Question about Food Mixers
Hi,I have model E- 60 it go up and down but is stuck in left position and would not turn right.
Motor not turning on
Get a copy of the Repair Part List for your model at Kitchenaid.com
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
Make sure that the Motor Brushes are not worn out and making good contact with the Motor.
Adjust the mixer speeds (if necessary):
Remove the screw holding the End Cover and locate the three screws from the Control Plate.
All three (2 top left and right, and 1 bottom) must be adjusted.
1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Aug 15, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Mixer has lost all speeds, only works when moving the lever back and forth. The mixer is about 9 years old.
Adjust the mixer speeds:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Aug 14, 2011 | KitchenAid KSM150PS Artisan Series Stand...
I have a KA k45ss and it is stuck on high speed only
Obtain a copy of the Repair Part List for your model from Kitchenaid.com.
You need to adjust the mixer speeds:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 28, 2011 | KitchenAid K45SS Classic Stand Mixer
My house was recently struck by lightning and my KA mixer was a victim. All ten speeds spins at the highest speed. Any suggestions?
All three (2 top left and right, and 1 bottom) must be adjusted. Make sure that the Control
Plate is not damaged in any way, contacts are not charred or burnt,etc...
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 28, 2011 | KitchenAid 32685 Mixer
Only works speeds 6-8. Turns off when moving knob to lower speeds. Tightening two screws in the back of the mixer above the power cord changed the working range from 4-6. Any ideas?
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 26, 2011 | KitchenAid 32685 Mixer
I have a Kitchen Aid k45ss that was dropped a few years ago. I works fine but the speed switch doesn't want to stay in the off position so we have to unplug it. I opened the unit and the switch...
When you said "the speed switch doesn't want to stay in the off position", you meant to
say "the speed switch in the OFF position does not turn OFF the mixer", or "the speed
switch physically cannot be moved to the OFF position"?
In any case, try to adjust the mixer speeds.
Obtain a copy of the K45SS Repair Part List from Kitchenaid.com.
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 21, 2011 | KitchenAid Food Mixers
Kitchenaid speed controller (don,t work
You need to adjust the mixer speeds.
Obtain a copy of the KSM150PS Repair Part List from Kitchenaid.com.
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 20, 2011 | KitchenAid KSM150PS Artisan Series Stand...
I was grinding some meat and my mixer got very hot. I let it cool down and now it only operates at one speed.
I am not sure what has happened to your mixer but, select
different speeds from Stir to 10. If it runs OK, then there is
nothing to worry about, otherwise do the following to re-adjust the mixer's speeds:
Get a copy of the Repair Part List of your model from Kitchenaid.com
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 18, 2011 | KitchenAid KSM150PS Artisan Series Stand...
My KitchenAid mixer will not turn on. It was working fine, then it slowed down and made a noise as if it was being overworked, then it shut off. Now it is not turning on at all. The mixer has not been...
You may have to adjust the mixer speeds. Obtain a copy of the KSM150 Repair Part List from Kitchenaid.com. Remove the screw holding the End Cover and locate the three screws from the Control Plate. All three (2 top left and right, and 1 bottom) must all be adjusted. 1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 2
Jun 10, 2011 | KitchenAid KSM150PS Artisan Series Stand...
The KSM150PS 325W mixer does nothing until speed control is moved up to position 8 or 10. Then when repositioned back down to say 6 it may run for a moment but then stops. It might just click on position...
You need to adjust the mixer speeds. Obtain a copy of the KSM150PS Repair Part List from Kitchenaid.com. Remove the screw holding the End Cover and locate the three screws from the Control Plate. All three (2 top left and right, and 1 bottom) must all be adjusted. 1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Apr 22, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Food Mixers Logo
59 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
