Question about Dual Televison & Video
I have the dual deck cinevision dvd/vhs player 2003. My hand held remote barely works...how much for a new one?
5 Suggested Answers
  • 1003 Answers
SOURCE: Remote control device
you can use a universal remote that allows vcr and DVD operation go to walmart, radioshack, or target
Posted on Jan 15, 2008
vinzen
  • 217 Answers
SOURCE: Netflix dvd not playable on SamsungDVD/VHS
Buy a cheap DVD player under $50 they play anthing.I have a $600 Toshiba Tivo DVR that won't play some DVD s.My $32 RCA plays anything.Good Luck.
Posted on Sep 07, 2009
  • 11800 Answers
SOURCE: Need codes for toshiba remote to work cinevision
There aren't any, your brand isn't supported on your Toshiba remote. The only thing you can do is to try all the other codes, maybe you're lucky and one of them will.
Posted on Jul 11, 2010
  • 8457 Answers
SOURCE: Our Samsung DVD V6500 dual
This problems it is could not be happening,because the the VHS tape recording and the DVD recording functions are in the same circuitries.If u can do one way coppying,u should be able to do the reverse coppy the other way.Check ur onwner manual about this product.This unit might just a DVD and VCR player,than u can only copying form DVD to VCR not the reverse.U must have to have a DVD and VCR Recorder player to do both way.
Posted on Dec 07, 2010
The buttons on my DVD vcr don't respond
get a remote,it will be cheaper,I had the same vcr,it did the same thing,a circuit board burned up. Samsung 00008A DVD Remote Control for DVDV3650 DVDV3500 DVDV8080 Tested...
May 12, 2017 | Samsung Televison & Video
Cinevision rv 4000 locked
FOLLOW THIS STEPS AND FIX IT. God bless you
Unable to access all TV channels from my cable box
  1. You can only tune in to your cable channels on Channel 3 and you may have to use the remote for your cable box to select program channels.
Viewing resolution is poor in dim movie/TV scenes
  1. Apart from the RCA connections, try to disconnect any other video output cable from the connectors (e.g. S-Video) on the DVD player; or/and
  2. If there are other RCA inputs on the TV, you may try to connect the video and audio output to them.
Remote does not work
  1. Make sure no objects obstruct the line of sight between the remote and player.
  2. The remote may need new batteries.
Cannot enter menu selection
  1. Use the arrow keys to select option and then activate by pressing the Enter key.
Oct 30, 2013 | GoVideo Cinevision RV4000
Cant copy from VHS to DVD
You may take a look at this guide, it's about how to capture video from VHS to computer and burn to DVD, it works pretty well for me
http://www.reviewstown.com/how-to-convert-vhs-tapes-to-dvd.html
Hope it helps. If you still have problem, feel free to contact me.
Jun 03, 2013 | Toshiba Cinevision DVD/VCR Combo
Need codes for toshiba remote to work cinevision DVD/VCR player
Jul 11, 2010 | Toshiba Cinevision DVD/VCR Combo
Cinevision DVD player work with RCA universal remote?
You dont have codes for cinevision DVD player.So it cannot be programmed with Codes.
You can try programming withot code
Please follow the below steps.If it dont work then your cinevision DVD player donnot support RCR460 remote.
Code Search:
  1. Turn on the device you wish to control.
  2. Press and hold "CODE SEARCH".
  3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
  4. Release "CODE SEARCH".
  5. Press ON/OFF repeatedly until the device turns off. You may have to do this up to 100 times.
  6. When the device shuts off press and release ENTER.
  7. Try using the remote. If it does not function repeat steps 1 through 6.
Thanx
May 07, 2010 | RCA RCR460 Remote Control
Sep 07, 2009 | Televison & Video
DV220MW9 DVD/VCR: won't record video on VHS
your cable tv connect into dvd/vcr,video/audio out connect to av in your tv,solved
Jul 06, 2009 | Philips Magnavox DVD/VCR Dual Player
No usable code for CineVision DVD player with RCR461.. HELP!
A learning remote lets you program it with the original remote. I did it today with a Phillips brand remote I bought at Wal-mart. I have an cheap Memorex TV and when I pressed the volume down button on my Comcast remote, the TV setup menu appeared. I had to "teach" the new Phillips universal remote by pointing it at the original remote that came with my TV and pressing cooresponding buttons on both units. It was a bit of work, but it worked.
I guess this is useless unless you have the remote that came with the unit and don't mind switching to a new remote that has learning capabilities.
Dec 30, 2008 | RCA RCR460 Remote Control
Jan 15, 2008 | GoVideo Go Video DVD/VCR Combo
DVD/vhs combo
how is the vhs? if is ok, then the problem is the dvd and theres nothing to do with remotes, all point to a bad chip(Ic) and you gona need a tech, if the problem is with the vhs too, then try with another set of cable from the set to the tv...good luck
Aug 06, 2006 | Philips VPX210AT Dual Deck VCR
Televison & Video Logo
20 people viewed this question
Top Dual Televison & Video Experts
Jonathon summesfield
Are you a Dual Televison and Video Expert? Answer questions, earn points and help others
