My screen looks like a photo negative..I have a Toshiba Satellite.
    Novelist:
  • 112 Answers
Right click on your Desktop, click on Properties, then go to the Settings tab and set the color to 32 bit True Color.
It sounds to me like your display settings are set to monochrome/black and white.
Best Regards,
James
Posted on Jul 21, 2009
Mines doing the same thing. replaced the power inverter, no change. it slowly fades white, then photo negative...? external monitor works perfectly so its a screen or power issue.. any help out there???
Posted on Jan 13, 2010
4 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: The display has dimmed, and looks washed out (faded)
You most likely have a defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Apr 05, 2009
jaye_ellen
  • 591 Answers
SOURCE: LCD Screen colors are bad on toshiba Satellite M115-S3094
Was the screen showing all OK before you updated the driver? If so did you try backing out (uinstalling) the graphics driver? You mentioned gtaking screen cover off ... did you completely remove the screen from the laptop, including the wide connector at the top and the smaller one at the bottom, and the small one to the backlight? These connectors might be seated wrong, and you'll have to reseat them, mostly the big one at the top. Best o'luck, Moorethemerrier!
Posted on Sep 20, 2009
pheireith244
  • 310 Answers
SOURCE: toshiba laptop screen looks like
Cause : Display screen problem. Solution : Remove the Screen and check the weir. If there is no problem you need to change your Display... thanks
Posted on Aug 30, 2011
Can you fix the colours of the pictures on the screen of my Toshiba Satellite pro P300. It looks like the negative of a colour photograph. Light colours are dark and black is white. Red appears as blue...
In windows 7 , -
1 Go to the ease of access column in the control panel
2 Then go to the link "Turn on high contrast..."
3 Deselect it if it is selected
If it doesnt work then-
1 press Alt+Ctrl+Del
2 On the lower left corner their would be a button to Ease of Access
3 press it and deselect "Turn on high contrast "
This should work cause i tried it on my own computer
Mar 27, 2013 | Toshiba Satellite Computers & Internet
Toshiba laptop screen looks like photo negative
Aug 29, 2011 | Computers & Internet
Can i replace a toshiba l355-s7901 motherboard with a toshiba l355-s7915 motherboard
Going out on a limb here, but I'm going to state yes, except the s7901 has hot keys in the center strip under the LCD screen. Above the Keyboard, where the Power On button is located. The s7915 doesn't.
Toshiba Satellite l355-s7901,
http://www.notebookcheck.net/Toshiba-Satellite-L355D-S7901.14988.0.html
You can click on the photos towards the bottom to enlarge.
Toshiba Satellite l355-s7915,
http://www.notebookcheck.net/Toshiba-Satellite-L355-S7915.19879.0.html
Same with the photos at the bottom.
I know this doesn't seem like a very professional answer/solution, but in viewing both of the laptops the ports, (USB, DC Power Jack, etc.), and the peripherals, (DVD optical drive, add-in card drive, etc.), seem to be in the same place.
Viewing a Service Manual for the Toshiba Satellite l350 series of Notebook PC's, shows removal procedures to be the same across the board, no matter what model deviation it is.
As long as it's one of the Satellite l350 series.
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Go down to the second Satellite file header. The one that starts with Satellite A10.
Now go down to the second line, and then go across to L350, and click on it.
This is a PDF file. May take up to 30 seconds before you see the first page, and additional time to fully download.
Do I know for a fact they will interchange? No, I do not.
I'm willing to bet strongly that they will.
Nov 20, 2010 | Toshiba Computers & Internet
The my laptop took some water damage about a year ago, since then the display on the screen has looked like a photo negative. Is there any way to fix this wihout taking it to a repair place?
HI there,
Here's the easiest way for you to troubleshoot this hardware problem.
1. Using an external monitor (whether your own or at a friend's place) which you connect to the laptop, see if the same problem shows on the bigger monitor. On most Toshiba, you'll need to transfer the video signal by holding down the "fn" key and pressing the F5 key oncew you've attached the laptop with the video cable.
a. If the same negative-like appearance appears on the larger montior, it means your problem is with the video chip which is soldered to the motherboard, the plug where the laptop screen attaches to that board, or damaged circuitry in between. This would almost surely cost more to repair than to buy a working used A105.
b. If the external monitor shows up clear and normal, then you have narrowed the problem down to the the laptop screen's connecting cable plug and there's a chance that the cable's end that plugs in has electrically shorted out elements, or the surge from the water shorting some curcuits damaged what's called the "screen inverter" or the LCD screen panel or both.
2. If the result is b., then you should look into what a local laptop repair specialist would charge to double check this and do the replacements. Then, you'd be able to make a decision that fits your personal needs and situation.
Best Regards
Aug 23, 2010 | Toshiba Satellite A105 Notebook
Sep 20, 2009 | Toshiba Satellite M115-S3094 Notebook
I have a Toshiba Satellite A135 and not sure if blacklight or something else
Your backlight lamp, (Bulb), or the Inverter is bad.
1.General instructions, and photos, for replacement of a typical laptop backlight,
http://www.ccfldirect.com/lcdtutorial.html
2.Instructions for completely disassembling a Toshiba Satellite A135 laptop. The reason I included this is twofold.
A.It shows, and tells exactly, how to remove the LCD screen from your laptop.
B.It shows you that the following information in link 3, on how to replace an Inverter in a Satellite A105, will work for your Satellite A135.
http://www.irisvista.com/tech/laptops/toshiba-satellite-a135/remove-mainboard-1.htm
(At the bottom of this page you will see Page1:: Page2:: Page 3:: Page 4
You are on Page 1. Just click on the white Page2, and so on, to continue)
3.How to replace an Inverter in a Satellite A105,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-replace-LCD-screen-1.htm
FIRST! Always remove all power! AC adapter, (Charger), and battery.
Second! Observe anti-static guidelines!
Third! This ain't tough! It just looks hard. Once you see how simple this is, I'm sure you'll agree with me.
May 28, 2009 | Toshiba Satellite A135-S2276 Notebook
Screen save stops displaying
If you go to Start Menu --> Control Panel --> Power Options --> then look the option that allows you to change the amount of time that the system turns off the monitor because of inactivity.
Apr 15, 2009 | Toshiba Satellite A215-S7422 Notebook
Toshiba satellite m35x s149 displays red pixels for black pixels
if you have a warranty - have the manufacturer replace the lcd display unit.
Sep 26, 2008 | Toshiba Satellite 2250XCDS Notebook
Toshiba Satellite P205 Tab Key
Hi I don't own one but, what's the key just above the Caps Lock key?
From photos on the Internet that looks like a Tab Key.
Shoot me if I am out of line.
Apr 07, 2008 | Toshiba Satellite A135-S2276 Notebook
Negative effect screen
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
Apr 05, 2008 | Nikon COOLPIX L4 Digital Camera
Computers & Internet Logo
5,415 people viewed this question
David Payne
David Payne
