Question about Dyson Vacuums
My DC 59 is constantly on power boost .. Pushing button but repains on power boost .. Will NOT go back to "standard" vacuum
My dyson DC 59 Motorhead works fine for a period of time then just quits. The run time seems unusually short and does not slowly lose power but stops abruptly. What is the problem?
Modern lithium Ion rechargeable batteries don't slow down as they discharge, they run full appliance and then just boom they are dead. You need a new battery
Nov 30, 2016 | Dyson DC59 Motorhead Bagless Cordless...
My new dyson digital slim only runs for 9 minutes and says on the box to run for 15 minutes. Can I return it
Hi there, it's Jack at Dyson.
Good news - you shouldn't need to return your machine! Dyson Digital Slim cordless vacuums have two power levels - high suction power mode for regular vacuuming, and Boost mode, which provides 6 minutes of highest suction power for tackling tougher tasks.
It sounds like you're using your machine set to Boost mode, which will reduce runtime to around 6 minutes. To change back to normal power, hold down the on/off trigger so the vacuum is running. Then at the same time, press and release the round illuminated Boost button on the rear of the machine.
I'm confident this will resolve things - if not, Dyson experts are on hand to help. You can reach the Dyson Customer Helpline for further assistance by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Mar 13, 2015 | Dyson Vacuums
How do i turn on boost
In Boost mode, DC59 offers 100 airwatts of suction to tackle really stubborn dirt or clinging pet hair. To activate Boost mode, just hold down the on/off trigger so the vacuum is running, then press and release the Boost button on the rear of the vacuum. To change back to regular power, you would follow the same procedure - holding down the trigger and pressing the Boost button a second time.
I hope this helps, but you're welcome to give the Dyson Customer Helpline a call if you'd like further guidance. You can reach our experts on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Mar 03, 2015 | Dyson DC59 Animal Bagless Cordless Stick...
Why does dyson dc 59 smell
perhaps the filters are dirty you should clean them or change them .it could also be caused if you have sucked up a liquid and its gone stale try the filters first
Jul 29, 2014 | Dyson DC59 Animal Bagless Cordless Stick...
My dyson dc 59 has stopped charging only 5 mnts old
This could be due to premature battery failure or charger failure.
Jul 08, 2014 | Dyson Vacuums
Sentry 3 series vacuum smelled hot, and now will not power up, changed bag (not over full)
There is a reset button on the back of the vacuum that shuts the power off if the motor gets too hot. Try pushing the little white button on the back. If it comes back on that means that there is probably a clog somewhere or the bag was too full.
Aug 10, 2013 | Simplicity Vacuums
Fuller Brush FB90 Bagged Upright Vacuum not starting
Try pushing the reset button located at the bottom on the back of the machine. If the reset button has tripped it usually indicates a clog or restriction somewhere caused the motor to overheat.
May 23, 2012 | Fuller Brush FB90 Bagged Upright Vacuum
Our westpoint home electric blanket, model 950, flashes 8 on one unit & can't be turned off. ELECTRIC BLANKET!!
Try pressing the power button and boost button at the same time. Then a C will flash and the setting you had it on before will show up. I think that was caused by pressing the boost button.
Dec 28, 2010 | Vacuums
Dyson dc14 vacuum cleaner ,the power, off-on switch does not work
Take it back - the power on switch button sounds like its being tempramental and it shouldn't do that. It would have to be repaired.
Mar 31, 2009 | Dyson DC14 All floors Bagless Upright...
Vacuums Logo
26 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
