Grinder got clogged and stopped working so I tried to clean it. Even after unclogging it , it still doesn't work. Help
  • 575 Answers
Check if the breaker in your panel has tripped. Also check if the grinder has a reset button.
Posted on Dec 22, 2016
My Breville BDC600XL grinder appears to be clogged and would put ground coffee into the basket. The grinder also slows almost to a stop. How do I fix it?
if this isa bed-bath and beyond unit?! take it bak!. and try the Braun coffee grinder. I hav had mine for 10 years and nevr a problem.
Dec 31, 2014 | Breville Bdc600xl YouBrew Drip Coffee...
Why does no brewed coffee comes out? bypass preground does work
- coffee-channel is stuck.
check google for calibrating/cleaning your gaggia.
Aug 27, 2014 | Gaggia Titanium Espresso Machine
No steam pressure help
see this causess and proceed .God bless you
If the grinder does not run when turned on, make sure power is on to the outlet, then check the electrical cord.
If the grinder runs intermittently or doesn't stop, the switch may be clogged or damaged. Unplug the grinder and brush any grounds from the switch with a fine brush. Depress the switch several times with a toothpick. If the problem persists, disassemble the grinder to clean it and inspect the switch for breaks that you can fix.
If the grinder does not run, the motor shaft may be frozen. Disassemble the grinder, clean the shaft and lubricate each bearing point with one or two drops of lightweight machine oil. Rotate the shaft to evenly distribute the oil.
coffeegrinder1_1.jpgMost coffee grinders are accessed by removing fasteners on the base of the device.If the grinder still does not operate, the thermal limiter may be burned out. If you can't readily find a replacement thermal limiter, it may be more cost effective to replace the grinder.
If the grinder vibrates, the blade may be bent. Inspect the blade and replace if it is damaged or dull. Another cause of vibration could be a worn motor bearing. Unplug the grinder and remove the access plate. The bearing is bad if the motor shaft moves when pushed back and forth; replace the grinder.
Sep 25, 2012 | Lello 45920 Ariete Cafe Roma Deluxe...
How to clean jura C5 grinder
How to access grinder itself? Where is it? My Jura C5 doesn't grind coffee beans at all. Firstly grinder has started with starnge noise and then stopped with alarm "no beans", now it doesn't start at all..
Mar 06, 2012 | Jura Capresso Impressa Coffee Makers &...
CARTRIDGE PROBLEM TRI COLOR WONT PRINT
HTML clipboardHi
If your printer has been left unused for some time? You probably have an ink clog and the standard cleaning is not enough to clear the clogged ink.
Assuming your tri colour still has ink? (Empty they are about 30g Each 1g over that is 1ml of unused ink.)
Provided it worked OK before a period of non-use? Then you just need to use a PRINT HEAD CLEANING KIT to unclog the tiny jets.
Magic Inkjet Flush usually works a treat on those!
Magic is ideal for unclogging the tiny jets on any Canon, Epson HP and removing those horrible white lines which usually appear in prints when dried ink clogs several jets...
So if yours appears to be a clog? all you should need to do is to use a little Magic Inkjet Flush to soak the print head and you should be printing again like new.
HTML clipboard HTML clipboard HTML clipboardYou can read more here: How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
HTML clipboard
John P Bradley
Tinteiros (Ebay)
Tinteiros (Ebay)
Nov 02, 2009 | HP OfficeJet J4580 All-In-One Laser...
My machine states I need to fill it with beans when it has beans in it. How can I fix this, or am I able to have this fixed locally?
It seems that your grinder is clogged. try opening the lid for preground coffee. With a torchlight you will be able to see the outlet from the grinder. Clean out all the coffee that`s stuck there. It`s smart to have a small brush with an angle to do this, and then vacuum it all out.
Also, check your adjustment on the grinder, it shouldn`t be to fine, this could clogg the grinder again.
If this doesn`t help, you need to contact your local servicecenter.
Sep 02, 2009 | Jura Capresso Impressa E9 Espresso Machine...
Red lignt is flashing - advice on how to unclog coffee grinder?
Hi If you have not pushed the coffee button since this happened you can turn the big knob in the bean hopper to the largest # and then turn the small knob to the minus, and try again. If it clears do a second coffee. If it doesn't your going to have to clean the grinder.
Jun 07, 2009 | Gaggia Syncrony Compact Coffee...
Severe clogging
Try using long grain white rice works better than minute rise, if that does not help, then the burrs need to be replaced on grinder.
May 12, 2009 | Breville Conical Burr Coffee Grinder -...
Clogged?
I've been having the same problem. I would clean out the burrs and it would get clogged right away. But I found that at the top of the chute where the coffee comes out that there's a flap type device. Mine was clogged with coffee. When I unclogged it it would swing freely. That seems to have helped. You need to use a skewer or long toothpick to clean it and free it. Use a flashlight to see the flap. It looks like it has a weight attached to it and probably swings back and forth as the coffee is ground.
Aug 24, 2008 | Solis Maestro Electric Burr Grinder
Saeco odea go
Try to use another brand and more dry coffee.
Apr 10, 2008 | Saeco Odea Go
21 people viewed this question
k24674
jasbo
jasbo
