Question about Ovens
Why my iwave oven screen is showing lock sign.?it is unlocked but when i click any function lock sign appears on screen.
3 Suggested Answers
  • 130 Answers
SOURCE: Thermador SC302T clicking noise, locked door after power outage
iodine, open the upper oven, look thru the grill below the control panel on the right side and there is your model number. The issue here is that when the power came back on the oven run thru a test and your lower lock motor has failed. It will need to be replaced. Yes the only way to stop this is to shut off the breaker.
Posted on Feb 03, 2008
  • 8 Answers
SOURCE: A lock sign is showing on the screen and the oven
This is possibly a self clean oven. Usually when the self clean is operated the timer is used. Try checking the timer is back on "manual"
Posted on Sep 02, 2009
I have a neff double oven - When i try to use the top cooker the functions light up when selected then go off. The display shows -5- & the temp does not show on the screen when i turn functions on.
although it looks like a five it means safety activated or to be more precise child lock to switch off turn oven selector switch quickly 3 times off and back on between off and light only this will turn child lock off.
May 25, 2016 | Neff Ovens
I have a Bosch oven with the "key" sign constantly lit and the oven won't function at all. Re set it at wall etc.
the key sign shows that the child lock is engaged. to unlock, usually you push and hold the lock button for a few seconds. the correct button is usually a dual function and so marked. if you need more help, go to and look up your model number for your manual. good luck
Dec 27, 2015 | Bosch Ovens
How do I unlock the display on my Blanco oven
- Press the "START" button and hold it down until the lock sign desappears on the display. All the buttons will light up for 1 second. The display is now unlocked
Oct 05, 2014 | Ovens
Bottom oven stopped working there is a key symbol showing on the panel what is wrong ?
There are a few reasons for this. One is the most obvious and that is the child lock switch needs to be engaged to unlock.Some models call it panel lock.
Turning the panel lock on and off:
To turn the panel lock on, press and hold the Panel Lock key for four seconds. The Panel Lock symbol will appear in the display.
To turn the panel lock off, press and hold the Panel Lock key for four seconds. The message in the display will disappear.
Oct 04, 2014 | Bosch HBL 5056 Electric Double Oven
The childlock key sign is on when i try to use my Tecnik TKH4050/3 hob. How do i unlock it
Most control panels have a button that can be held down to lock and unlock the controls. Do you see one that has this function.
Mar 23, 2011 | Tecnik Ovens
I got a key sign on the screen and since then I cannot operate the oven
This is telling you that the oven is locked. You will need to unlock it to use it.
Mar 18, 2011 | De Dietrich DOP390 Pyrolytic Electric...
What does the sign "control lock" mean?
Here is what the manual for your oven says about control lock.
Let me know if you have questions.
Control Lock
The Control Lock shuts down the control panel pads to prevent
unintended use of the oven(s). The Control Lock will remain set
after a power failure, if set before the power failure. The only time
it is not available is during the Sabbath Mode or Self-Clean cycle.
When the control is locked, only the TIMER SET · START, TIMER
function. On double oven models, CLOCK SET · START will also
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Press and hold CONTROL LOCK for
about 3 seconds, until “CONTROL LOCK” and a picture of a lock
appear on the display. Repeat to unlock and remove “CONTROL
LOCK” from the display.
May 13, 2010 | KitchenAid SGL OVEN T/C
A lock sign is showing on the screen and the oven won't go on and I can't get the lock sign off!
Sep 01, 2009 | Ovens
Re: my whirlpool digital oven
The red key sign is a lock against children. To cancel it you have to hold the two buttons at the same time for 5 seconds (you activate it the same way).
The STOP sign appears after the cooker switches of after a power cut. You just have to press the left button, and, using the right knob, set the time.
Jun 24, 2008 | Ovens
Door Keeps Locking and Unlocking after Power Outage
Located the switch - resetting fixed my stove as well.
Dec 17, 2007 | GE Profile JTP18 Electric Single Oven
Ovens Logo
29 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
