and causing the two E codes; E674 for faxing and E677 for printing.
Jun 01, 2009 | Canon imageRUNNER 400S Copier
Problem with hp laser jet 1018
i need the windows xp driver
Jul 12, 2008 | HP LaserJet 1018 Printer
Xerox phaser 77600n
First try disconnecting your pc from power cable for 10 minutes and disconnecting scanner from pc. Then connect back everything and see if it works (this is called hard start). If this does not work then disconnect 77600 from pc. Uninstall and re-install all xerox drivers and software.
good luck
Feb 21, 2008 | Office Equipment & Supplies
Lexmark p6350 all-in-one not working
I am guessing that you're using the New improved windows Vista. If so, you need disconnect the printer power and usb connection. then remove the current driver for the printer and down load the current driver @:http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:571:0:0
The soft ware will tell you when to install the printer
Dec 30, 2007 | Lexmark P6350 All-In-One InkJet Printer
Canon imageCLASS  MF4150 All-In-One Laser Printer Logo
70 people viewed this question
old marine
old marine
